Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Power cord to fit modelBEFSR41
I need power cord voltage and amps for BEFSR41
  • 39 Answers
Try compusa
Posted on Jun 30, 2008
9v power supply ,................
Or better buy new one its useful.........your problem is solve
Posted on Jul 29, 2008
I lost the power cord to my "vintage fiber optic light" and would really like to use it. I don't know the voltage, so I can't even try to use another cord. Any ideas I what I can do?
If it is the type that has a cord, a power transformer and then the unit, look on the area where the power cord plugs into the unit. It ought to have the voltage, milliamps needed and the polarity.
If you have only lost the power cord, it just need to same type of plug.
Dec 11, 2016 | Office Equipment & Supplies
Where can I find a power cord for simpletech
Hi, I think I found one for you 5V AC DC power adapter for SIMPLETECH 96200 41001 075 250GB USB hard... . If it is correct, it is OK to just find ANY power cord with Output Voltage: 5 Volts DC and Amperage: 1 Amps. It just need to fit in.
Sep 21, 2014 | SimpleTech 250GB USB2.0 7200 RPM External...
No stop key indication and treadmill wont power on
Check the 2 fuses under the motor shroud. One should be a 10 Amp fuse, the other should be a 15 Amp fuse.
Is the red LED lit? If not, check outlet, check power cord for treadmill. With cord unplugged, check the connections on the motor control board for the AC input, which are marked AC1 and AC2.Plug cord back into the wall outlet, and check voltage at those terminals- it should be 90 volts or higher.
If those check out- replace Motor Control Board,
Dec 31, 2011 | Startrac Fitness Products Star Trac 4500...
I need to replace the charger and cord for my laptop. It is a 19v 3.95a. How improtant is it to match the amp rating?
The Voltage must be within 10% of your original AC Adapter Voltage. The Amps may be the same or higher but they cannot by lower. Or it would damage your laptop. Besides the voltage and current, make sure the connection fits the port in your laptop.
Source for Toshiba laptop ac adapter
May 17, 2011 | Toshiba Computers & Internet
I lost my tv power supply cord my tv is 110-240 can I use a 10a 125V cord from my computer that fits in my tv (to replace the one I cant find)?
No,tries websites like,, to buy the right power cord.They're different cords tv power cord 110-240 voltages.The computer a/c power cord 10 Amp to 125 voltages.Don't try it,will burn somethings on the tv.
Sep 17, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
Power cord issue? Black Screen with image issue?
The powere cord you are using is fine (the cord is made to handle the 10A load, you are only drawing 1.5A). The monitor uses switching mode power supply that can handle any voltage INPUT between 100v up to 240v. More likely to be bad caps in the power supply. See example of failed Westinghouse due to bad caps:
Mar 01, 2010 | Westinghouse LCM-19v5 Monitor
My power source is not doing anything! I've checked my cord, and it has full power, but I'm getting no "juice" from the system when it's plugged! I'm going to replace the power source for this Acer, but...
The PSU must be EXACT or it will damage the unit. Also the "Polarity" of the plug MUST be correct too. That is why it is always best to get the Acer one... But in saying that usually they are usual 9 - 12 volts at 4 - 5 Amps.
Jan 26, 2010 | Acer Aspire L100 PC Desktop
Power requirements
The BEFSR41 version 2 requires 9 VAC @ 1.0 Amp.
Jan 25, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
BEFSR41 power supply?
Both the voltage and the polarity should be printed on the case of the router. The polarity should be right next to where the power plugs in.
The polarity information will look something like this:
If you take the router into a local Radio Shack, the clerk will probably be able to tell you which power supply you need.
Jan 09, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Can't get power cord
I assume this model comes with an external power supply- that is a package that plugs into the out let. you can buy at places like Wallmart a universal power supply, that has a variety of connectors and a switch to change the voltage. the connectors have a colour code and match the voltage slider which also has a colour patch. Take a look at the monitor to see if the operating voltage is mentioned- but is does not matter. what you do is take a connector- not plugged to the cord and fit it to the power inlet- you get several connector and only one will fit -the right one. Match the the colour to the voltage slide on the power pack and you are in business- well maybe - I bet first time it will not work That's OK simply unplug the connector from the cord and reverse the pins [reverse the polarity] come back
May 20, 2007 | Gateway FPD1810 18.1" LCD Monitor
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
276 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
