Every time i turn on my RCA tv the picture go's verical i hear and see the picture but it goes so fast verticly it used to go verically but then go to normal now it stays that way i found to switches in the back of the tv but i dont wanna touch them i dont wanna make it worse.
    President:
  • 357 Answers
Hi there
Try replacing the electrolytic capacitors in the power supply section. I started with replacing (2) 860uf 180v caps just after the bridge rectifier and continued along the circuit. Some (15) or so capacitors later,it finally cleared the the horizontal bars and lines and the high pitched noise. It also fixed another intermediate problem of no video, when turning on the power.
Here is a picture of what they look like:
Thank you for using FixYa. Have a nice day and please remember to rate this solution as FixYa if it helps you.
Thanks
Dustin Ellse (BearWeb)
Posted on Jun 30, 2008
What is the problem with my Plasma tv, it has a black verical box with a yellow and blue line inside?
Contact the nearest authorized service center for Samsung. This is not a user repairable fault.
Aug 29, 2012 | Samsung PN42A400 42 in. Plasma TV
I replaced a new motherboard for my television. (sanyo crt tv motherboard 29"). Now pictures are upside down. how can I solve it.
hi,
do on thing revere the polarity of vertical yoke connection. just see the picture bellow for verical connections. inter change the wire of vertical coil.
Jan 19, 2011 | Televison & Video
I got the problem for my Panasonic 21 TV (CRT type) where's Vertical line across picture tube when the brighness adjust high. The vertical I.C already changing. Any solution > Thank you
Hello
Have you recently replaced its Line Output Transformer [LOT]?. If so have you replaced it with same type and number? Verical bars are due to LOT to Deflection Yoke mismatching. It is known as "Yoke Rigging" technically. Replacing the vertical Ic won't help in this problem . If you have replaced the LOT, the replaced one is not orginal. Ok
Oct 31, 2010 | Panasonic Televison & Video
The unit is only vertical line appearing in the screen,i check all the component around the vertical ic but no component defective
Tapping all around PCB for coldsolers?U resolder the vertical the IC and all the components around the IC?Still have the same reseult.Replacded the verical IC.
Sep 21, 2010 | Sanyo DS19310 19" TV
No Picture
It sounds like the veritcal ic has failed, and./or a cap in the verical circuit, When replacing the vertical ic, always check for a fuse resistor near the ic, it could be blowen aswell.
Sep 01, 2009 | Televison & Video
ROLLING PICTURE HATACHI
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
SAMSUNG HCM4216W has a verical line
the vertical line has nothing to do with the picture tube,Some component in the horizontal circuit is causing that problem,most likely an electrolytic capacitor
Dec 07, 2007 | Samsung HCM4216W 42" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
