Question about Cambridge Soundworks BassCube 12 Speaker
BassCube 12 Startup Problem
I have had a Bass Cube 12 for several years and it has worked flawlessly. It is plugged into the switched outlet on the back of my Marantz receiver. I recently went on vacation for a week and shut down the Bass Cube by turning off the receiver. Upon my arrival back home, I turned on the switch at the power-strip that the amp is connected to. I heard a loud noise similar to a loud ground loop coming from the bass cube. After about a minute, the power LED went off and the ground loop disappeared. From that point onwards, I have not been able to power up the BassCube. There is no light coming from the LED but the fuse appears to be intact. So, at the moment, the unit is dead. If you have any suggestions on how to fix this issue, please pass them along. Thanks
  • brians_62 Sep 25, 2008
    My Bass cube 12" did something similar...except that now it immediately blows the new fuse right when I plug it in. I think I am just going to toss it in the garbage. Any suggestions? Besides junking it?
Same here... nothing changed though like a move or wiring etc... just stopped working one day and i realized the fuse popped... now blows fuse as soon as i plug a new one in! Quality product right!?!?! Heading to the store after work today to purchase a 10" def tech... sux!
Posted on Mar 23, 2010
Same here. happened after moving residences
Posted on Aug 29, 2008
No speaker output from Basscube 8s
Yes. Check your connections that you are using from your preamp/processor or receiver to the Basscube to confirm that any adjustments I'll give you instructions for will go to the correct output. There are 2 ways that signal can be connected to the Basscube, your inquiry does not describe which you are using; either speaker level or line level. Line level is the easiest as it uses only one cable so I'll assume that is what you've used.
The following instructions I'll provide you with will presume that you are using a digitally controlled receiver or preamp/processor with an LED or LCD display and remote.
On the preamp/processor or receiver, navigate to your speaker setup menu and adjust the frequency output of any bass management system it may have to a full range signal. This may be a setting labeled for speaker size for example, choose "large." Or, if it has just a crossover setting, increase that to it's highest value.
Then go to the rear panel of your of your Basscube. Adjust the crossover to about 120Hz.
Return to your preamp/processor or receiver. Navigate to your speaker level control on the speaker setup menu. Increase this level to a matching value for each channel until you can hear your Newton speakers.
May 16, 2012 | Cambridge Soundworks BassCube 8S Speaker
Basscube 15 hums only in "Auto" mode?
There is a guy on ebay (edwards electronics) that can repair this amp for around 150.00
Feb 20, 2012 | Cambridge Soundworks BassCube 12 Speaker
Bass Cube 12 makes loud buzzing noise when turned on !
Hi Ok thanks. I cannot be 100 % sure about this without seeing it but it sounds alot like there is a power supply issue, either bridge rec or caps. Caps are very often very obvious. If you get into it and have a look at what is normally the 2 or 4 biggest capacitors at the start/power supply of the board and see if they are ok visibily. If they are bulged, (often they actually explode and leave paper residue) then those are what need to be replaced. Have a look and see.
If its the bridge rec, it could be 4 diodes, fairly large next to each other or a square component with 4 legs out. Need a meter to test, but i would start at caps first
All the best
Aug 03, 2009 | Cambridge Soundworks BassCube 12 Speaker
Changing out my monitor speakers to bose cube speakers
You probably can do it as long as the speakers there now are 8 ohm speakers and you must use the bose bass module with the cubes because the crossover is built into the bass module for the cubes to work. If you just wire up the cubes you will mess the cubes up and they want sound right at all. The cubes are no good without their bass module in other words. Hope this helps.
Nov 09, 2008 | Bose Lifestyle 12 System
Basscube remote knob wire
funny seeing this question posted here... I worked at Phoenix Gold for 4 years, and I can help you with your problem.
when the BassCUBE was designed, the engineers didnt realize that a standard phone cable is what we call a "flipped cable", where if you were to lay the cable flat without any twists in it, on one end the connector would be tab up, and the other end would be tab down. on a standard RJ11 plug (the phone plug), the telephone requires that the pinout is as follows:
#1 - Black
#2 - Red
#3 - Green
#4 - Yellow
But the BassCUBE needs a non-flipped cable, which are hard as heck to find... so I will give you the quick easy fix.
You need a 2-line (4-wire) telephone cable that has a black, a red, a green, and a yellow wire in side it, and you will need 4 crimp caps or other way to splice the wires back together. You then need to cut the wire in half, and carefully seperate and strip each wire on each piece of the cable. Call one piece "Part A", and the other piece "Part B". Then you need to splice the cable back together as below.
Part A Part B
Black ------------------> Yellow
Red --------------------> Green
Green -----------------> Red
Yellow ----------------> Black
Once you have done this, and your SURE that your splice is good (not shorted out), then go ahead and plug your modified cable into the BassCUBE and its remote control, power it up, and you should be good to go.
Nov 04, 2008 | Phoenix Gold Tantrum BASSCUBE Car...
Freezer GFI reset
no what rpobebly happened is that your freezer fillefd up with humidity and now its shorting out and tripping the breaker. make sure that theres no ice in the freezer also you should not really have it plugged intoi a gfi outlet.if its in the garage near the breaker panel i would add a dedicatefd outlet for the freezer from the electrical box.
Jul 01, 2008 | Frigidaire FRT15G4B Top Freezer...
the correct size fuse is based on amps, not volts. The correct fuse rating should also be displayed on the chassis of your sub, if in doubt take the original one to an electrical shop and let them identify it for you.
Nov 26, 2007 | Cambridge Soundworks BassCube 12 Speaker
Home theatre sub
Sounds like a ground loop issue. Try plugging your sub, and the rest of your entertainment equipment into the same outlet with an extension strip (4 plug adaptor). If there is too much stuff to plug into one strip, experiment with combinations and hopefully you will find which piece of gear is the culprit.
Aug 28, 2007 | Cambridge Soundworks BassCube 12 Speaker
Repetitive buzzing noise
Some componet in the Amp circuit is breaking down. The longer you let this go, the more of a chance that you will have a major short and blow out several parts,m as thats what happens with amps. Get it service asap and dont use it.
Sep 01, 2006 | Cambridge Soundworks BassCube 12 Speaker
Open Questions:
See all Cambridge Soundworks BassCube 12 Speaker Questions
Cambridge Soundworks BassCube 12 Speaker Logo
873 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
