Question about Gateway FPD2275W LCD Monitor
Kepps going to sleep
When i turn my computer on it keeps shuuting down snd it says going to sllep on the monitor. please ley me know what the problem might be,
thanks,
christine
  • ladyelizabet Jul 02, 2008
    i can't get my computer to stay on long enough to go to the apperances area!
  • manishbvashi Jul 15, 2008
    Same here. As soon as, the computer is turned on there is a message about about not seeing an input and "Monitor is going to sleep". I have checked the connections several times to no avail.
  • 39 Answers
Your setting in the screen saver has been set to shut down go to control panel then appearances and theme select screen saver you shoul see where the computer is set you can change it
Posted on Jun 30, 2008
Monitor keeps going into sleep mode
try a different monitor / tv (some have pc hookups) and see if it really is your monitor or your PC not providing a signal
Sep 02, 2014 | Compaq Computers & Internet
No vga input/dvi input monitor going to sleep. irksome! can somebody give the appropriate solution. tns.
When i turn my computer on my monitor keeps saying no vga input and no dvi input then the monitor says going to sleep ..........PLEASE HELP ME!!!
Feb 10, 2011 | HP w1907 LCD Monitor
My Hp A6252D monitor keep turning to sleep by showing the message ' monitor is going to sleep' before it was turned off, but processor was still running. Sometimes, it hang and i hear noise from CPU. May i...
in power set up in control panel,there are setting for the computer and monitor,the setting is { shut down after 5mins,10 mins or never click never.and it should stay on
Jul 07, 2010 | HP W19b LCD Monitor
Monitor does awake from sleep mode
You need to check the inverter fuse, transistors, caps, solder joints. Please see my pictures here to get some ideas so you will know what to look for inside.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Please post back.
Replacement board: http://www.lcdrepair.us
Apr 27, 2010 | Dell E173FP 17" LCD Monitor
Won't turn on... keeps "going to sleep"
Try another monitor on the computer, if it works properly then you know that the original monitor is the issue.
If the 2nd monitor gives you the same issue then you know its a problem with the computer. At that point, unseat and reseat the memory. Try another power supply. If the monitor still shows sleep mode then the motherboard in the computer is bad.
Dec 17, 2009 | Compaq FP 5017 15" Flat Panel LCD Monitor
Appears to be stuck in sllep mode, sr2020nx
unplug computer if necessary. Can also hold the power button in until it shuts off. Then you might want to to turn hibernation off in your power settings in your control panel.
Oct 25, 2009 | HP Compaq Presario SR2020NX PC Desktop
My computer keep shuting saying monitor going to
start button >settings >control panel > Power Option > set time for monitor to sleep if inactive...if you dont want the computer to sleep go up to the hibernate tab and uncheck it. If you want the computer to stay on regardless, move all drop down menus to "never" instead of a time.
Sep 01, 2009 | HP w1907 LCD Monitor
The video goes to sleep.. and I can only get it back by powering down and back again.,.,..what a pain..???
Hi there.
Go to the control panel, select power options and set the computer to never go to sleep, all the options and quick links are down the left hand side in Vista.
Good luck and thanks for using FixYa!!
Mar 11, 2009 | Dell OptiPlex GX280 PC Desktop
Hp vs17e monitor says it's in sleep mode then goes blank
If you are running Windows Vista,do the following,
  1. Click start,Control panel,
  2. Double click Power options,
  3. On the left menu bar,Click Change when the computer sleeps,Change "turn off the display" to never,
  4. Go down to the botton and select "Change advance power settings,
  5. Scroll down to Display and click the + symbol,
  6. Click the + symbol beside "Turn off display after" change to never,
  7. Click on the next plug + symbol beside Adaptive display and change to off (You may or may not have the adaptive setting)
  8. Click apply ,click ok,
  9. Restart your computer.
If you are running windows Xp
  1. Right click on an open area on the desktop
  2. Click properties
  3. click the screen saver tab
  4. Click the power button at the bottom
  5. Change the "Turn off monitor settings"To Never
  6. Retart computer
if this doesn't fix your problem,please let me know
Please rate this a fixya
Feb 02, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Works when it wants to then turns whie with grey line in it
Hi
If only the monitor is going to sleep, then it could be a problem with the connection from the monitor to the computer or with the cable.
If the computer goes to sleep and if you are not able to wake it from sleep then check the sleep mode settings and also the power management settings for the keyboard and mouse.
You may also do a system restore if you are not able to wake the computer from sleep.
Feb 24, 2008 | Sony SDM-HS73P 17" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
122 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
