No vertical scan
Hi Robotek,
Does the info that I just added about working OK after being off point more likely to the vertical IC, the various capacitors, or the yoke connection?
What exactly did you mean by dry jointed? Did you mean that some of the solder connections might be cracked or have flux buildup?
  • msternx Jul 02, 2008
    Hi Robotek,
    In response to your July 2nd comment, I have not been able to
    see any of your comments since June 30 th.
    Also, there is something wrong with the rating system, because
    I had clicked the rating "helpful", not "thanks for trying".
    I would still like to see your latest comments.
    The last entry in the string that I can see is from Maklean,
    who provided a most useful piece of info---the site to
    download the TV service manual.
  • msternx Jul 09, 2008
    Hi Robotek,
    Your info has been great. Because I have been out of town
    on business, I haven't been able to get at the circuit board.
    I will get back to you with the results shortly.
  • 1,512 Answers
Yes, it is likely that it is dry jointed,as Premtech described, a ring like crack about the joint where it solders down to the printed circuit. They are generally pretty obvious. There is generally no flux on modern PCB's If you cannot solder,then this may pose a problem. What are your skills like with an iron in hand? :)
Posted on Jun 30, 2008
  • 2 more comments
  • Graeme Ross
    Graeme Ross Jul 02, 2008
    I have posted some more information to the original post.Are you still able to see it here
    I notice that your rating of my solution is thanks for trying, you have indicated that you would like to proceed with my guidance, a change to FixYa on that post is then appropriate. Cheers
    robotek
  • Graeme Ross
    Graeme Ross Jul 04, 2008
    I will repost to here. I have the service manual for you also, but a free version. I have cut and pasted my efforts into here. Sorry bout that. Didn't know you couldn't see the post still.
    yes, the fault may be marginal.
    Capacitors are a likely cause of this condition also. I generally just
    rebuild the area, clean old heatsink paste away, and use new compound.
    I use 2% silver content solder for its better heat stress strength
    Comment by robotek, posted on Jun 30, 2008
    DON'T FORGET - DANGEROUS VOLTAGES ARE PRESENT
    even with power disconnected !!! Be sure to Work electrically safe.
    Comment by robotek, posted on Jun 30, 2008If
    the problem comes and goes however, it is probably more likely to be
    dry joints. Start with resoldering first, then if it does not improve
    capacitors and vertical IC would be my call
    Here is another repair method relaying the same message about the verticle IC by one of our Top Experts, Premtech
    it's most likely the the vertical IC an
    LA7847-E has probably become ring-cracked at the point where the pins
    are soldered to the pc board.
    Depending on how long it has been
    allowed to arc the IC may have failed also, but they are not terribly
    expensive or difficult to repair - at least not here in the shop.
    The
    main board has to be removed. Locate the vertical IC - it will be
    mounted to a metal heat sink and the IC will be stamped LA7847. Then
    turn the board over and inspect where the pins are soldered to the foil
    side of the board. One or more will look ring cracked or fractured all
    the way around the pin. At this point you have two options, carefully
    reflow solder over each pin and put it back together or replace the IC
    by de-soldering it and removing it from it's heatsink. remember to use
    a good heat sink grease when applying the new IC.. There should also be
    a couple of caps in pretty close proximity to that IC... One should be
    about 50v/100uf and in the shop here we test em all... You might also
    just replace that one for good measure - they're not expensive either...
    Comment by robotek, posted on Jun 30, 2008it
    can be said that there are many ways to skin a cat, there is only one
    way to skin this one. The solutions given relating to the verticle
    output IC are correct. I hope that the extra solution I provided from
    Premtech helps clear that up. Cheers
    Comment by robotek, posted on Jun 30, 2008@midwest. the LA1460 is a low power dip chip... not a vertical output chip. What part of the circuit are you looking at?
    no
    problem glad to be of help. The chasis generally slide into rails on
    the front section, and also into the rear casing. It is not hard to
    manouver it about to get access to the verticlechip. They slide out and
    with not much "unhooking" of loom dress, you can turn the chassis over.
    Will post back to here tommorrow. Cheers
    regards
    robotek
    Comment by robotek, posted on Jul 01, 2008
    ----When the picture becomes a horizontal line, I can get the picture back by turning off the TV and
    turning back on after several minutes. It will then operate for 5 to 10 minutes before failing....
    Sounds
    like you are talking about an intermittent fault. This is classic
    behaviour for heat stressed dry/cracked solder joints about the
    VerticalOutput chip. The chip may even be desoldering itself from
    overheating in the first place, the conditions promoting the
    overheating being caused by failing overheated, vented out caps mounted
    near the heatsink.
    Have you got to the chassis yet?
    Comment by robotek, posted on Jul 01, 2008To help a little with the repair provess, I have found a link so you can download the service manual for the 32DF46.
    Is the 32 inch version of the set you have, but same chassis i believe.
    The LA7847 comes up for both models, so the vertical circuit will be
    relatively the same. It is marked as IC401,and is towards the center of
    the main board near the flyback (eht) transforme.
  • Graeme Ross
    So download the manual. and do some sight checks with your chassis to see if they are indeed the same. Then you have a reference point that we can work from together :)
  • Graeme Ross
    Graeme Ross Jul 05, 2008
    How did you get on with the set? :)
Sir i have sansui leader 500 main iv no tda 12135 Vertical ic ok vertical not open
Check and replace the vertical scan output IC. Check related capacitors, and solder terminals at the vertical scan output section circuit for any loose soldering. Check the voltages at the vertical scan output IC. Refer its circuit diagram [schematic] for more details. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 03, 2015 | Sansui Televison & Video
AKAI Colour Television CT-1419A/AT plus AKAI remote RC-V9A. Television was fine, then went to just a narrow, bright horizontal band across the screen but sound is fine. Suspect my son played with the...
hi,
Its not problem with any setting. Its an internal fault. Vertical scanning output stage has failed in your tv. You have to check the soldering of the vrtical output ic if there is any dry soldering this can happen. try to resoder all the points in the vrtical output stage. IF doesn't help then you have to change the vertical output ic. Have added the picture of the dry soldering point how it looks like. If you need further assistance feel free to contact throug FixYa.
Aug 20, 2011 | Akai Televison & Video
Horizontal line
hi,
ur tv has problem with vertical scanning section. may be dry soldering or vertical output ic faulty.
u can easily find out the vertical section on ur tv. for that u have to open ur tv. u can see a coil is fitted on the picture tube neck. there are four lines coming from the neck, of which two will go to horizontal scanning section and the remaining two will go to vertical section. follow the two thin wire normally in color green and yellow. it will go to a socket in the main board. trace the track from that socket in the main board . it will lead u to the vertical scanning section. check for any dry soldering in that section. mainly the soldering of vertical ic. if see or not re-solder the leads of the vertical ic . then check is the tv is ok or not. if complaint remains replace the vertical scanning out pout ic. it will be fitted on a aluminum heat sink in the vertical section. if u need more assistance feel free to contact through fixya.
regards
Ajin
Apr 11, 2011 | JVC AV-20020 20" TV
No picture. Just a thin horizontal band of light running through the center of TV.
HI,
Your tv has problem with its vertical scanning side. vertical scanning output ic (integrated circuit ) may have some problem ( faulty or dry soldering in its leads). You can easily find out the vertical ic on your tv. there will be four wire coming from the coil which is fitted on the picture tube neck, of which 2 will goto horizontal scanning section and the remaining two will go to vertical scanning section. just follow the two thin wire (normally in color green and yellow ). it will goto a socket on the main board. follow the track on the board. it will lead u to vertical scanning section. check for any dry soldering, if not , replace the ic.
ok
Mar 07, 2011 | Mitsubishi CK-35308 35" TV
Bkit yong tv ko my horizontal line sa screen nya ano ang dapat kung gawin dto
hi,
if u can understand English do the following
ur tv has problem with its vertical scanning side. vertical scanning output ic (integrated circuit ) may have some problem ( faulty or dry soldering in its leads). u can easily find out the vertical ic on ur tv. there will be four wire coming from the coil which is fitted on the picture tube neck, of which 2 will goto horizontal scanning section and the remaining two will go to vertical scanning section. just follow the two thin wire (normally in color green and yellow ). it will goto a socket on the main board. follow the track on the board. it will lead u to vertical scanning section. check for any dry soldering, if not , replace the ic.
ok
Jan 28, 2011 | Daewoo DTQ-13P2FC 13" TV
The bottom portion of my screen is double vision witht the colors red and green only
p { margin-bottom: 0.21cm; }
hi,
check for any dry soldering in that section. mainly the soldering of vertical ic. if see or not re-solder the leads of the vertical ic . then check is the tv is ok or not. if complaint remains replace the vertical scanning out pout ic. it will be fitted on a aluminum heat sink in the vertical section. u can see the heat sink on which the ic is mounted in the picture ( in side the small green circle). if u need more assistance feel free to contact through fixya.
regards
Ajin
Jan 05, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Horizonal lines across the screen.
hi,
u can easily findout the vertical section on ur tv. for that u have to open ur tv. u can see a coil is fitted on the picture tube neck. there are four lines coming from the neck, of which two will goto horizontal scanning section and the remaining two will go to vertical section. follow the two thin wire normally in color green and yellow. it will go to a socket in the main board. trace the track from that socket in the main board . it will lead u to the vertical scanning section. check for any dry soldering in that section. mainly the soldering of vertical ic. if see or not re-solder the leads of the vertical ic . then check is the tv is ok or not. if complaint remains replace the vertical scanning out pout ic. it will be fitted on a aluminum heat sink in the vertical section. if u need more assistance feel free to contact through fixya.
regards
Ajin
Jan 05, 2011 | Daewoo DTQ-27S5FC 27" TV
I have sony triniton tv when i was turn on there is horizontal line on the center of screen this problem was never happen before
HI,
ok
Jan 04, 2011 | Sony KV-35S42 35" TV
There is a horizontal line in the mid
Hello
The vertical scan of your TV has failed. All picture tube type TVs have both horizontal and vertical scan sections to scan the picture on the secreen. When horizontal scan fails, you will see a vertical line at the middle of the screen, and if vertical scan fails, there will be a horizontal line through the middle of the screen. In your TV, the second stated has happened.
This may be due to an IC trouble or a voltage loss inside the printed circuit board of your TV. To rectify this fault you have to open your TV, and locate the vertical output section inside it. It is very easy to locate that section. There will be four wires goes from the deflection yoke; the coil fitted at the neck of the picture tube; out ot which, two will be thick and the other two will be thin. The thick wires are usually colour coded as red and blue. Colour coding may differ from set to set. Anyway you have to follow the tow thin wires, as they are carrying vertical scan signal to the yoke.
Following it, you will reach to a plug in point on the printed circuit board. Upside down the printed circuit board, and follow the track through which that wire connection goes, and finally you will reach to the vertical output section.
There may be transistors or IC used on that section. First check the voltage at the vertical output section. Voltage lose also may occur in this section. If it uses IC, check for any loose or bad solderings at the terminals of the IC. I advice you to resoder the suspected points by applying a little more solder, without shorting the terminals. In most cases this will solve the problem. If there is voltage, and there is no loose solderings and still the fault perists, replace the IC or transistors, whatever it may be, with same type and number.
If you want anymore asistance, fee free to contact me through Fixya. OK.
Dec 27, 2010 | Toshiba CF30F40 30" TV
Picture has been reduced to a thin line in center of set sound and remote functions still work
Hello
Your TVs vertical output section has the trouble. All TVs have both vertical and horizontal scanning sections, which scans the picuture on the secreen both vertically and horizontally, to get a picture frame. If horizontal scan fails, you will see a vertical line at the middle of the screen, and if vertical scan fails, there will be a horizontal line across the middle of the screen. Your TV has the second stated trouble. To get it rectified, you have to open your Tv.
Unplug your TV from mains socket and open it. Locate the vertical output section. It is so easy to locate. Your TVs picture tube neck id fitted a coil alongwith it, which is called the deflection yoke, and it will have four wire connections. Out of these four wires, two of them will be thick, usually red and blue in colour, and the other twos will be thin. Just follow the two thin wires, you will reach to a point that these four wires are plughed onto a pin connection, on the main printed circuit board.
Upside down the board, and trace the track to which these two thin wires goes, through the print side, will reach to the vertical output section.
Normally this section consists of an IC for this purpose, and can be screwed onto a metal heatsink, as it will get heated when it works. Before unsodering it , just look at the soldering points of this IC pins for any loose soldering points. Loose soldering are very difficult to locate, as thay will be very minute up to microns, so resolder all the pins of this Ic, by applying a little more solder, and see the effect. Sometimes this will resolve the problem. If not go tho the main input voltage that goes to Ic pin. If it is not there, check out the reason. If it is there and still vertcal scanning does not occur, resolder out the IC from the circuit board, and go for a same type and number.
If you wants anymore asistance, feel free to contact me through Fixya. OK.
Dec 08, 2010 | Insignia NS-RTV32 32" TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
