Question about Toshiba SD-V392 DVD Player/VCR
Need new drive belt for cd/dvd tray
Hi. Where can one order a new drive belt for the cd/dvd tray? Mine broke and I used to be somewhat of a DVD repairman, but don't know where to order parts. Any help on this??
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 106 Answers
I have an acer aspire x1200-b1601a with a cd/dvd drive that will not open without putting the tip of a knife along the edge and prying it open. the "magic" pinhole is behind the case's cover and cann
CD-ROM, DVD, or other disc tray not opening Locking device or software installed First, verify no locking software installed that prevents the tray from opening. If you are unsure, reboot the computer and as it is booting up, eject the tray. If the tray can eject as it is booting, but stops working after loading your operating system, something is being loaded that is preventing the drive tray from opening. Programs used to burn CDs are a common culprit.
Bad eject button If you are running Microsoft Windows, open My computer, right-click the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective, and it is recommended that the drive be replaced.
No power to computer or disc drive If you have recently installed a new optical drive or you have moved the computer, the power cable to the CD-ROM may have become loose or disconnected. Reseat the power cable to make sure this is not the problem.
CD stuck within drive If you suspect that a CD may be stuck within the drive, the tray needs to be ejected manually. Look for the small manual eject hole that ( not the head phone jack) located on the front of the drive. Unwind a paper clip and place one end of the paper clip into the hole to eject the CD-ROM tray.
If CD-ROM tray opens part of the way, pull it gently to see if you can get it to open fully. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become damaged or dislodged. But usually, a stuck CD is blocking the way.
Caution: If you are able to open the CD-ROM drive using a paper clip, we do not recommend continuing to do so. This is meant to be used as a temporary solution; the drive should be replaced.
What to do if CD or DVD stuck in drive? Note: This document is for disc drives with a disc in the drive that prevents the tray from opening. See our CD-ROM, DVD, or other disc tray not opening document, if the tray is not opening at all or doesn't seem to be getting power.
If the CD or DVD is not set into the disc tray correctly, it could be sticking up above the surface of the tray, causing it to get stuck with then tray tries to open. In this case, it may be possible gently shake the computer and move the CD or DVD into the correct place in the tray, allowing the drive to open. However, use caution when doing this, as you do not want to shake the computer too much, or you could damage other components.
If this is a desktop computer, you can prevent damage to the computer by opening the computer and removing the disc drive in order to shake or rotate the drive. When the drive is out of the computer, you can manually release the tray by inserting a paperclip into the manual eject hole.
In the case of a laptop computer or a slot load disc drive, since the CD or DVD does not sit in a tray, it cannot be shaken in order to adjust the disc. If the disc is visible you may be able to move the disc a bit by hand, enough to allow the drive to eject the disc. Again, be careful in doing so, as you could damage the disc or drive in the process.
If you're still unable to get the disc out of the drive after following the above steps, it may be a damaged drive and should be replaced. If the disc in the drive is an important disc and you believe the drive is bad, the drive can be disassembled in order to remove the disc. In the case of a laptop or computer with a slot load disc drive, the computer needs to be serviced in order for the drive the be replaced and the disc to be removed.
reference: http://www.computerhope.com/issues/ch001487.htm
Jan 03, 2015 | Acer Computers & Internet
Close dvd drive
Most DVD/CD drive are belt engaged driven by a small motor. If the tray is not sliding in and out by itself, it is highly probable that the belt is cut and therefore of course would require replacement. In some instances, it could be the small motor itself or the servo electronics that control it. There are also known instances when the tray is misaligned or the plastic rail/gear underneath have been worn out.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 19, 2008 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
My cd tray broke on my desktop, where can I purchase a new cd drive for a cp4401 Balance
Hi adrake13600...
Any CD/DVD drive will fit in your computer...just make sure it is an IDE and NOT SATA connector for the computer hook up
Please take time to rate me
Sep 10, 2011 | Balance CP4401 PC Desktop
Dvd writer's flap not going in..
Breaking of cd indicates that the cd is not aligned (tightened) properly between the spindle and the magnetic top, if the tray dos'nt align properly it may not lift the spindle up, open the drive and check for any obstacles in the tray path, important if your drive uses rubber belt to drive the tray in-out replace the belt, also check the magnetic top for breakage.
Jul 24, 2010 | Samsung (SH-S162L/BEBN) DVD RW Burner
PC s/n = 0029975695: The tray will not eject. When
The usual problem with disc drives is a little belt that drives the loading tray. It stretches with age and slips, so the motor turns but the belt doesn't. If you want to take the time to try finding one, the belt is replaceable.
On the other hand, new DVD/CD burners are only around $30, so it's usually not worth trying to repair the drive. It's faster and easier to put in a new one.
Hope this helps. Thanks for using Fixya!
Mar 01, 2010 | Gateway (5502134) CD-RW/DVD-ROM (Combo)...
Dvd drive wont open , can hear motor working but drive wont come out. we believe the cd holder isnt shifting up/down to allow the drive to activate & open
Turn the computer off,Remove power cable.Use a peper clip insert it through a hole infront of the dvd drive this will eject the door.Make sure once this is opened the tray is aligned properly,slide it in and out.Push it in all the way then power up the computer.This may work for a while,before it goes again,so you might have to replace it.
Good Luck
Jan 17, 2010 | Lite On SHM-165P6S DVD RW Dual Layer...
LG V782W Combo DVD/Video Player - DVD won't eject
Hi
I am trying to set up my LG V782W but have lost my user manual.
Can you help. I need to know how to tune channels and program to record.
thanks
steve
Jan 30, 2008 | Televison & Video
Cd tray eject problem
THE DRAVE is DAMAGED
the carriage unit (tray) is braoken, you can open it up and use plastic weld to fix the broken off part or you can change the tray or buy a new one :)
Dec 22, 2007 | Samsung (DSSMBK482448) CD-RW Burner
Dvd recorder goodmans door sticking
open up your machine then check the cd tray there is a motor that drives the tray. between the motor there are gears which rolls the tray in and out. check properly you will see a belt '' blader kind of'' plz replace with brand new one it will work fresh coz if the belt is worn out then it means motor can not pull the gears to enable opening and clossing of your cd tray
Sep 07, 2007 | Televison & Video
CD Drive not Ejecting properly
Hi, Since the warranty period has expired I will assume that the CD/RW has been in use for some time. Normally a small belt powered by a motor drives a gear that slides the tray out. Sometimes this belt is loose, warped or plain cut. Replacing the belt should solve the problem. You have to open the CD and it is near the front just below the tray. In other instances, the grease on the toothed railing at the sides and/or underneath the tray gets gummed up, cleaning and repacking with new light grease should take care of that. Rarely (but still does happen), the motor itself burns up and replacement (if you can get the part) is in order. An interim fix is to push a small straightened metal paperclip at a small hole below the tray cover/lip and slightly push till the tray partially opens. You can then manually pull it out. Hope this be of some help/idea to you. Good luck and kind regards.
Aug 27, 2007 | Samsung (SH-W08AENB) DVD±RW Burner
Toshiba SD-V392 DVD Player/VCR Logo
1,111 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
