Question about Dell W4200 42 in. HD-Ready Plasma Television
2 horizontal bands of negtative image
I have a W4200HD. I am getting 2 bands of distrotion (negative image), one at the top 1/2 of the screen and the other in the bottom 1/2. It's worse at the bottom of the band and get better going up. when the image is neutral the negative images is worst. For quite some time if you turn the tv off then try and turn it back on you have to unplug it for a few seconds. this problem happened right after doing that. I have the TV open but don't have a lot of expereince with electrons. Certainly seems easy to replace boards. Can anyone tell me which board is bad?
Thanks a bunch, David Henderson
    Sergeant:
  • 243 Answers
Ok this is the part that most likely needs replacement its the main logic board. not to much to replace yourself.
Posted on Jun 30, 2008
  • Nathan Ayers
    Nathan Ayers Jun 30, 2008
    Inspect all the boards identify if anything else may be damaged and replace them from this list here.
    let me know if you have any questions or need anything else answered.
    hope this helps thanks,
    Nathan
    President:
  • 357 Answers
Hi there
Try replacing the electrolytic capacitors in the power supply section. I started with replacing (2) 860uf 180v caps just after the bridge rectifier and continued along the circuit. Some (15) or so capacitors later,it finally cleared the the horizontal bars and lines and the high pitched noise. It also fixed another intermediate problem of no video, when turning on the power.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as FixYa if it helps you.
Thanks
Dustin Ellse (BearWeb)
What is causing interpolated image shifting on my Sony KDL-403000 LCD TV? It has wide vertical bands of horizontal lines that are shifted parts of the displayed image, only occurring on the sides.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 10, 2017 | Sony Televison & Video
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Samsung ln52a650a1fxza LCD has horizontal band of dark lines across screen
check connections on top of screen this is becoming a stockfault on samsung tvs
Dec 01, 2012 | Televison & Video
Samsung L830 digital camera Has horizontal bands across still images past 1 month this is 2 year old camera
Sounds like you have a faulty LCD, or the backlight in the LCD has failed.
Check eBay for a replacement screen.
Please remember to rate my solution to show your appreciation!
May 31, 2011 | Samsung Digimax L830 Digital Camera
My zenith lcd tv has horizontal black lines whih form a band about 3 inches wide across the screen, sometimes the band looks more like a dark shadow than lines other times the right side of the screen...
This is either 1 of 2 things, first it could be faulty panel tabs , in this case, there is nothing you can do and is unrepairable....2) you could take the back off the tv and you will see 2 ribbons going from your t-con board to the panel tabs (top center of tv) remove them carefully and reseat them. This is a common problem. Tv repair tech 15 years! Best of luck.
Dec 05, 2017 | Zenith Televison & Video
Dark horizontal band at top of Sony KDF - 46E 2000 TV
rca ps2720lv blue is very dim any suggestions
Nov 14, 2009 | Sony Televison & Video
Ps 27123 have sound, tuning etc only small horizontal color band
Hello bdedrick708,
If what you are trying to say is that you have a 1/4 inch horizontal line across your screen, this means that something in your vertical deflection circuit has failed. This could be the vertical oscillator, the vertical output processor, the vertical coupling capacitor, or the vertical section of the yoke transformer.
If what you are talking about is a vertical line from top to bottom then you are possibly talking about a failed horizontal section of the yoke transformer.
Why so little about the horizontal section of the yoke? That is because if the horizontal section fails completely then you would lose high voltage and no line would be present because you would not have raster (screen light).
In any even check the yoke transformer first. Then work back from there.
I hope this helps,
Thank you,
Shuttle83
llc.com/">http://www.electron-age-technologies-llc.com
Feb 07, 2009 | Proscan PS27123 TV
19" Samsung Monitor Image size function, distroted
Yes, this can be reset by pulling up your video card utility window. this should be located on the right hand side of the task bar. it should be a background utility. Just reset all settings to default in the video res tab...
Jan 28, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Dell W4200 42 in. HD-Ready Plasma Television Logo
115 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
