Question about Kenmore Oasis HE 27082 Top Load Washer
Musty smell I've noticed a musty smell when I open the top of my Kenmore Oasis. We just ran the cleaning mode with bleach, but I'm afraid it may just mask the problem, if there is one.
  • 1 more comment
  • smmdavis Jul 01, 2008
    So far, cleaning the machine has helped a great deal, but I'm hanging on to the instructions for finding 'lost' clothes, thanks!
  • Toby Norton
    Toby Norton May 11, 2010
    Have you made sure there is nothing trapped between your basket and yout tub? If a clothing item gets tossed up in there, it can mold and mildew without being drained out. here the front panel and the top of the machine meet, there is a crack. When using a flashlight, you will see 4 items in this crack. 2 are green 2 are black. The black pieces are support studs, ignore them. The green one's are clips that hold the top to the front. Using a putty knife (easier) or a small flat head screw driver (a bit more difficult) push one of the green clips towards the rear of the machine while lifting on the top (warning they are very stiff). You can wrap the tool in a light cloth to help protect the finish, althought it may make the clips more difficult to remove. Only lift slightly (too far and it will bind on those support studs I told you about) Now press the clip on the other side and lift the top up.(now this is easier if you have a second person to hold up the lid while you work underneath. You will see your tub from a new perspective. First you will see a plastic ring around the top of the tub. Disconnect the green clamp on the hose towards the left
    rear using a pair of pliers or channel locks. The ring is held down with clips all of the way around the tub. By pressing down over each clip and pulling the clips slightly forward, you can remove the top ring. The rest is the easiest part. In the center of the basket, there is a small cap. Remove this with a small flat head
    screwdriver. Remove the bolt (7/16") that is underneath the cap. Now lift the whole basket out. If your small items get too far (ie, the pump), remove the back panel. On the left hand side you will see a small black hose towards the botom. This connects to
    the pump. Forign objects can lodge in here keeping it from draining also. If you disconnect the hoses, have something handy for all of the water to go into (large wet vac is usually the best). Drop the 3 #20 torx screws and the pump will come down
    and you can remove the obstructions.
  • Anonymous Mar 20, 2014
    has a very musty smell when you open the top
  • 246 Answers
Great, I'll flag this one as ok. If you have anymore problems, we'll be here.
Posted on Jul 01, 2008
There is a musty smell in the maytag washer even b4 I fill it with water, I've disconneted the hoses & flushed with bleach that did not take care of it,Iv'e run washes without clothes in it...
When a moldy or musty smell develops in a washing machine, many times the smell is coming from the open areas of the agitator. Water along with soap and/or liquid softener sometimes splashes into an open agitator, and when the lid is closed it does not dry out. Instead, mold begins to form, and a musty smell wafts from inside the machine, even after the lid has been opened for an extended period of time. Until the mold is removed the washing machine will continue to smell bad, even if it is used and allowed to air dry with the lid open.The tub can also be the source of the smell. Lint can gather and collect in the holes, and when it does not dry fast enough it ends up smelling musty and moldy. Even the top of the rim can become moldy and musty, but proper cleaning can get rid of the odor.
So that said.To clean the machine,fill to just above the top row of holes in the tub.Add 2 cups of bleach.Let sit for 1-2 hours.Then let the machine run it`s wash cycle.Lastly use bleach water and a rag to wipe the machine down inside and out.If the agitator has a cup on top remove and clean with bleach.Leave the top open so the machine can dry.
Now it should smell better,if so use as normal,and leave the lid open when not in use.
May 15, 2011 | Maytag Washing Machines
My clothes have a musty smell after being washed
run a wash load (no clothes) with 2 cups of Clorox brand bleach and use hot water, that should help.
Nov 13, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Our dishwasher developed a musty smell. The smell
I would use bleach and then rinse and then air dry.
Nov 13, 2009 | Dishwashers
Musty Smell
spray motor and gear housing surrounding with insecticide, roaches may be nesting there that gives out the foul odor
May 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer smells musty
there could be buildup in the outer tub causing some water to stay trapped and causing the smell, try running some loads uning Ahfresh or you can try pouring lots of bleach in there and letting it sit a while, then run it throu a cycle.
Feb 12, 2009 | Kenmore 23822 Top Load Washer
Kenmore Series 70 has musty smell and sounds like water inside
The water will always be in there. It is in between the basket and the drum. That is normal. However if you want to get rid of the musty smell there is a good tip that I have. You can find this on my profile too. Just take about a cup of white vinegar and put it in the drum and wash on hot heavy load. This will clean the tub and all hoses as well. You can do this every few months or even every month if you do a lot of laundry. Put some vinegar into the bleach dispenser too and the fabric softener area as well. This way you will clean everything. It is much cheaper then going out and buying that expensive cleaner made for washing machines. Let me know if you have any other questions and if this was helpful. Good luck and have a great weekend.
Jan 24, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite front-load
you must remove bottom panel ,,in the center front you will find pump,,remove pump filter,,always unplug has slugg,..than after you clean filter run your unit once a month with a pint of bleach and hot water only..also wipe your rubber gasket or bellows with a touch of bleach..
Dec 27, 2008 | Kenmore Elite 45986 Front Load Washer
Clothes smell musty
The big door seal is probably the problem. Put on gloves and using a solution of Laundry detregent and hot water and rags, carefully wipe clean all the folds of the seal. It will be icky. Next run a cycle with some detergent and oxyclean or bleach if you have it.
Especially during warm weather, damp clothing left in a front loader mildew slightly very quickly- you can't really see much but you can smell it! So get the clothes in to the dryer immediately. You'll want to relaunder the smelly clothing after you have cleaned the washer.
Good luck to you and Thank You using FiX YA!
Aug 19, 2008 | Kenmore 43052 Front Load Washer
Musty smell
probaly a good wash with chlorine bleach..fill tub with hot water pour 2-3 cups bleach let agitate for few mins stop machine and let set 20-30 mins restart and let finish cycle head of future problem leave lid open between uses
May 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Smells of mildew and so do clothes
Hi! I have Kenmore Elite 4t and had this same problem: Musty, Moldy smell in washer and on clothes. The Sears Technician suggested that I use a half a cup of Clorox Liquid Bleach and put it in the tub (not the dispenser). NO CLOTHES! Use the longest hottest setting and when it's done clean the inside (underneath rubber tire thingie) and the undernath part of the door with a papertowel. And to always leave the door open. I did what he said with the bleach and it worked. I didn't want to leave the door open because I have 2 cats & was afraid that they would want to go in it, but ended up repeating the bleach thing again because a few days later the horrible smell was back. I leave the door open all the time now and the cats never go in it. They've watched laundry spin around, so I guess they're smart enough to not want to go in it. I have not had this problem again since I always leave the door open and I did this over a month ago. I hope this helps!
Jan 10, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
240 people viewed this question
Sal De
 Brian Main
Brian Main
