Question about Mitsubishi WS-65613 65" Rear Projection HDTV
We had thunder storms my tv 65613 has a green blinking light wont star
Tv wont work wont come on
  • 927 Answers
Good Day,mikeybecerra; TV wont come on mb try these 6 items, please pay attention to the blinking light (it's a code) : 1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). LED stops blinking after 70 seconds of plug in but will not power on. 5. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 6. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001. Good Luck, big IRISH.
Posted on Jul 17, 2008
Can't turn on the TV. Green light keeps blinking.
You need to change the four capacitors C9B01,C9B02,C9B10,C9B11 all 1000 MFD 16 VOLT (on the DM board which is inside the metal shield standing upright on the left looking from the back of the set)The tops of the capacitors will look puffed out making them easy to find. This is your HD tuner digital board which is trying to reboot but can't - when the green light stops blinking after a minute,than you can power on your TV.
Aug 26, 2007 | Mitsubishi WS-65613 65" Rear Projection...
My JVC AV-48WP55 only blinks the green led when plugged in. This happened after a power surge, during a thunder storm.
Have you tried unplugging the tv and letting it sit for a while then plugging it back in?
also.. sometimes i have seen appliances that will flash the power light if an internal fuse has blown to indicate a problem. open it up if you feel you want to and check for a fuse around where the power cord comes in teh tv.
Nov 18, 2009 | JVC Televison & Video
Mitsubishi WS-65613 tv green power light keeps blinking tv will not turn on
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using
SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
Sep 11, 2009 | Mitsubishi WS-65613 65" Rear Projection...
Green (power on) light continuously blinking/set won't turn on
This set was designed in such a way that when it is unplugged and plugged back in the LED will blink for around 90 seconds and then stop. During that time you cannot turn the set on. This is the amount of time it takes for the Digital Module to boot up. These units have a problem with some capacitors going bad in the Digital Module and when that happens the LED never stops blinking. You need to contact a qualified repair shop to get it repaired. I have repaired many and the cost is around $250 to $350 depending on where you live. That set is well worth the repair cost.
Jun 02, 2009 | Mitsubishi WS-65613 65" Rear Projection...
Green blinking light and tv would turn on
blinking light is an error code. Check the manual for it's meaning.
Aug 14, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Mits 65" wont power on
set could have a short and be in shut-down mode ...making just a blinking green light on the front.
remember your standby circuit is always on waiting for a remote command and can be damaged by surges in the line from storms.
please add a surge protector in future after you found the failure.
May 11, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
I can't turn on the TV.
I had the same problem. Unplugged it, reset it, everything. I went to work the next morning and left the light blinking, came home from work and it was off. I turned it on and so far, so good. Just give it some time to reset internally
Mitsubishi WS-65613 65" Rear Projection HDTV Logo
134 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
