3 year old Mitsubish 52" DLP mdl.WD-52627 TV displays all "Red" colors as Brown-Grey in color. Going to the color level menu and maxing out the Red color bar does no good. Also intensifying the color level strength to "max" color does no good. Screen is mostly Blues, Browns, Greens & Yellows. I have changed the DLP lamp. Is there a "light color gun" or color amplifier in the set that has gone bad? Thanks, Bill.
  • randalle Dec 09, 2008
    We are having the same problem on our Mitsubishi - did you ever find out what it could be?
Found out I have extended warranty and I am awaiting service company to respond in order to conduct service to find the problem.
Thank You
Posted on Jul 01, 2008
I need to know what the various colored wires connect to since I needed to remove the old amp and install an after market stereo.
Check the speakers connection and that should give you at least 8 of the colors. The ones left then are going to be ground and power and display power. You can figure those out with a meter.
Aug 24, 2015 | 1994 Volvo 940
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
WD-60638 DLP TV does not have any red
It would have come with a 1 year labor and parts warranty--now is the time to see to the issue---Talk to Mitsubishi if you do not have a extended warranty that is active.
Nov 03, 2012 | Mitsubishi Televison & Video
Mitsubishi wd-52627 dlp hdtv doesn't appaer as
I have seen alot of the Mitsubishi DLPs to get very dim and the colors appear dull and the cause was almost always caused by the small front mirror needing to be cleaned due to a dust build up. If you need assistance with how to access the mirror on that model send me a email and I will send you info on how to access the mirror. The file is too large to post here. slinteriors@yahoo.com
Jun 07, 2011 | Mitsubishi Televison & Video
Color is off, very red green have auto corrected and also tried manual color adjustment. still not correct mitsubishi wd 52627televison
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Mitsubishi WD-52627 52" Television
No display or sound on Mitsubishi WD-52725
This is a DLP They have issues with the color wheel, the winding sound could be from this color wheel. If it stops spinning it will cause the tv to shut down. DLP is a mechanical display process. If you are handy and understand electronics you could replace this yourself. If not i would let a tech handle it.
Sep 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Faded color display
replace the colorwheel.
Jan 27, 2009 | Eiki EIP-3500 DLP Projector
Wd 52525 52 in dlp tv screen needs cleaned
all you have to do is, take the 12 screws out from around the screen, from the back, there are also like 4 of them on the front, but usually , you can just lean the screen out far enough to use a swifer sweeper in there, and the dust isnt going to be on the back of the screen, it will be on the projecter, do the screen while the tv is on, then you will realy see the dust on the projecter
Jan 07, 2009 | Mitsubishi WD-52627 52" Television
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Dec 28, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
