Unit does not power up
The unit sparks when the power cord is connected, but that's all it does.
  • larry1948 Jul 05, 2008
    The proposal that I replace the power cable seems too simple, without any basis. After all, I don't know whether the problem is outside the unit or not. It would be a fine solution if I could somehow first narrow down the problem with some diagnostic or other that shows me it's likely a problem with the cable.
  • 6,487 Answers
1. Switch off unit and unlpug AC cord from outlet.
2. Press and hold the DIRECT and STEREO buttons, whilst simultaneously plugging in the AC cord.
3. Check that the display is flashing with an interval of about 1 second, and release your fingers from the two buttons and the microprocesor will be initialized.
Check also the power adapter if its possible replace it..
Hope that helps.........
Posted on Jun 30, 2008
  • 92 Answers
Try replacing the power cable. and you might want to make sure it didn't short circuit when it sparked.
Kenmore stacked laundry unit. when it was plugged in sparks flew and small parts of the heating element fell and the power cord is ow black. can we replace cord and be ok
Heating element must be replacedas well as the cord. Make sure the drum screws were not screwed into anything electrical.
May 18, 2013 | Kenmore Dryers
HOW DO I GET MY HP JET 4500 OUT OF power Save Mode in order to print a document from my computer?
Perform a Power Cycle on the unit by following the steps below:
  1. Turn the unit off.
  2. Unplug the power cord from the unit.
  3. Wait 30 seconds, and then re-connect the power cord to the unit.
  4. Turn the unit on.
Oct 28, 2010 | Computers & Internet
Touch screen wont work
Try the following to bring the touch screen backto life.
Step 1:
Do a power flee by unplugging the power cord from the rear of the printer and holding down the power button for 30 seconds.
If the above doesn't resolve the concern, then try the step 2.
Step 2:
Perform a Full Reset of the HP Photosmart ,
-Press the On button to turn off the unit.
-Disconnect the power cord from the back of the unit.
-Disconnect the power cord from the AC outlet.
-Connect the power cord to the back of the unit.
-Connect the power cord to the AC outlet.
-Press the On button to turn on the unit.
If the touch screen has not gone bad,the above troubleshooting steps should resolve the issue.
Thanks and regards,
Techbuddy247
Jun 10, 2010 | HP Photosmart D7260 Printer
I just refilled my ink cartridges and for some reason the printer still flashes no ink, any ideas?
  1. Press the On (c00636182.gif ) button to turn off the unit.
  2. Disconnect the power cord from the back of the unit.
  3. Connect the power cord to the back of the unit.
  4. Press the On (c00636182.gif ) button to turn on the unit.and hold it down 10 se
this are the usual procedure..some do it by actually power off ..disconnect power cord..hold down the button ..and connect power cord with the button pressed..and after it powers..release the button ..try it both way s..the issue is that you probably used refilled cartridges and it needs to reset the counters..
Jun 02, 2010 | HP DeskJet F380 All-In-One Printer
The power cord is split near the base unit
There are 2 screws on each side of the top cover of the Rainbow ‘E’ series vacuum cleaners located behind the decal windows. To get to the screws; use a non-scratching tool such as a plastic putty knife and pry out a corner of the plastic window, carefully pull out the plastic window and decal and remove the 2 screws. Repeat this process for both windows and then just lift up the top cover to expose the inside.
May 15, 2010 | Rainbow E series Canister Wet/Dry Vacuum
All the lights on the buttons flashing with error message
Please perform the following steps:
* Take the cartridges out of the unit. Dis connect the unit from the computer.
* Unplug the power cord from the back of the unit.
* Press OK and Cancel buttons together while connecting the power cord back to the unit.
* Now turn on the unit and verify the result.
:) Dr Tony
May 12, 2010 | HP Officejet 5610 All-In-One InkJet...
My printer is showing error oxdo5do1od recycle power how can i over come that
Step 1: Power Cycle
1. “Shutdown” your computer.
2. Verify that the unit is switched ‘on’.Unplug the all-in-one from power and ‘disconnect’ the connection port.
3. Wait 30 seconds.
4. Plug-in only the ‘power cord’.
5. Repeat steps 2-4 two more times.
6. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
7. Restart your computer and check the functionality.
Step 2: Partial reset:
1. Unplug the power cord from the unit.
2. Press and hold # and 3 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit
If the issue persists, perform the following:
Step 3: Semi ful reset:
2. Press and hold # and 6 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit.
If the issue persists, pleae conect the unit to a diffrent power out let. Also please chek if the unit works fine in the stand alone mode (with out connecting to the computer). If the issue persists, replace the printer
:) Dr Tony
Apr 19, 2010 | HP Officejet 5610 All-In-One InkJet...
Power cord bad connection to unit
Hello :
I think you have a problem with the charging jack . For that you need to call Garmin or get your device serviced .
please rate !
Apr 15, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
I also have HP 6310xi all in one printer with power reset message
1. Please make sure that the power adapter is working properly. Also connect the unit to a different power outlet and verify.
If the issue persists, please perform the following steps:
Step 1: Power Reset:
1. Disconnect the unit from the computer. Verify that the unit is switched ‘on’. Unplug the power cord from the back of the unit.
2. Wait 30 seconds.
3. Plug-in only the ‘power cord’.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
If the issue persists, perform the following steps:
1. Take the cartridges out of the unit. Unplug the power cord from the unit.
3. Turn on the unit and insert the cartridges.
This will solve the problem...
Jun 23, 2009 | HP Officejet 6310 All-In-One InkJet...
Unit trips circuit breaker when plugged in
On AC current it really makes no difference to the operation of the unit which terminal the wires are connected to as long as the circuit is completed. A reason for the inverted wiring is that there will be a resistance between the hot wire and the control circuit. It makes for a reduced load on the contacts and switches minimizing arching.
Jun 08, 2008 | Maytag Portable Air Conditioner M6P09S2A
 Grubhead
Grubhead
