Question about HP DeskJet 810c InkJet Printer
Printer problems I have a 810C HP Printer and the third light is flashing. I put new ink in there to. I dont know what is wrong? Can you please help.
  • alpha2009 Jan 22, 2009
    I have a HP deskjet 810c printer which is not working and the third light on the right hand side corner is blinking. I have changed the cartridge and dont know what else to do. Kindly suggest a solution. Regards.
    Amit
Scrap it. I suspect your 810C has the same problem as mine - it's buggered. I have done everything to address the blinking cartridge light but nothing works. I've come to the conclusion that it's a mechanical/electrical problem and that my 810C, which has worked pretty well, bar the odd tantrum, for many years now, has come to the end of its life. Very possibly its demise has been hastened by the use of remanufactured cartridges, a practice I will continue as long as the real McCoys are such a rip-off.
Posted on Feb 21, 2009
I put a new colour cartridge in to my 810C printer but the colours all came out wrong. How do I clean the ink jets please?
I am not sure what you mean by colors come out wrong. However, if the new cartridges are refills, there is the possibility that the refillers damaged the cartridges.
Try this: remove the color cartridge from the printer and check the bottom of the cartridge for ink blobs. Blot any ink around the silver screen-like area. Try not to touch that silver area. If there is no ink there, reinstall the cartridge and go to the Printers and Devices where your printer should be listed. Right click on the printer and select printer properties which will bring up a properties window where you select the Services window and select "clean the print cartridges" (this is Windows 7 but XP and Vista are not much different) Select ok and wait for the printer to go through its gyrations. Don't select "prime" at this time. When the printer finishes, try printing again. If the colors are still messed up, you could return to the clean selection and select "prime" in the next window (not likely to help).
If these don't work, you can run the clean cycle a couple of times, but chances are the cartridge has failed inside, allowing the inks to run together. Whether it is new or refilled, just return it for a replacement.
Feb 12, 2011 | HP DeskJet 810c InkJet Printer
HP 810C. Lower of three lights winking. Ink cartridges installed. Driver confirmed as O.K. Attempts at printing form queue - now deleted. Will not print. Will not clean or do any maintenance function....
The blinking ink light means that the printer does not recognize one of the ink cartridges. Power the printer off, pull out the power cord, wait for awhile, replug and turn the printer on. If the light no longer blinks, ok. If not, try installing another cartridge pair if you have them available - even if they are old used ones. If the ink light continues to blink with different cartridges or if you don't have any different cartridges, old or new, you have a dilemma. Do you want a new printer or do you want to continue to chase this problem. To chase this problem, get new cartridges and install them (half the price of a new printer). If that works your set, but if not you need to have your printer serviced which is doubtful that it is worthwhile doing so.
Oct 13, 2010 | HP DeskJet 810c InkJet Printer
Toner light keeps blinking
The inkjet uses ink, not toner. When the light is blinking it indicates something is wrong with one of the cartridges, such as can't find it, not installed, out of ink, improperly installed, printer has died. First thing to try is to disconnect the power (not just power off) for 5 - 10 minutes and reconnect. If that does not resolve it, inspect the cartridges and reinstall them. If you have another printer that uses the same cartridges, try the cartridge in it. if not, get another set of cartridges and install them. If none of these steps resolve the problem, chances are that the printer is the problem and is probably not worth spending additional time on it.
May 03, 2010 | HP DeskJet 810c InkJet Printer
Printer indicating out of ink
Hi! joeandtam
Did you run a cleaning cycle on your cartriges? Check your tool options from your Programs/HP page.
InMrFixIt
Nov 08, 2008 | HP DeskJet 810c InkJet Printer
New Ink Cartridge not working
first check the new cartridge tmake sure you took off the thin clear tape on the bottom of the cartridge. if you did then the cart. is falty and go back to store and exchange. please rate me. thanks
Sep 21, 2008 | HP DeskJet 810c InkJet Printer
Ink cartridge
Is the ink cartridge now unstuck? Are the cartridge ports free of any dried ink, etc. are new cartridges in place? Try turning your printer off for several minutes and then turning it back on. Let us know if this does not work.
Aug 15, 2008 | HP DeskJet 810c InkJet Printer
Light is flashing
check cartridge compatibility first:- HP Deskjet 810c HP15................black cartridge compatibility HP 23 ....................colour cartridge compatibility Issue ---A print cartridge is missing. Solution Install the missing cartridge. Issue --The printer detects a faulty, incompatible, or improperly installed print cartridge. Solution 1. Open the top cover of the printer. 2. Make sure the correct print cartridges are installed. Click here to go to the printer/cartridge compatibility chart. 3. Replace or reinstall the print cartridges. 4. Close the top cover of the printer. Issue ---The print cartridge contacts are dirty and the printer does not recognize the print cartridge. Solution Clean the contact points on the cartridges with a dry, lint-free cloth. 1. Open the top cover of the printer. 2. Remove the print cartridges. 3. Clean the copper-colored contact points on the cartridges with a dry, lint-free cloth. NOTE: Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. 4. Use a dry, lint-free cloth to remove the moisture from the contacts. 5. Insert the cartridges back into the printer. 6. Close the top cover. 7. Try printing again.
Sep 11, 2007 | HP DeskJet 810c InkJet Printer
Lights Flashing
try this...hold down any 2 switches and then turn it on. try a combination if possible. this should print a test page.
May 27, 2007 | HP DeskJet 810c InkJet Printer
Flashing ink refill light
Sometimes refilling them over and over doesn't work well. Once ok...but i suggest that you buy a new cartridge. I know that they are expensive but it will help. Also take some Rubbing alchohol and a q-tip...clean inside where the cartridge sits..that will help...this is for sure a bad ink cartridge
Feb 28, 2007 | HP DeskJet 810c InkJet Printer
HP DeskJet 810c InkJet Printer Logo
225 people viewed this question
Seeker5211
Seeker5211
