Question about GE Refrigerators
We have a GE Profile s/s double door fridge/freezer, MOD PSG29NHSBCBB No. ZH407560. The temperatures in the lcd panels have gone off, in Custom Cool panel HRS is flashing on and off and it is making a buzzing/clicking sound at the same time. Please advise what I can do before we lose hundreds of dollars worth of food! Thanks in advance. Sue
  • watchad3 Jan 11, 2009
    I have a PSI23SCRF with the same problem. HRS on custom cool panel flashes, then after a while the flashing stops and the refrigerator starts to display the temperature settings for the refrigerator and freezer, but they are not the recommended factory settings. Called the service center and all they could recommend was for a technician to come out and service it for $79.99.
2 Suggested Answers
  • 74 Answers
SOURCE: GE Profile Artica
The main PCB at the back of the appliance has failed
Posted on Aug 28, 2008
GE Profile refrigerator Model PFS22SISBSS is not cooling, the digital temp control is at 74 when I try to lower it will go to 34 then immediately back to 74. The fan and freezer are both working. A repair...
The problem is damper assembly.In the damper assembly there is a door.This door opens and close with the help of motor.The damper is located between freezer and fridge section.The cold air from freezer section enters to fridge section via this damper door.---------- What repairmen did was proper, but may be that door is not properly got open, it got closed again.Or there is ice got collected between the freezer and freezer section, so this is not letting the cool air to pass from freezer to fridge.----------- ---------- This damper assembly needs to be replaced.Actually this door functions correctly with motor.He open the damper door manually and thought, the cool air will enter the fridge section non stop, but that door is again got closed, by some how.--------- You will have to get the damper assembly part replaced, to get the air flow work properly.------- As the repair man has already ordered the part, otherwise you can get this parts from online sites like www.repairclinic.com or from sears parts direct site.-------- Getting the damper door assembly, replaced will help.Thanks.Helpmech.
Sep 08, 2011 | GE Profile Stainless Bottom-Freezer...
The custom cool bins on my ge profile refrigerator freezes anything i put in it. The rest of the fridge is normal temporarture.
Did you ever find a fix for this? I have the same problem, it even freezes items in the produce bin above the custom cool bin.
Dec 25, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a ge profile psc23nhpa refriderator that the fridge side of the unit temperature shoot up to 135 over night. But the freezer side was still very cool. What could cause this?
Are you sure it is 135? If the freezer is cold but the fridge is warm, most likely is the damper door problem. (Basically, it's a door controlled by the main board, get cold air from freezer and close when the fridge is cold enough)
Oct 17, 2010 | GE Refrigerators
GE bottom freezer model PDS22MBRBWW gets too warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE Profile PDS22SBRR Stainless Steel...
I'm unable to set GE Profile Arctica ridge to recommended temp
OK, First let us check the compressor to see if running or trying to start. Pull away from wall and unplug from wall. Remove lower cover and feel the compressor top of the to see if too hot to hold hand there, cool or warm. look inside freezer and tell me if ice is building on rear wall. Answer that and I will be able to tell you what we need to do, Thanks, Sea Breeze
May 06, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ge profile fridge will not cool
i would check to make sure you can hear the fan in the freezer you may need to hold in the door switch
Oct 08, 2009 | Refrigerators
GE Profile Side by Side is getting too cold on the fridge side.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Artica
Nov 12, 2007 | GE PSS25NGM Side by Side Refrigerator
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
