Question about Samsung TXJ2554 TV
SAMSUNG STANDARD TV SET
I have problem with my samsung tv., at first i heared a sound something like there's a popcorn inside my tv set.. but now, my tv has no more power at all.. please tell me what's going on my television and what is the cause of that sounds.. thanks..
    Problem Solver:
  • 12 Answers
Maybe you have a blown fuse,try to have a look first inside,if you have a blown fuse then replace it with the same rating,if it blows again replace your power regulator
Posted on Jan 13, 2009
My new tv house no sound
simple, if there is no audio cable connected to the ext audio jack going to surround sound, and it is a stand alone tv, just take it back to walmart, however, if you have connected the set for external audio you do need to tell the device in menu/system/audio and select the output type example LCM/ SPDIF/ or MPEG as well as speaker types small large or raw out to a surround reciever, i do know that sound bar devices connected to these sets have a bit of trouble working with these sets, however.......if the Tv is a standalone and nothing is connected to its audio out and sound is expected to come from tv onboard speakers, then, i would take it back to wallmart, however still sounds strange as when a sound card goes in these sets you will usually hear a high pitch screetching and whining almost identical to an old Short wave radio signal, if the speakers are totally silent i would try a factory reset first, or if your set is connected to internet try going through menu and doing an software update, if this fails seeing as it is new from walmart you say.....then as Samsung issue a standard 1 year warranty on this set you are entitled to a new ste, and do not let walmart convince you it is a problem between you and samsung now as they are the seller , they are responsible for replacing it and they deal with Samsung not you, this is shown in the goods and services act section 19, "If a product was purchased and not functioning as intended , the seller has the responsibility of replacing it" (ps Ebay also uses this policy worldwide as well) my recommendation is take it back to walmart, as when you turn on the set first start you should see the samsung splash logo and animation with sound at first run, if you did not hear this, then there is something faulty with its internal audio.
Aug 04, 2014 | Televison & Video
Symphonic TV has no sound unless I am playing games.
Could be something wrong with the tuner inside of the TV.
Oct 22, 2012 | Symphonic Televison & Video
When you turn on the TV it makes this buzzing sound like something is spinning inside the TV. After a while the TV cut off on its own. It has a new bulb in it.
check the fan that cools the bulb. if its rubbing something that would make the buzzing sound, and if its not cooling the bulb it will shut off when it over heats.
Sep 14, 2010 | Samsung DLP HL-P5663W 56" TV
I have a Samsung LE26B450C4 26-inch Widescreen HD
U set it on suround sound might help a litte.Best to buy a speakers system's like BOSE or Yama help the sound,modify the sound about 50% louder.If u are hard of hearing,best money ever spend for the BOSE sound sytem,it a dream system's.
Apr 14, 2010 | Televison & Video
Samsung TXN2668WHF Does not power on, blinking red light
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 10, 2009 | Samsung DynaFlat TXN2668WHF 26" TV
Sound but no picture
well if any i can say with out seeing it would be straight off my head 2 things
1 the bulb blew out
2 the input settings on remote were accidently pushed to another setting which the tv now has no picture
if you still get a menu from your remote on tv that means that some how you clicked a remote setting input if you dont get the menu then the bulb blew out
May 20, 2008 | Samsung TXP2675WH 26" TV
Duraband tv no sound
Your settings in your tv need to be moved off surround sound and set for standard dolby.
Mar 15, 2008 | Durabrand DWT1905 TV
Auto shut off
maybe it was on too long. or there is just something wrong inside of it.
Dec 31, 2007 | Sony FD Trinitron WEGA KV-30HS420 30" TV
RCA 35V432T Dead Set
Check for a high voltage power supply section of your TV set...
Especially in flyback transformer.Be careful to do so because the output voltage of the flyback transformer is almost thousand volts.
Oct 17, 2007 | RCA 35V432T 35" TV
Samsung TXJ2754 (27") DVD issues (Sound but no Picture)
Assuming you have picture on the TV when hooked up to cable, antenna or satellite I would take the DVD player to a friends house to see if it worked on their set (using your cables of course). If you can't get a picture on your TV no matter what, then it could be either the Jungle IC or EEPROM IC inside the set. Since it displays "No Video Signal" on the screen, that leaves out the High Voltage section of the TV. My main suspicion would be the video cable or settings on the DVD or TV.
Jan 02, 2007 | Samsung TXJ2754 27" TV
Samsung TXJ2554 TV Logo
90 people viewed this question
Henry  Thomas
Henry Thomas
