Question about RCA OPAL M4001 MP3 Player
Rca M4008A I got mine a while back and was working just fine, until i got a new laptop, i plugged it to the laptop and it says driver is malfuctioned. So I plugged it in to my old computer and it says the same thing, so I cant charge it or use it or anything :( What the heck do I do?
  • j_dog51890 Jun 30, 2008
    That didnt work, i did it for well over 10 minutes and no New Hardware Wizard came up.
    Thank you!
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jun 30, 2008
  • Corey Knoettgen
    Corey Knoettgen Jun 30, 2008
    When you plugged the RCA into the new computer, a reformatting occurred. You can try reloading the original firmware from RCA's website, but that is the only other suggestion I can think of.
My playstion 3 has no display or sound after disconnection hdmi connection and going back to rca connection, worked fine until then any ideas, it comes on but no sound or video thanks jamie
u will have restart ur ps3 mine has done this before i just restart and it automatically switches back to rca it does this when hdmi is plugged in also this is all from my 60gb im sure its the same all the way around
Apr 24, 2010 | Sony Playstation 3 (PS3) Console
Need driver for rca opal m4008a
go to that website
http://support.rcaaudiovideo.com/select.aspx?u=downloads
choose your mp3 player it doesn't matter if the a is not after the m4008
download the software auto updater
hope it works
Jun 17, 2009 | RCA OPAL M4001 MP3 Player
Rca opal m4008a
The solution is to reset your firmware.
You can get this directly from the RCA website at
http://download.rcaaudiovideo.com/downloads/OPAL_4GB_8GB_FWUtility_v1.2.8.0.exe
Or you can try to fix your problem using someone else's files for your player.
You need to set your computer to view hidden files for this--the firmware on your player uses hidden files like this. I don't have those files handy--you may try searching online forums for onther m4008a users.
Good Luck!
--Bitscience
Aug 06, 2008 | RCA M4008 MP3 Player
RCA OPAL M4008 MP3
Mine has the same problem too, it says boot error, I format the unit, nothing happens. Dang!
May 29, 2008 | RCA OPAL M4001 MP3 Player
Hung in a transfer loop after being removed from PC
When I (USB) plug in my RCA Opal M4002A mp3 player into my "Office PC" it works fine, but when I plug it into my "Studio PC" the "Opal" screen shows "USB connected" and so does the "PC" with the "Device Connected Sound" but then the "Mouse Pointer" changes to the "Hour Glass" you hear the "System Notification Sound" then the "Mouse Pointer" changes back to the default "Arrow Pointer" and this back and forth action loops endlessly until I unplug it. I've tried everything. Any ideas would be greatly appreciated. Thank You, Quaal
*** ONLY THIS PART OF THE ABOVE MESSAGE IS MINE ***
ALSO I HAVE THE "RCA Opal M4002A" (2GB) mp3 player.
*** After much trial and error this FIXED my problem. ***
1 - First right mouse click on "My Computer".
2 - Left click on "Properties"- Left click on "Hardware"- Left click on "Device Manager".
3 - Now with one end of the USB cable plugged into your mp3 player, plug the other into your USB port. (Now when I did this a new "Portable Device" icon with an "MTP" Driver (sub icon) showed up in the "Devices List". (The "MTP" icon had an "!" on it, telling my it wasn't working properly. I then did this.
4 - Right click on "MTP" driver icon, then ...
5 - Left click on "Update Driver". (I was then given two choices. The top one was the faulty "Portable Device" driver which I had done everything I could to fix, but nothing worked. So I then did this ...
6 - Left click on the "Mass Storage" Driver (the second choice below it in the list), I then clicked "OK". The "Updating Driver" screen showed for a moment. The "Portable Device / MTP Driver(!)" icon vanished from the "Device Manager" devices list, But the looping STOPPED!!! My Opal was working beautifully and showing in my "Root Directory" as Drive j: and in "Device Manager" under "Disk Drives" as "Thomson Opal USB Device".
P.S. For some reason the file transfers are noticeably faster now. Good Luck, Quaal
May 21, 2008 | RCA OPAL M4001 MP3 Player
Lost USB cable for my RCA Lyra MC4002A MP3 player
I work at RadioShack and have had a few customers ask about this. We don't have one specifically for the RCA mp3 players, I had a hunch that the charger for the iPod Shuffle (the newer one, not the older one) would work. As it turns out, it does. You can order one through our stores or website that's made by DLO (catalog # 55025326 ), though most electronic retailers carry some sort of charger for the Shuffle already, and you can easily find them online, too.
Mar 17, 2008 | RCA OPAL M4001 MP3 Player
Rca opal m4008a
My daughter's was doing this. We found out that there is a button on the side of the player that says hold. She had turned it on hold, by accident. As soon as we turned it off, it worked fine. This "hold" button is for when pocketing it, so the battery doesn't run down.
Jan 20, 2008 | RCA OPAL M4001 MP3 Player
RCA Opal M4008A 8 GB
FF - This is a common problem with Audiobooks - there is no way around it on this player. Drag files to Audiobooks folder to get them out of the "music" folder
Jan 17, 2008 | RCA OPAL M4001 MP3 Player
Rca mp3 player dont work
Did yout hit the reset button on the back?
Dec 29, 2007 | RCA OPAL M4001 MP3 Player
RCA HDTV Tru Flat 27"
I had that problem, it was the tuner.
Nov 11, 2007 | RCA TruFlat 27F520T 27" TV
RCA OPAL M4001 MP3 Player Logo
48 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
