Don't spend your time removing something that is not relevant to the problem.
The hose can be pulled easily from underneath of that washer reservoir.
First thing is to find out why the washer fluid leaks, look for the cause of the leak.
If the leak is in the reservoir, just remove the reservoir and check it.
If the problem is in the hose line, remove the hose from the "Y" connection between the two washer nozzle and pull the hose from the main outlet of the tank washer.
Hope that clears up everything!
Thanks for using Fixya!
