Question about Video Game Consoles & Games
My xbox360 has 3 flashing red and will not respond to anything except turning the unit on off and opening and shutting
  • 36 Answers
Turn off xbox, unplug the av cord from back of xbox.. power up unit without av cord.. wait til unit shuts off by itself.. reattach the av cord and turn it on..
Posted on Jun 30, 2008
How to program remote
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Aug 19, 2012 | Televison & Video
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
Turn camera on, lens goes in and out then camera shuts off
You may try resetting the Camera to the original factory settings.
If the issue persists then service will be required.
Aug 27, 2009 | Panasonic Lumix® DMC-FS3 Digital Camera
The door does not respond when using the remote inside the car
If the main light flashes 10 times when the door reverses it is a door sensor problem. Look at the LED just to the left of all those white wires and see if it is flashing a code. It will flash a number of times and then pause if it is sending a code. If the code is 5 then you have a bad RPM sensor board which is just in front of the motor. Also try increasing the down force just a bit. This control is on the rear of the motor unit.
Jul 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
CX235 will not play, select Cd, open door or respond in general
The select and play mechanism has failed, perhaps due to a stretched or failed drive belt. This a common failure of Sony "jukeboxes".
May 07, 2017 | Sony Audio Players & Recorders
Xerox XL592DS Flashing Colors, Nothing on Screen
Sorry time for a new monitor you might open it up and look at the capacitors and see if any need to be replaced the bad ones will be domed on top normal is completely flat
Jun 19, 2008 | Xerox XL592DS (Silver) 19 in. Flat Panel...
Planar PDP42BK Plasma TV
It is the power supply. Replace the C97, C19, and C16 Capacitors with 2.2 uF ones.
Jul 10, 2007 | Planar PDP-42BK 42 in. Plasma HDTV
Nikon SB-29s macro speedlight
Trigger coil or a flash tube. Flash tube is easier to replace so try to replace that first. Caution before you do anything else when you open the unit locate the main 330v capacitor and discharge it before you work on the unit !
Mar 22, 2007 | Nikon Speedlight SB-600 TTL Flash
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
