Question about Yahoo YDP-700 Portable DVD Player
Toshiba SD-1600 dvd player disk error
I have a Toshiba SD-1600 DVD player and when i put the disk in all it does is load forever only to tell me disk error with every disk i put into it,even new ones. i believe it has something to do with possibly the motor that spins the disk im not entirely sure
  • khaled_tsi Aug 13, 2008
    i bought SD-1850sa 6 years before and i did not use from the same period , just 2 days ago i bought an excellent multi super woover speakers and some new CDs , when i try to load my cds on that SD-1850sa it gives me "disk error" i wrote some thing about code or number to e entered in it, any one can help me on that or tell my where cn i found that code on the manual book or on the DVD or what can i do....
    NOte: the spin machine gives higher sound than i heared before when i bought it !!!!!!
    did it mean that the spining machine of the cds broke down?????
  • Anonymous Nov 28, 2008
    same problem as 1st report with d-r410
5 Suggested Answers
SOURCE: what does "pcb on" means when displayed on a DVD player screen and it won't play VCD burned on a laptop
CAN SOMEONE HELP ME FIND THE CODES FOR A DVD PLAYER YDP-530 YAHOO. I HAVE A ONE FOR ALL UNIVERSAL REMOTE. I HAVE THE CODE LIST BUT THIS DVD PLAYER IS NOT LISTED. IVE TRIED AUTO SEARCH, AND RANDOM CODES CANNOT GET IT TO WORK . I CAN PROGRAM THIS REMOTE FOR OTHER COMPONENTS BUT NOT THIS DVD PLAYER. THE DVD PLAYER IS A 2005. IF ANYONE CAN HELP ME THANKS IN ADVANCE . HANEY111
Posted on May 08, 2008
jaffa012001
  • 376 Answers
SOURCE: un lock toshiba dvd sd-370 ekb
http://www.avforums.com/forums/showthread.php?t=508285
go down page until you see the download from here there are 2 file follow instuctions and it will work
Posted on Sep 09, 2008
  • 3422 Answers
SOURCE: Toshiba DVD player says every DVD is a bad disk
HI,
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.see if the player tries to read the disc. Load a disc and listen.
Posted on Feb 10, 2009
BobbyR1234
  • 173 Answers
SOURCE: Toshiba Portable DVD will not spin upon start up
If the disc does not spin it will cause the optical reader to not read the disc, which will give you the "no disc" or "invalid disc" error. If a disc will not spin, the most common cause of this is due to a spindle motor malfunction. The good news is that it can be fixed on average of between $70-90 dollars depending on what service repair technicians charge in your local area. You can fix the problem yourself if you have the patience and a bit of knowledge, but I can tell you from first hand experience it is a pain to do this.
The pictures below provide you an idea of what you are looking at.
I hope this helps give you an idea of what the problem is and helps you solve the issue.
If you would not mind, please rate my help. I would greatly appreciate it. Thank you.
Posted on Feb 07, 2010
I have a toshiba modelsd-p1850sn model it goes on
possibly needs both the disk and the laser iris cleaned. Buy a cleaning kit for about $15 and run the disk in the drive to clean the iris.
please rate my help++++Thanks for using Fixya
Nov 29, 2009 | Toshiba SD-P2000 Portable DVD Player
Get Disc Error on display when loading a disk
you have problem with EPEROM IC you have to bring your set to toshiba repair center and they give a new program to your set . the program of your set is defected must be repaied
Mar 13, 2009 | Toshiba SD-3990 DVD Player
Toshiba sd-4990 dvd player will not load a disk
Your toshiba is not spinning that's why it keeps on saying loading. Unplug the dvd Open the device,once open plugin the dvd and put the dvd cleaner in the player. take your finger on the top where the dvd disk is and spin the disk. What happening is that you are cleaning the len. keep spinning until it spin on its own.Put the toshiba top back on and clean again. It should clean on it's on. Now you can play your dvd. Clean your dvd on a regular basic.
Mar 12, 2009 | Televison & Video
TOSHIBA SD-1600 WILL NOT PLAY DVD+R RECORDIBLE DISC.
wer i can find the model of the toshiba dynabook video driver?
Dec 22, 2008 | Toshiba SD-1600
Disk Error
You can not fix this problem because the player does not read dvd recordable disks
Sorry!
Dec 18, 2008 | Toshiba SD-2700 DVD Player
Toshiba dvd player - SD-1200
Its actually in the troubleshooting manual. Pg 126. Try putting in the disk with the label face up, that might work too,
regards
Jim
Dec 22, 2007 | Toshiba SD-1200 DVD Player
Toshiba SD 4800 dvd player
I've had the same symptoms on the last two Sony DVD's that I've rented. I managed to get around this by hitting one of the menu buttons after the loading message stopped.
Aug 07, 2007 | Toshiba SD-4800 DVD Player
Toshiba disc error
Check formatted disc see if it's +R,-R and see if Toshiba will play homemade disk or just disc recorded in different format.
Jun 25, 2007 | Philips DVP642 DVD Player
Yahoo YDP-700 Portable DVD Player Logo
518 people viewed this question
Top Yahoo Televison & Video Experts
Henry  Thomas
Henry Thomas
Craig Butler
Craig Butler
richie46
Are you a Yahoo Televison and Video Expert? Answer questions, earn points and help others
