Question about Dishwashers
Hello I recentley repaired a broken door latch on chef electronic diswasher the push button type not the rotary switch style. i had to disconnect the circuit board I wrote down the were the wires connected i have discovered that when I reconnected everything i had not got all the wires in the right place is there any way I can get a wiring diagram so I can connect the wires correctly thank you
    Genius:
  • 1,665 Answers
Unfortunately as i know it is difficult to find a wiring diagram. Better try an authorized service station where they may have similar appliances.
Posted on Jun 30, 2008
Car register doors as open, when they are all closed. Help
If it has the old style push button switches, one could be stuck or broken. If it uses sensors in the door latches, one of the sensors could have failed.
Aug 27, 2013 | 2002 Kia Rio
HOW TO USE THE SELF CLEANING OVEN
Remove the racks, pull the door latch from the left to right side and depending on exact controls either push the control panel button that says clean on a touch panel or select clean in both the selector switch and thermostat on rotary style controls ineither case be sure to remove racks since during the cclean process the chrome would be burnt off
Jul 18, 2011 | Tappan Kitchen Ranges
Rear passenger exterior door handle will not open door. it lifts up but will not activate latch.
You need to open door from inside, take off door panel and reconnect small plastic clip that attaches external door handle.
Mar 14, 2011 | 2005 GMC Envoy
I push start and my dishwaher wont turn on. I have checked the other buttons and they work. I also turned off my breaker to see if that will help and it still doesn't turn on,
either:
  1. something blocks the door from latching or closing. Check, if anything is stuck behind a dishrack. try reversing lower rack. check if the door aligns properly and dishwasher is installed correctly
  2. latch switch failed/latch mechanism is broken. Disconnect dishwasher from power. Disassemble door, check latch, check latch switches for continuity
  3. touch panel or control board (less likely) is failing. replace if none of the above is working for you.
Good luck,
Vlad
First Choice Appliance
Sep 14, 2010 | Magic Chef CDB1500AW 24 in Builtin...
My Magic Chef gas oven is giving me a readout of F9
Hello there:
this error code that you have is refering to the door latch/switch and the latch switch wiring assy.
F9 Door lock circuit Check wiring and test operation of door lock switch if the circuit is not working when tested it will have to be repaired or replaced but if it has found to be good than the door switch may be faulty and needs to be replaced and please let me know how this is going so i can help you out if needed ok
Best regards Michael
Feb 24, 2010 | Magic Chef Ovens
Dishwasher has power but will not start when start button is pushed
hi there,
if your dishwasher is recieving power and the circuit is controled by a switch,the swtich is faulty,check the swtich by multi tester if switch is defective replace the switch with new one.
check also the door if is tightly closed and latched.The diswasher will not operate until the latcht is prop[erly engagaed.to check this close and latch,closed and latch the door,holding the latch tightly inb place,then still pressing the latch closed, turn the control knob to the ON position.check if the dishwasher work,the latch is faulty and should be cleaned and tightened or replaced.best regard
Aug 09, 2009 | Dishwashers
MAGIC CHEF ELECTRIC DRYER DOESN'T WORK. WHEN I PUSH THE ON BUTTON, NOTHING HAPPENS. POWER SWITCH IS ON.
Hello dybarra_fami, first suspect is the door switch. Check the little button on the door & the switch it presses when you close the door. Merry Chrismas.
Dec 05, 2008 | Magic Chef CYE4000AWW Electric Dryer
MVP IV Microwave Model VM12AM-1
There are a series of switches in the door latch mechanism which are a safety interlock system. If the latch on the door is secure and not broken then it is in the latch mechanism itself. It is possible for the mechanism to come loose and stop the oven from working. The control panel will have to be removed and the mechanism adjusted for proper operation.
Alternately if the door hinges (screw in type) are not aligned properly then it can cause the same symptoms.
I am unable to locate your model in my reference, but there is usually one or two screws behind the grille that hold the control panel on if it is a vent hood style. If it is a cabinet style then the cabinet will have to be opened. Be sure to disconnect power at lease 1/2 hour before opening.
Jul 28, 2008 | Magic Chef Microwave Ovens
Can't turn on Magic Chef oven
check the door latch it must be opened completely if not then it will display DOOR if it is open all the way then checkthe switch on the latch assby for proper operation
Mar 26, 2007 | Magic Chef CGR3725 Gas Kitchen Range
Dishwashers Logo
111 people viewed this question
Top Dishwashers Experts
