Question about SanDisk Sansa Clip MP3 Player
Computer wont recognize device
Plugged new sansa into usb port -- I keep getting an error message saying that it didnt load properly and may not work -- and "my computer" doesnt recognize the port. I tried on other ports, none are recognizing. I know its not the USB port because I can use my sancruzer flash drive & external hd on any of my ports. I have an HP pavilion x5369c1. advise please! i bought this for a gift and wanted to load some music on before giving it.
thank you
Kree in Seattle
  • Anonymous Jul 01, 2008
    won't recognize
  • 8,596 Answers
Your computer may not be compatible with the software on the installation CD - check Sandisk's website for a more up to date version of the software. Many, many, many products are not and never will be compatible with Windows Vista.
If it is DEFINITELY not an incompatible operating system, then:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jul 01, 2008
Used for years. Deleted mp3 files. Tried to reload new mp3 files by select all and drag and drop to audible folder. Message said it was full and would only load partial. Deleted partial load safely...
Sorry mate it has been corrupted and and may not work any more it seems the set up and read file that is like a operating system has been moved or deleted. The same things happens with usb drives.or has been disconnected without using the disconnect usb device icon.
Jan 31, 2011 | SanDisk Sansa m240 MP3 Player
I just purchased a sandisk sansa fuse mp3player and for some reason my computer wont recognize the player. the player itself says that it is connected to my computer and the usb chord is plugged into the...
i would need you to try connecting it to some other ports and see how it respond because you see, some devices tend to behave like they are working properly but wouldn't work if they are not connected to a hi-speed hub(port) let's say 2.0 or something.hope this solved your problem?
Oct 21, 2010 | SanDisk Sansa e260 MP3 Player
Sansa view is no longer recognized when plugged into USB port
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Sep 07, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Usb is not recognizing sansa
try going to "my computer" on your desktop and it should show an unkown device thats plugged into one of your drives
Aug 01, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Sandisk sansa 2gb
Make sure the hold/lock switch is not engaged first. If you do not have a USB 2.0 port, then you do not have enough power to make the computer properly recognize the device. Laptops need to be plugged into a wall outlet AND have a USB 2.0 port for you to have enough power, especially.
-Tha Mp3 Doctor
Oct 28, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Wont Connect to the Computer
-Tha Mp3 Doctor
Jun 10, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 mp3 player
my e260 sansa mp3 player dont recognized by computer what to do
May 06, 2008 | SanDisk Sansa e260 MP3 Player
Malfunction
-Tha Mp3 Doctor
Dec 01, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
141 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
