Question about HP LaserJet 4250n Printer
Hp lj 4250 printer
  • jeewa Jun 30, 2008
    60.02 error
HP LaserJet 4250n Printerclearing paper path Questions
If this continually displays then either you have an actual paper jam in the printer that you have not found yet or a flag is broken/sensor has failed. Make sure you check the paper path that runs from the tray behind the MP tray assembly.There is a sensor in there that can be damaged.
Dec 02, 2015 | HP LJ 4250 Printer
Need to perfrom nvram init on HP 4250
To initialize NVRAM, turn the printer power off. Remove any installed accessories (for example, a stapler/stacker). Turn the printer power on, and then hold down (SELECT button) when the memory count begins. Continue holding down until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds. Press (UP ARROW button). Press the PAUSE/RESUME button (LJ 4200/4300) or the MENU button (LJ 4250/4350). The display should show SKIP DISK LOAD. Press (UP ARROW button) until NVRAM INIT is highlighted. Press (SELECT button) the printer initializes NVRAM and then continues its power-on sequence.
Nov 07, 2012 | HP Laserjet 4250dn Network Laser Printer...
Yes, it is possible to be the problem. Most of the time you would replace the whole fixing unit, it could also be the paper feed rollers in the paper tray or the manual feed tray. Good Luck
Sep 04, 2012 | HP LJ 4250 Printer
Last lines on page printing squished
It is a problem with the drive train. It is not finishing the feed process. Or it could be the toner. Try replacing the cartridge and see if that helps.
Jul 07, 2010 | HP Office Equipment & Supplies
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
Hp lj 4250 tray 1 stoped feeding automatically.
Here is the info from the service manual about tray configuration.
The value corresponds to the media size that is currently loaded in tray 1. ANY: If both the type and size for tray 1 are set to ANY, the printer will pull media from tray 1 first if media is loaded in the tray. A size other than ANY: The printer does not pull from tray 1 unless the type or size of the print job matches the type or size loaded in this tray.
So set both the paper size and type on tray one to "ANY" and you should be good to go.
I hope this helps, if so please rate my solution.
I have the full service manual available for instant download for $6.95 if you are interested.
Corporate Computer
Jul 09, 2009 | Office Equipment & Supplies
While printin to hp lj 4250 printer i am getting following error subsystem: kernel error: illegalOperatorSequence operator: endchar position: 24
I'm guessing you have either the PostScript driver or the PCL6 driver (which is really flakey) installed. Try installing the PCL5e driver.
Dec 20, 2008 | HP LaserJet 4250n Printer
50 .2 Fuser Error in HP Laserjet 4100N
you need an maintenance kit 4100
ACC C8057A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8057-67901 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8058A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 220V, LJ 4100 LJ 4100 Series
Selected Item RG5-5069-000 See RG5-5069-090 Not Available 0
Alternate Item(s) RG5-5069-090 Fuser Film ***'y, 220V, LJ 4100 180.50 2
HP LJ 4100 Fuserkit RG5-5069 HP
Dec 11, 2008 | HP LaserJet 4100n Printer
Cannot print odd-sized envelope with 4250 LJ
I got to HP tech support, and they tell me that the envelope feeder is intended only for a few standard envelope sizes. If we're trying to use a different sized envelope, as in this case, it must be fed manually, and the feeder bin will not work. So that answers that. Thanks for the help, though.
Apr 29, 2008 | HP 4250 Monochrome LaserJet Printer
Error 60 02 on a HP LJ 4250DTN
printer error
The tray 2 lifter-motor is not functioning. 1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness
is full seated in its connector on the
dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver
assembly. See Tray 2 lifter-drive
5 Replace the dc controller PCA. See
Jan 10, 2008 | HP LaserJet 4250dtn Printer
HP LaserJet 4250n Printer Logo
239 people viewed this question
Ben Johnson
