Question about Carrier Heating & Cooling
In Dec 07 I had a complete Carrier AC/Gas Heating System installed in my home to replace my original system when my house was built in 1983.We upgraded the new system to 3-TON AC as the old AC was 2 and half ton. Since the new system was installed in the winter time it was not until the hot weather started in May that a problem arose. The first conclusion of the problem was that the coil was aligne incorrect the second was that we needed more air return so an addition vent was added. Now the third conclusion is that when we went from 2and half ton AC to 3 tons that my old duct system is not able to carry the addition output by the 3-ton unit. IS THIS CORRECT THAT I NEED TO HAVE A NEW DUCT SYSTEM INSTALLED. AS THE HEAT BUILDS UP INSIDE THE HOUSE AND INSIDE TEMP. GOES UP THE AC RUNS ALL THE TIME AND CANNOT CATCH WITH THE DESIRED TEMP- for example if we put a temp of 72, and inside temp goes up to 78, the unit cannot catch up and runs continously. IT IS NOT UNTIL THE EVENING HOURS THAT THE TEMPS EQUAL.
    Scholar:
  • 104 Answers
Air conditioning requires 400 cfm (cubic feet per minute) per ton of cooling so your old 2.5 ton system would have required 1000 cfm and your new 3 ton requires 1200 cfm. This is not a big change, but if your ductwork is too small it could cause problems. The best way to check to see if airflow is the problem is to check the temperature of the air going in to the system and then check it when it comes out. Take a temp reading with a reliable digital thermometer at the return grill ( the vent that is physically the closest to the furnace that is sucking air in). Then take a temperature reading at the vent that is physically closest to the furnace and that is blowing air out. The target range is for the air coming out to be 18-22 deg F colder that the air going in. If the air is coming out is more than 22 deg colder then there is not enough air moving through the system. If the air is coming out is less than 18 deg colder then the problem is with the system. Potential problems range from improper refrigerant charge or incorrect refrigerant metering to wrong coil/volume ratio which is essentially mis-matched equipment. It sounds to me like you have a company that doesn't really have much of a clue what they are doing. When the company I work for changes equipment in a house to a larger capacity, we always check the ductwork and do the math ahead of time to make sure that things will work rather that throwing things at problems later. Also, when you check your temps turn the system on and allow it to run for about 10-15 min first so that everything has a chance to stabilize and the ductwork has a chance to cool down.
Posted on Jun 30, 2008
  • Chris Lyon
    Chris Lyon Jul 04, 2008
    Dear zamorar98,
    I put alot of effort into the detail and accuacy of my solutions. I would appreciate it if you would rate my solution as Fix-Ya unless you fee that would be in appropriate. Please keep in mind while you are deciding on a rating that I am a technician that normally deals with these issues "in person" when I am the one who can check the system out and evaluate the problem.
    Thank You,
    Chillmaster
How can i disconnect heater from a/c on a carrier 50ZP
The 50ZP Air Conditioners are one-piece, air-to-air units designed for installation on residential, manufactured housing, and commercial applications. The units are factory assembled, wired and charged for use as a complete heating and cooling system. Get a refund.
Apr 27, 2014 | Heating & Cooling
Tip
Gas Condensing Boiler High Efficiency Heating
Ultra high efficiency boilers have become one of the best buys in home heating. These high efficiency boilers have changed dramatically from the first pulse boilers that I had the privilege of installing twenty years ago. Today’s condensing boilers are much more reliable and will not shake and rattle the windows of your house like those old beasts did.
If you are looking to purchase or install a new boiler for your new or existing heating system then you need to look a condensing boiler to heat your home with. In the past twenty years the condensing gas boiler has evolved to be a reliable, very efficient way to heat your home.
Radiant heating systems with the right design feature can easily heat your home at temperatures that use just warm water. At these temperatures the water is pulling the exhaust temperature of the boiler to very low points. This gives you extremely efficient boiler operation.
The boilers of today are made to operate continually at temperatures of 100F or less. At these temperatures it is not uncommon to have the combustion analyzer give me readings of 98-99 % efficiency. To get these types of readings and still heat your home the heating system has to be designed to work at these temperatures.
The right condensing gas boiler coupled with the right heat transfer system to get the heat into your home the right way will give you the most efficient heating system possible with today’s technologies.
Do a bit of research and find a heating contractor that knows exactly how to install a condensing boiler with a radiant heating system properly. For your radiant heating system to perform well at these temperatures, your boiler will need to be installed in exactly the right way. There is not a lot of room for error when designing very high efficiency heating systems. To wring every BTU of heat out of the fuel that is being burnt means that you are also on the ragged edge of supplying just enough heat to the building to over come the heat loss of the building at any given time.
http://www.fixya.com/support/r3706364-gas_boiler_condensing_best_features
http://www.fixya.com/support/r3597748-the_extra_benefit_of_a_modulating_boiler
http://www.fixya.com/support/r3583943-condensing_gas_boilers__the_best_radiant
on Dec 24, 2009 | Heating & Cooling
Tip
Condensing Gas Boilers - The Best Radiant Heat Boiler
The right condensing gas boiler coupled with the right heat transfer system to get the heat into your home the right way will give you the most efficient heating system possible with today’s technologies. There are a few things that need to be taken into consideration for this combination to work well and serve you well.
For this type of heating system to work you first need to have a radiant heat system that will supply enough BTU’s to your home at very low water temperatures. By low I mean under 100F. To get the output that you need at this low a temperature you of ten will need to design the radiant heat system with heat transfer plates. The heat transfer plates will make the transfer of the heat from the tubing that the water flows in to the floor as efficient as possible. Getting the floor warm enough to heat your house with low water temperatures should be the goal.
Now that you have a great heat transfer system you can set up your boiler to run at very low temperatures also. Most of today’s condensing boilers use out door reset technology to assist in keeping the water temperature just high enough to help the heat transfer plates produce just enough heat to keep you warm. On the coldest day of the year you want your water temperature to be no more than 100F and still be keeping your house to the temperature that you want it to be.
A great high efficiency heating system coupled with a good high quality condensing gas boiler will give the best in comfort, quiet heating at the lowest cost possible. Sure this type of system will have a bit higher upfront cost. And the contractor that you hire to install this type of heating system may require a higher rate to perform the work, But once you experience the comfort and efficiency of a top notch heating system like this you will soon forget the money and enjoy your nice warm comfortable home.
on Dec 06, 2009 | Heating & Cooling
83 sedan deville ac
A/C SYSTEM OIL TYPE 1983 Cadillac Seville 4.1L TBI 8cyl The A/C System Oil Type
SEE NOTE Ask about A/C repair & diagnostics DVDAll vehicles originally equipped with R-12 Freonwill require a complete system flush,draining comp A/C SYSTEM OIL CAPACITY 1983 Cadillac Seville 4.1L TBI 8cyl The A/C System Oil Capacity 6.00 Ounces
ressor oil & ultimatelyretro-fitting the vehicle to R-134A refrigerantand the compatible polyalkylene glycol (PAG) oil.
Jun 27, 2012 | 1983 Cadillac DeVille
I BOUGHT A USED HOME APPROXIMATELY 1000 SQ. FT. IT
quantity of gas alone does not make for cold air
to understand that it is necessary to understand how an air conditioner or fridge works ( ac, car ac , fridges , freezers etc all work on the same principle)
Simply put it is a heat transfer device where the heat of a room is transferred to outside the room
IT does this by allowing an extremely volatile liquid to evaporate ( being boiled off by heat in the room)
the gas is then collected by a compressor and recompressed back to a liquid
this process releases the heat back outside by the condenser and so the process is repeated until the amount of heat in the room reaches the temp set at the thermostat
Basic I know but it is sufficient to know that there is more than gas at work
if the compressor is inefficient ( worn , faulty etc) it cannot compress the gas properly and so instead of releasing liquid at the evaporator , it will be releasing gas which is not boiling off and removing heat
next is the thermostat
it controls the TX valve that regulates the amount of liquid that is allowed to enter the evaporator to collect the heat to be removed
next there is the condenser
if the fan is not working it will not remove the heat from that unit and so the compressor cannot do the job as it goes into over pressure and shuts down
Good advice is to get a second opinion from an accredited service technician, preferably a carrier service technician that has the technical knowledge of the make to be able to properly diagnose and test each component of the system
every system is repairable if the parts are available but the deciding factor is the repair cost against the energy saving costs and parts availability of a new unit so get quotes and then decide the action to take
Mar 01, 2017 | Heating & Cooling
My wipers stop half way when I turn them off, sometimes they stop working all together.
Built into the wiper motor is a control switch. It will be the little black box sitting on top of the wiper motor assembly. My memory fails me to weather the control can be replaced separate from the motor or the system is a complete unit. You parts house will know for sure.
Feb 22, 2010 | 1983 Chevrolet Silverado
I want to upgade from my old water tank to a tankless water system. I have underfloor heating and it has 4 zones but i run it as one zone and it is controlled from a therm ostat that controlls a pump.I...
what you have is called a hydronic heating system.
this heating system is completely isolated from your water heater I believe this as most hydronic systems I have installed circulate water through the furnace to heat the house. If this is true you need only to connect your old water heater cold water supply side to the tankless and, old hot water side to the house system: the showers/tubs/sinks etc. in your home.
my appologies if I have missunderstood your inquiry.
Jan 26, 2010 | Rinnai Digital Remote Water Heater Control...
Heating & Cooling Logo
137 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
