Question about Panasonic KX-T7730 Corded Phone
One tuoch dialing fail
I tried to sen one tuch diling but I lost my CO-1
How could I roll it back?
  • 30 Answers
Press program button, then press the CO-1 button, press 0 and 1 then store button.
Posted on Jul 24, 2008
How to make CO button back to its default on KX-T7730 ?
Press program
press the co button
press 0
press 1
press auto dial store button
Aug 05, 2014 | Panasonic KX-T7730 Corded Phone
Oxegen sensors how many on ford taurus"?
what size motor ? 4 cyl -you'll have 2 larger will have 4oxy sen
named as follows upper lower or bank 1 sen 1 or 2, bank 2 sen 1 or 2 your code reader will give you info
Aug 04, 2014 | 2002 Ford Taurus
Not spin drying clothes enough
IF YOU ARE YOUSING A MANUAL MACHINE WITH gentel / normal dile settings ,the problem would be the dial is stuck on gentle load and not selecting normal load spin ,[ Two things ]
1 the wire to the normal contact can be changed to the wire on the gentle contact and put the removed wire off the gentle contact on to the normal spin contact of the dial this will give full spin only if this fails replace the spin dry switch assembly
2 if a timer is involved then the timer will need to be changed [ new one fitted ] BE SURE THE POWER PLUG IS WHERE YOU CAN SEE IT [ AND NOT PLUGED INTO ANYTHING ]
IF
Mar 05, 2011 | Maytag PAV2300 Top Load Washer
HAVE LOST LINE 1 AND LINE 2 ON THE PHONE LINE 3&4 OK LINE 1 & 2 COMES UP NOT VALID
When you press PROGRAM 99 and the buttons where line 1 & 2 appear, it should say CO-01 and CO 02. If it doesn't dial 0 01 STORE and 0 02 STORE in those buttons. In a TD system, the lines have to appear in order for you to use them. They don't have to be 1:1, but it's the easiest.
(there's a Group CO button command to save buttons)
Carl
Mar 02, 2011 | Panasonic KX-T7431 Corded Phone
How do i password protect our copies?
you can protect your copier with user code protection just fallow theis steps 1. Press the User Tolls Button 2. Tuch the System Settings 3. Tuch the Keyoperator tools 4. Tuch the User code managment 5. make copier ON & tuch OK 6.Tuch Next and Tuch Addressbook Managment 7. Tuch new program 8. Tuch User Code 9. Enter the number your choise & Tuch the # 10. Tuch the function Eg. Copier & Tuch the OK and Exit the user tools - thanks
Oct 29, 2010 | Gestetner DSm745 Black and White Copier
Am I able to fax to multiple recipients with canon lc 2050p?
Yes. Here is a link to your Canon Laser Class 2050P fax machine's User Guide. Reference pages 5-1 through 5-28 for Speed Dialing, One-Tuoch Dialing, and Group Dialing. Speed Dialing must be set up before Group Dialing can be assigned. Group Dialing will accomplish the multiple recipients sending.
http://www.actcopiers.com/Manuals/Canon_Laser_Class_2050P_User_Manual.pdf
Dec 14, 2009 | Canon LaserClass 2050 Plain Paper Fax
We lost the manual for our 25982EE3-A and need to change to tone
From the Manual!
Tone/Pulse Dialing
NOTE: This setting may be made only with the base.
1. Press the menu/flash button until 41TONE 2PULSE shows in the display. 1TONE is the default.
2. Press the caller id (9 or :) button or the touch-tone pad to scroll to 1TONE or 2PULSE.
3. Press mute/menu to save. You will hear a confirmation tone.
Here is a copy of the manual.
http://www.home-electronics.net/ge/pc/IB/25982EE3_IB.pdf
Jan 16, 2009 | Uniden Cordless Phone
LinkSys SPA 2102
try this out
power on your linksys
then pick up the phone connected to that linksys
no dile tone required
dial ****
when it says configuration menu
type 73738#
if ask for password then nothing can help you buddy
and if it says press 1 to save then press 1 and your device is reset with factory default
Feb 05, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
Indesit washing machine
This turning of the dial signifies a fault.. Indesit machines are made this way.. The most likely cause of this is the pump filter is blocked but can be either your carbons on the motor ( the latter is very uncommon). Saying it is the filter then what do is remove the flap at the bottom front of the machine. unscrew the filter and thoroughly clean.. Then to reset the dial what you have to do is leave the door open; turn the dial to a black dot; then press the on and off bottom untill the red light flashes quickly.. then the dial is reset.. try out a wash and see if the problem reoccurs..if it does then you might need to get someone out
Dec 04, 2007 | Washing Machines
Panasonic KX-T7730 Corded Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
