Question about Windchaser PACR10 Portable Air Conditioner
Windchaser ac leaking alot of water into room
My windowless ac unit has been leaking water which destroyed about 30 planks of hard wood. I put it inside a plastic container but the water leaks still and fills up. I am afraid this will case a fire. I need to know how to fix this problem asap.it is too hot to go without but i do not want to put myself in danger. please help!
Krazytech
  • 725 Answers
SOURCE: Exhaust fan making loud noises
Still under warranty. put it back together and don't tell anyone you took it apart. Call the factory numbers and have them fix or replace it...let us know what happens..kraxytech
Posted on Sep 11, 2007
  • 340 Answers
SOURCE: windchaser AC leaking water
maybe cloged kinked line needs cleaning
Posted on Jun 17, 2009
vinceisaac
  • 2432 Answers
SOURCE: I have a windchaser portable
hi check first the compressor motor if it is running which cycle the cooling system .then make sure the thermostat knob is good. if all those i mentioned are good.now look for the thermostat if it is good and with contact.if still air doesn't cold might need to refill freon by this time you need an AC technician to do the work. i hope it will help you good luck.
Posted on Jul 03, 2011
  • 50 Answers
SOURCE: unit shuts off, getting an
E5 is the fault code for Compressor overheat/malfunction it coulb be caused by the exhaust hose being too long or kinked, remove the exhaust hose and run the unit for an hour and see if your problem goes away, if so re-route the exhaust hose, if not you need to contact the manufacture
Posted on Jul 23, 2011
cool78259
  • 228 Answers
SOURCE: when i run the ac
All portable or window ac units are mounted or standing with the back lower housing at a slope
so that the condensed water buildup from the evaporator can drain into a tray or thru a tube out
the back of the unit, depending on what kind of unit you have you may have to take it apart and
make sure the drain for the condensed water is not blocked. some times these units are not
installed correctly, they will not drain properly and standing water with time will turn to rust and
clog up the tube where it needs to flow from the ac unit. good luck!
Posted on Jul 31, 2011
What causes the exhaust hose to get hot on a windchaser portable AC
make sure its not obstructed, then wrap it up with a towel or other insulative material. it heats up because the heat exhausts through that hose out the window.
Jun 28, 2014 | Windchaser PAC9 Air Conditioner
Ac leaks
If you are talking room a/c then the holes are water drain holes. The one on the bottom allows water to drip into a garden etc and the one at the back you can fit a hose to drain away
Jun 14, 2013 | Windchaser Wind Chaser Air Conditioner...
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
When i run the ac it leaks on the floor from the inside n i dont know what to do about this problem.
Jul 31, 2011 | Windchaser PACR10000 Portable Air...
Brand new GE room size ac unit (1 week old) is spiiting water out of the air vent into the room. Unit 100% level.
If a brand new unit is spitting water, i waould suggest that it is short of refrigerant... Get your installer back or the Manufacturer.. You need to hold An ARC licence to do this ( In Australia)
Jul 16, 2011 | Heating & Cooling
I don't know how to uninstall my ac
have some one steady the unit while you raise the window a bit.carefull,it may want to fall out.pull the bottom of the unit in a bit.if that dosen't change the angle,like if it's sitting on a storm window frame too,place a wood plank between edge of sill & storm window frame to raise the inside bottom of unit a bit above the sill.it only requires a few degrees of tilt.
Sep 22, 2009 | Heating & Cooling
A lot of water leaking out of A. C. into neighbor's window below
Place a flat piece of sheet metal or aluminum under the unit that is LONGER and Wider than the unit.....the water will drip on it and run down it and away from the building.
Aug 17, 2009 | Frigidaire FAC126P1 wall/window Air...
LEAKING WATER EVEN AFTER DRAINING THROUGH THE BACK HOSE. AFTER USING FOR ABOUT 8 HRS, WATER STARTS TO LEAK AT THE BACK THEN IT STOPS WORKING AND RED LITE FLASHES ON THE ON/OFF BUTTON. IT LOOKS LIKE WATER...
Being that I am the owner of a Haier 12000 BTU portable A/C unit with the same flipping problem & having a husband that works as a refrigeration tech with plenty of experience with A/C units of all types, we have come to the conclusion that the evaporation pans they put into these portable units are either too small or faulty! The best advice I can offer you if you are out of warranty is to raise the unit onto a sturdy & level base (you can use wood planks if nothing else can be found) & attach a hose to the plug (open of course) & run the hose into a bucket. Sadly, I was unaware of how bad our situation was until my husband told me that it is "raining" in our dining room! We'll now have to rip up carpeting (only 5 years old), rip up the old vinyl flooring to check the sub floor & if that's too bad off, we'll have to replace it, then cut out the sheetrock of the ceiling, treat for black mold before it happens (because it will, wet wood & sheetrock make a lovely sort of place for it to grow exponentially!) then rebuild the ceiling! I hope you got help before my answer & good luck!
Jul 23, 2009 | Haier HPAC99ER Air Conditioner
Windchaser AC leaking water
Jun 15, 2009 | Windchaser PACR10 Portable Air Conditioner
Windchaser PACR10 Portable Air Conditioner Logo
87 people viewed this question
Top Windchaser Heating & Cooling Experts
Jay Finke
Jay Finke
Donni Steen
Jake's Auto Care...
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
