Question about Sony MHC-GS300AV CD Shelf System
Can i connect a mic??
Can i connect a microphone to my stereo to record sound??
  • 4,472 Answers
No that is not really possible with this system nor would I recommend using it to record. What is it you are trying to record?
Thanks,
Lee
Posted on Jun 30, 2008
Hi i have connected the Samson G-track with my macbook. also i using Nicecast & Traktor for radio broadcasting. when i talk from Samson G Track my voice comes only from left speaker. I try the...
This is because the G Track's Mic signal is on the Left channel and the Instrument signal is on the Right channel. You are making a stereo recording when you should be making 2 mono recordings. Does Nicecast have an option to set the track to mono Left channel? Traktor should, but I haven't used it so I can't tell you where the option is. There's probably a Track Input drop-down or something like that.
Sep 12, 2011 | Samson G-TRACK USB RECORDING MICROPHONE...
The mic does not record stereo anymore. when playing back a stereo works fine but when recording in stereomodus only the left channel records, the right channel seems to record silence/noise
This Mic is not a stereo Mic. If you're using a windows computer, check your sound control panel to see if the mic wasn't suddenly set to two channel device.
Sep 30, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Tried to use mic, only picking up computer sounds.
Ensure that you have selected the Microphone or the Line-in as your recording input. It sounds like you have set STEREO MIX as the recording input. Double click your speaker, select from the drop down "Properties" then Adjust volume for (RECORDING) select that and ensure that your appropriate recording device is selected. (XP)
Jun 30, 2009 | Dynex Audio Players & Recorders
My mic is recording sound from the headphones, NOT the mic piece, why is this?
-right click on the volume icon on the system tray and select recording devices
-there should be a selection that says stereo mix or something like it
if not.. right click on a blank space on that box and select "show hidden devices"
-you must disable this device
-make sure your microphone jack is enabled
-click apply and it should work
Apr 12, 2009 | Microsoft LifeChat Stereo Headset with...
Built in mic
Goto the Volume icon in the tray on the right hand side of the taskbar.Open it.Goto the recording properties and change the recording option to microphone.The initial setting could be with a Stereo mix.Once you did the necessary change, the recording should be normal.Please do rate if this solves the problem.
Dec 06, 2008 | Toshiba (P000257700) Microphone
AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Dec 03, 2008 | AKG Perception 100 Microphone
Samson co1u recording issue
you first 3 people are idiots... maybe if you had worked with the hardware you would know how the mic works because its obvious you don't. The 4th person is correct because this is exactly how i use the mic and it captures sound in stereo format beautiful when set up rite. Using it in mono, whether use keep on one channel or two drastically reduces the crisp sound that this mic can record.
Mar 18, 2008 | Samson C01U - USB Studio Condenser...
Playback only on left speaker
The quick, easy solution is to change your microphone to mono recording. In the attached YouTube clip, I'll show you how to do that.
The short and simple is to go to your Mac HD -> Applications -> Utilities -> Audio MIDI Setup. Select your C01U USB device, and set it to 1ch 16bit. This will set the microphone to record in mono, equally over both speakers.
Nov 26, 2007 | Samson C01U Consumer Microphone
Line Recording with H5500
i think that audio jack is for headphone-microphone combined (those cable plugs have a three black lines , top for left audio, center for right audio, last line for microphone) so you can use a headphones with mic directly with this 5500. the mic is i said before is the last line. what you need is a monophone plug. (mono mic) i dont think stereo mic will work.
Sep 12, 2005 | HP iPAQ H5555 Pocket PC
Sony MHC-GS300AV CD Shelf System Logo
65 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
