Question about Cobra 29 LTD CB Radio
COBRA 29 LTD
No tx and no red tx lite
    Brigadier General:
  • 6,966 Answers
Your concern is no transmit and no red transmit led -
If there is no receive likewise, then probably problem in the PLL/VCO section or 9V voltage regulator TR23 (2SC1096) or Zener diode D22 (9.1V).
If the receive is normal, then possibly any of two (2) faults:
1. microphone/PTT switch and/or the mic cable specifically the wire connected to pin# 3 of the connector; or
2. +8V switching transistor TR21 (2SA733P).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 30, 2008
How to change RF meter lite in cobra LTD 29 radio
It's a small bulb . There is a number on it. You may have to get a magnifying glass to read it. It is soldered in so removal will require a soldering iron of a low wattage.
Jun 20, 2015 | Cobra 29-LTD 29 LTD Classic CB Radio
Cobra 29 LTD LX LE vr pots
vr1 "s" 9 setting on the tx meter vr2 voltage setting vr3 squelch vr4 amc vr5 p4 display on tx signal meter.
Mar 22, 2013 | Cobra 29 LTD CB Radio
Cobra 29 ltd c b radio no tx no rx
you will have to take it to a repair shop and let them fix it or buy another one .
Dec 08, 2012 | Cobra 29 LTD CB Radio
Cobra 29 ltd Classic no sound, no rx, all lights work rx,tx, lite up. The SWR meter moves when mic is keyed up.
Check speaker and plug external one in if you have it.
swap mic could be a broke wire or bad switch in handset.
check antenna and coax connections.
i know checks sound basic but they could save you a lot of headaches later
May 31, 2011 | Cobra 29 LTD CB Radio
Key to tx-green lite out-no output power or red lite rec ok
It could be small transistors--in the back where the light and transmit hook up. One small transistor will shut down transmit & possibly receive. Get it serviced at a radio repair shop. if you know how do it yourself. Change all small transistors to 2sc3904 or 2sc 3906 at "Radio Shack."
Apr 30, 2011 | Cobra 29 LTD CB Radio
Cobra 29 ltd cb radio will not transmit can you help
can you tx to a radio next to you? if so problem is in the rf final transistors. replace them and you should be back in business.$5-$8 in parts.
Jan 06, 2011 | Cobra 29 LTD CB Radio
Red RX/TX and red ANT light on my CB
Well,first hand ,some cobra radio,s have red some have green RX/TX lights, but are you modulating? Some green lights turn red. What is your standing Wave on the antenna,s? You need to check it and the output of the radio. To do this you need a watt or field strenth meter. Can get one at Radio Shack. Your standing Wave is ok as long as it is below a 2. That has to be done on the antenna. ..hope this helps...
Mar 11, 2010 | Cobra 29 LTD CB Radio
I have a deisel 4-7 echo mic ineedcolor to pin to wire it to a Cobra 29 ltd classic thank you so much
cobra:black--ground
yellow--mic
red--tx
blue--rx
the wiring for the echo mic is identical
Sep 16, 2009 | Radio Communications
Cobra 29 nw ltd won't transmit
Have you cracked the radio open yet?  check for loose connections etc.  get back to me if that doesnt yeild any results
Dec 23, 2008 | Cobra 29 LTD CB Radio
No TX Power
If it is classic it is a 2SC2029 driver transistor.
Nov 18, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
236 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
