Question about Canon Office Equipment & Supplies
Canon multipass F80 printer ....check printer press resume message...will not print anything...help
  • 39 Answers
Try cancel and then print
Posted on Jun 30, 2008
My multiPass F80 alarm is flashing a check printer press resume key code and I not able to clear it this happened after I stopped it in the middle of a fax mode
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Dec 02, 2010 | Canon MultiPASS F80 All-In-One InkJet...
Canon f80 multipass New five years ago never
Are you using Windows Vista or Windows 7? If so, the driver download page at Canon does not provide drivers beyond XP. Otherwise, go back to the XP (or earlier versions) driver downlaod site and download the MultiPASS F80 Software User's Guide. That may provide the answer to your problem. Also, if you are using unpopular, proprietary software programs the driver may not recognize the commands. Good Luck!
Apr 26, 2010 | Canon MultiPASS F80 All-In-One InkJet...
Check Printer and Press resume key message along with Alarm light
Too many things can cause that, paper jams, carriage errors, printhead problems, purge assembly errors, feed roller errors, need more info to be of any help.
Aug 12, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Canon Multipass F80 printer. "Check printer press resume key"
On the f80 you need a shop to go to service mode and get the error code and tell you what the problem is. Could be purge assembly, waste ink full, feeder error, printhead error, any number of possible problems.
Aug 05, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Check Printer Press Resume
try a new print head part # QY6-0041-010 I had the same thing happen I replaced it and it works fine I even swaped the ink from the old one to the new one
Jan 28, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Cannon multipass f80
Hi,I would suggest you to first trying unplugging/ switching off your device for 5 minutes. This restores and refreshes the device. Go for it
Let me know if this works, if it doesn’t then I’ll provide some other alternative solution.
Thanks
Dec 10, 2008 | Canon MultiPASS F80 All-In-One InkJet...
Problem with Canon MultiPASS F80
On the right side of the print cartridge carriage there are two small felt ink pads. When they fill with ink somehow the machine detects it. Mine started with the flashing light and check printer error code and then progressed to a nasty grinding sound everytime I hit resume or tried to reset the counter. I thought all was lost, but kept trying. I found two pads, one square and one rectangular. They aren't very spongy but they are full of ink. They are only about an inch across. I got them out without taking the printer apart and repeatedly soaked them in a little water until the water was clear, then I let them dry and replaced them in the little trays where they came from. I cleaned the plastic fins that were nearby and coated with ink with a Qtip and rubbing alcohol. And I removed the print head and cleaned the muck of ink on the connectors with a Qtip and rubbing alcohol. Much to my suprise, after all of this the damn thing worked fine again when I plugged it back in.
Apr 14, 2008 | Canon MultiPASS F80 All-In-One InkJet...
Check Printer Press Resume button
When your printing? thats the problem? Remove the USB cable then turn off the printer, then turn on it again and plug in the USB cable on the USB port. See what will happen?
Feb 28, 2008 | Canon MultiPASS F80 All-In-One InkJet...
Alarm light on. F80
This worked for me on an F60 and someone else on an F30. Re: Check Printer error message on Canon MultiPass by watsonk (6/7/05 11:16 PM) reply + / - It could be due to "waste tank full" alarm; you may need to reset the waste tank counter. I found a reset sequence for a MP730 printer in this website that works for F30 as well. Try: Resetting the Waste Ink Volume Counter 1) Enter SERVICE MODE.--- By pressing Menu-Copy-# 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [OK] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key. Skip step (6) since there is no [OK] key on F30 printers.
Sep 29, 2007 | Canon MultiPASS F80 All-In-One InkJet...
62 people viewed this question
old marine
old marine
