Question about AT&T Blackberry Curve 8300 Smartphone
I have a blackberry curve and am wanting to pair my bluetooth HS850 to it. Please help!
  • 57 Answers
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Posted on Sep 22, 2009
  • 14 Answers
Posted on Aug 22, 2009
    Sergeant:
    Champion:
  • 223 Answers
Make sure your bluetooth is enabled on your blackberry. Turn on your HS850 and make sure it is in pairing mode. Then go into your bluetooth setupo on your curve and look for mobile devices.
Posted on Jun 17, 2009
    Sniper:
  • 69 Answers
There actually is a trick to the HS850 - flip the boom closed, then hold down the button just until the light holds solid - IMMEDIATELY after it does flip the boom open and this should keep the light solid. Then on your cell/device search for bluetooth devices - you should be able to find it now. Passkey for most devices is 0000.
Posted on May 27, 2009
SOURCE:
Passkey for bluetooth?
most bluetooth earpiece pass keys are 0000 or 000000. Hold the device power button down until the lights flash two colors, then locate device with the blackberry. Enter either of the two codes and see which works. Normally you can not change the code on the earpiece, but you can on the phones.
Jul 24, 2009 | Motorola Mobility H700 Wireless Headset
Blackberry Curve 8330 can not find my bluetooth headset
Turn the 360 off.
Then turn Bluetooth off, then back on the Curve.
Then turn the 360 back on, input the code when asked to due so.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 23, 2009 | RIM BlackBerry Curve 8310 Smartphone
Won't pair with Motorola HS850 headset
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
I can't find my instruction book for the Motorola Headset HS850.
Just google the instructions. Should get a pdf option to download ??
Nov 07, 2017 | Motorola Mobility Universal Wireless...
Motorola hs850 bluetooth headset won't pair with Blackberry Curve
try to delete it out of ur phone all the way and then try to pair it again
Dec 15, 2008 | Motorola Mobility HS850 Consumer Headset
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Can't get the HS850 to pair with my blackberry
Device is not bad blackberry has a compatibilty issue with this headset try plantronics brand go to www.n1wireless.com
Jan 08, 2008 | Motorola Mobility HS850 Consumer Headset
My bluetooth passkey
Passkey 0000 worked for pairing my Motorola HS850 and my Blackberry 8800. Thanks!
Dec 12, 2007 | Motorola Mobility HS850 Consumer Headset
AT&T Blackberry Curve 8300 Smartphone Logo
597 people viewed this question
Top AT&T Computers & Internet Experts
Vincent_G
Vincent_G
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
