Question about Yamaha DSP-A1000 5-Channel Amplifier
When acellerating the bike and then let off 0n the gas to change gears the engine continues to rev and very slowly decreases in rpm[which could take as long as 1 to 2 minutes].From what I can gather it needs a vacuum line to the air cut valve, but where in HELL is that valve.Thanks Bert
  • 1,512 Answers
Hi Bert
What model scooter you playing with. I am sure I can find some info for you, just need somewhere to start. :)
robotek
Posted on Jul 18, 2008
Rpm high after starting the engine of R15 v.2
It sounds as if a throttle cable or choke cable is either sticking or badly routed . Most bikes rev high at cold start then the revs should decrease as the engine warms up. I would check the throttle and choke cables first make sure they lubricated and operate smoothly and especially with the throttle cable if you open it slowly does it return immediately you take your hand away. It should almost snap shut. I would also check out the pilot air screw in the carb these get clogged with debris from the petrol over time. Before you take the pilot air screw out turn it clockwise into the carb and note how many turns it takes until it stops (do not over tighten this screw) be very gentle when you do this. Check your user manual to see if the turns in you found match the turns out in the manual. Also make sure the tick over (idle) adjuster screw is set correctly your bike should idle at approx 1,200 to 1,300 RPM when hot. My Yamaha 125 is 1,300 RPM my Suzy 650 about the same.
Jan 09, 2015 | Yamaha Motorcycles
I have an 03 Jeep Grand Cherokee v6 2x2 with 170k... I'm having a couple of issues... 1. Occasionally will have trouble with cycling through gears when getting on Hwy causing decreased, sluggish...
I would consider changing the vehicle speed sensor. When they go bad, they can really throw out a lot of bad data to the computer, resulting in unexpected behavior like you're experiencing. They're only around $20-$25. I hope this helps! :)
May 02, 2014 | Cars & Trucks
How adjust the carburator???
Be careful while doing this
1. Pull out the air pipe between the carb and the head. You will see that a rubber pipe is fitted to carb insulator. Pull it out.There will be a brass pipe. Close it with your finger. If you do not close it your bike will not idle.
2. Now set the mixture screw to 1.5 turns out.
3. Now start the bike. Be sure to close the air injection at carb insulator with thumb of your left hand.
4. Now increase the idle by idle screw to 2000 rpm.
5. Now slowly turn out the screw. I repeat very slowly.
6. You will see the idling rising. continue until maximum idling is obtained. Beyond a point idle will not increase at all and instead decrease. At the point where idle is highest stop turning the screw.
7. You will see your idling is highest and also the rpm needle is constant.
8. Now decrease the idle to 1.2k. stop the engine.
9. Now remove your finger from carb insulator and connect the air injection pipe.
10. restart engine and check idle.
Oct 24, 2013 | 2011 Hero Honda CBZ Xtreme
Why my bike head light brightness is decrease when the operate the clutch
whats battery like, the engine gives out different power at different revs. the battery should compensate for this,
Feb 20, 2013 | 2009 Bajaj XCD 125 DTSSi
How many rpms should i go on my honda cbr 600
hi,i dont know a lot about this particular bike,but,as with any high revving sports bike you will need to keep the revs up before changing gear,an 883 sportster has a lot more torque than your bike and you can "short shift "them and let the torque do the work,however on a cbr i think you will need more rpm before you shift as they dont have the torque of your old harley,a friend of mine has an r6 yamaha,that thing revs out to nearly 17000 rpm he doesnt change untill about 9 or 10000 rpm,from memory your bike should be capable of nearly 60mph in first gear..hope this helps...cheers
Mar 10, 2010 | 1997 Honda CBR 600 F(3)V
Vw polo maintains engine revs when foot is off the accelerator.
You need to check the cable the runs from the gas pedal to the engine, it might be rusty and need some drops of penetrating oil at the point it meets with the engine accelerator valve.
Feb 11, 2010 | 2007 Volkswagen Golf
REVS TOO HIGH WHEN COLD...........
High RPM is by purpose. Reason is to get engine hot as quickly as possible to reduce emissions. There is nothing to worry about. I am sure if engine is warm/hot then you wont see high RPM even if you resart it.
Dec 15, 2008 | 2002 Toyota Corolla
Yamaha DSP-A1000 5-Channel Amplifier Logo
47 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
