Easi logic 1300 servis washer/dryer
When i close the door and press the on/off button on every light on the front panel comes on and when i press start nothing happens, all the lights still stay on,
Yes must be door catch
Posted on May 21, 2010
I have got the same problem. Simply use your knee pressing the part of door handle. That's all.
Posted on Aug 27, 2008
Servis washing machine
Just by the sound of it, it sounds like it is the door lock/ sensor
Dec 10, 2013 | Washing Machines
Electric dryer not get heat
Inspect the front door lock if "F22" is displayed. Press the "Pause/Cancel" button two times. Close the washer door firmly to latch the door. Remove clothing preventing the door from closing and latching. Press the "Power" button, followed by the "Start" button.
May 12, 2012 | Maytag Epic 7.0 Cu. Ft. SuperSize Capacity...
Dryer won't come on door is closed timer ticks the
you need to open front panel or top, depends on brand and model...
you will see door switch there, to check you will need electrical meeter, unplug from power before opening it.
check continuity of switch, by pressing/depressing it.
if it's working than check start button switch if your model has it.
Jun 29, 2010 | Dryers
I have a servis easi logic 1300 working fine yesterday but today when i press the start button nothing i have checked the fuse and that is fine
It could be many things but the most common is the door lock ( electrical switch with three wires )
Jan 22, 2010 | Washing Machines
My servis m6755b washing machine door wont open
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 07, 2009 | Washing Machines
Door does not open after a wash cycle
the door lock is you problem. just replace and should be back to normal.
Mar 01, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Zanussi aquacycle 1000 start pause button
Try some WD40 on the door lock on machine (not on the door) & open and close a few times. Of course the mains plug should be off the wall socket.
Feb 28, 2009 | Zanussi IZ12 Front Load Washer
I have a whirlpool duet washer and dryer the dryer lights all come on but I get a beeping sound and dryer will not start
try to unplug the dryer for 5-10 minutes this should reset the board. if not take off the bottom panel and test the resistance of the thermistor ( the tech sheet is in the bottom there or up top)
Dec 09, 2008 | Whirlpool GEW9250 Electric Dryer
Servis easi logic 1600 washing machine not working
my servis eai logic 1300 will not rotate half way through the wash but will still spin and dry etc please advise.
May 09, 2008 | Washing Machines
Washing Machines Logo
854 people viewed this question
Top Washing Machines Experts
