Question about Whirlpool GS6NBEXR Side by Side Refrigerator
FRONT WHEELS ON FRIDGE NEED TO BE REPLACE
BOTH OF THE WHEELS IN THE FRONT OF THE REFRIGERATOR NEEDS TO BE REPLACED
  • karl siasico May 11, 2010
    which part of your wheels need to be replace?the front, the back,or vice cersa?
    Filmmaker:
    Uploaded 5 video answers.
  • 41 Answers
If your fridge still new then your fridge still have a warranty. if not youll have to buy a fridge stand that can be bought from any appliance store as shown below.some stand have wheels and some dont. i hope i was able to help you with your problem. tnx!
FRONT WHEELS ON FRIDGE NEED TO BE REPLACE - fridge-stand-150-ltrs-to-220-ltrs-.jpg
Posted on Oct 07, 2008
  • 61 Answers
Refrigerator whirpool is only working after tapping on the front control system panel? which part has to be replaced?
Whirlpool side by side fridges with the control panel across the fridge section have thermostats that will fail. Tapping on that control panel will cause the fridge to work temporarily. You will need to replace the refrigerator thermostat if you see small black specks under the thermostat.
Oct 21, 2016 | Whirpool Refrigerators
The "rubber covering" on my fridge wheels is scuffed off and the new wheels they sent me don't have the rubber covering. How do I replace this covering?
Hello Jim;
My name is Peter. I am a retired field service refrigeration technician.
Refrigerator manufacturers do not field test their designs before putting them on the market. They make their design changes based on customer complaints and field technicians doing repairs under warrantee.
Now, neither your front or rear wheels have a rubber covering. I am not surprised. A refrigerator is a lot of weight to move even on hard rubber wheels.
Current front wheels:
The rear casters are hard to install. They have a history of cracking and falling apart and are difficult to replace. LG has a history of high service calls.
Feb 01, 2015 | Samsung RF217ACRS Bottom Freezer French...
How do i lower the rear wheels? The back end sits flat on the floor but the front is raised higher because the nylon wheels are fully retracted. I will also need to level out the fridge.
set the level that backside of the fridge must be lower than front side,so that doors may,must be closed automatically after open the fridge
Jul 08, 2014 | Amana ASD2620HRW
Whirlpool fridge/freezer LCD replacement
What is the model number listed inside the refrigerator section?
Nov 17, 2012 | Refrigerators
Front wheels on ge refrig squeak when opening the door(s).
What is the model number of your GE refrigerator?
Jul 21, 2011 | Refrigerators
The freezer door opens if the refrigerator door is closed hard
this is quite normal on a lot of fridges ! if it isnt closing again by its self you need to re-level the fridge and have it very slightly backwards . alternatively the fridge is not level side to side !. open the main door a third to halfway open and let it go, it should close under its own weight, if not adjust up on the hinged side leg or down on the opposite side , if the front legs are not not adjustable pull it out and adjust the back legs , a quick fix, is to chock up the front leg and all will be ok ,regards terry ps, clean the seals and the fridge where the seals make contact the seals probably do not need replacing unless the fridge is very very old. a lot of people replace seals when its not needed. regs terry
May 17, 2011 | Frigidaire Refrigerators
I need to level the refrigerator. The back needs
Hello Monty, If you can roll the fridge out, you'll likely see the adjustment screws for the rear wheels, (if equipped). If the rear wheels are fixed, as most are, you can put a couple of wooden shims down on the floor where the wheels will be and roll the fridge back into place and then make the leveling adjustments from the front wheels.
If the amount of height adjustment is greater than a half an inch, you can use a solid piece of plywood the width of the fridge and about 4-6" wide and place that at the back. Roll the fridge in until it hits the plywood and tilt the fridge forward about 2 inches and push it back until the rear wheels are on the plywood. You can then, again, level the fridge using the front wheel/leg levelers.
I've found that it's easier to get a good idea of just how much out of level the space is where the fridge is being placed. Then you can make the changes using the best materials for the situation. Shims are fine for small adjustments, while the full width plywood is more consistent and easier to adjust, as the fridge will likley get moved out every 6 months or so, for cleaning of the coils and behind the fridge.
Remember that ideally, you want the front of the fridge just slightly higher than the back, so the doors will close by themselves, when opened almost 90 degrees and released by hand. Gravity should then take over and automatically close the doors, ensuring a good seal to keep the fridge closed and running properly.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Maytag MFI2568AE Side by Side French Door...
Need to move it.
you have to adjust the front legs untio the wheels make contact with the floor.. then after moving it adjust untill the doors are level with each other
Jan 20, 2009 | Samsung RS2534 Side by Side Refrigerator
Broken amana refrigerator wheels
Usually the roller for the rear of the fridge has an axle that is just a pin that will slide out(need a model # to know for sure) and the weight of the fridge holds the pin in place.
Dec 05, 2007 | Refrigerators
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
347 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
