Question about Goldstar KG6000R Window Air Conditioner
Trying to set air conditioner
I dont have an manual, my air conditioner comes on and shuts off after thrity- forty min. has went by. I need to know how to set the air conditioner so that afterthe room get to the temp. it will shut off then it will start back up when the temp. is higher.
  • 68 Answers
It shouldnt run for that long if it is sized right for the room in the first place. Does it not come back on after it runs for 30 to 40 mins?
sounds as though it is not the correct size for the room to me
Posted on May 02, 2009
Whats the right settings for the window air conditioner.
i operate my a/c's in summer at 72 to 74 degrees. in the winter at72 to76.
Jul 30, 2015 | Fedders AED24E7F Wall/Window Air...
Heat pump compressor wont come on in heat mode, works fine in cool mode, we get heat occaisionally for about 2 min, then the compressor shuts off. it is a fridgedaire window unit.
Try setting the thermostat at a normal heat setting. By raising the temperature too high the unit thinks that the heat pump won't be effective and go into strip heat mode.
Nov 17, 2013 | Frigidaire Energy Star Room Air...
Bryant heat pump with aux.heat,no blower,outside unit cycles for approx 3 min then shuts down and will repeat cycle in 3-4 no time will blower come on,tried setting fan to manual but no blower.
Chances are you have a bad capacitor or a bad fan motor, maybe a bad thermostat or thermostat connection. Your best bet without knowing what your doing would be to replace the capacitor( it is the part attached to the fan, bottom door, two wires coming out of it, silver). Even this requires some electrical know how. Turn off the power before you touch anything electrical. If that doesn't work then you should definitely call someone. Also a capacitor may be hard for you to buy in person without an account.
Good luck Hope this helps
Feb 10, 2011 | Heating & Cooling
I have a Dometic rooftop Air conditioner in my RV When I turn it to low medium or high the fan run the same speed and when I turn it to AC it will run for about 5 min then the fan will shut off but the...
Bad fan motor I suspect The windings are bad causing the motor to over heat sending the motor into thermal overload. would suggest the replacement of motor. Good Luck on repairs
Sep 14, 2009 | Dometic Rooftop RV Air Conditioner
The electricity went off this morning and now the air conditioner is blowing warm air and I don't hear the compressor coming on its a whirlpool window unit Thank You
turn the unit off for 5-10 mins. turn thermostat to coldest setting then turn unit back on. see if the compressor kicks on in a minute . it may need to reset itself.
Jul 30, 2009 | Whirlpool Heating & Cooling
Automatically shutting off after about 5 min
dose it have a thermostat if it dose that will turn it off
Jun 24, 2009 | Comfort-Aire PAD-91 Air Conditioner
My Air Conditioner does not get cold after I turned it off and turned it back on. I have now turned the themostat off about 20 mins ago
Air conditioners need a few mins to stabilize (the fluid in the lines) after they are shut off in the middle of operation. The comperssor will normally time out for several mins after it shuts off (or you shut it ofF) preventing it from coming back on within that time. So if you turn it off, and then right back on, you can expect warm air for several mins untill it times out.
Jun 17, 2009 | Honeywell Electronic Programmable...
Zoneline ptac
scrap the unit for alumimun and copper and buy a forty lol
Jul 10, 2008 | GE Zoneline AZ55H07D Air Conditioner
Coleman tsr mach 3 RV Air Conditioner
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $ you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know
May 20, 2008 | Coleman Mach 15 Air Conditioner
Goldstar KG6000R Window Air Conditioner Logo
224 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
