Question about Garmin StreetPilot c340 GPS Receiver
Unit shuts off
The c340 unit turns on for a minute and then says "external battery power loss" and will shut off in 30 seconds
    Scholar:
  • 52 Answers
I assume this message is when operating from the internal battery alone, correct? It could be that the unit is confused about the power source status... yes, electronics sometimes get confused too.
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get the unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Posted on Jul 18, 2008
I turn my computer on and comes up with toshiba and AMD turion 64 symbol and option f2 of f12. I push f2 and please wait comes on however it's been like this for several hours. What can I try?
Shut it off and unplug it, remove the battery and wait 20 minutes. Then replace the battery, plug it in and start it up, let me know if this works.
Apr 21, 2015 | Toshiba Computers & Internet
The unit runs Ok for a few minutes and then shuts down.
Does it do this on just battery power or with an external power source? If on battery poer, then the battery if defective.
- Jim
Jul 20, 2010 | Garmin Nuvi 660 GPS Receiver
Suddenly I have a blank screen. Was working just fine a minute ago!
It sounds like this might be a battery problem. Have you tried resetting the unit? Turning the vehicle off should NOT shut the GPS off instantly. It should indicate that the external power was lost and ask if you want to continue on battery power (shutting off in 30 seconds if you do not reply). Is this what it did?
Jan 09, 2010 | Garmin StreetPilot c550 GPS Receiver
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
Spc340 fails after 30 seconds. Is there a battery to replace ?
it sounds like the charging jack in the cradle has gone bad they can be fixed, you have to disassemble the mount and the resolder the jack, it is a difficult task i would rate it about a 9 to a 9.5 out of 10 on difficulty scale, more than likely it will not be worth the frustation to repair, vs replace.
Aug 14, 2009 | Garmin StreetPilot c340 GPS Receiver
Turns off with pressure applied to top of unit
I have discovered an intermittent problem on my 10 year old 295 when powered by batteries.
It appears that the chrome plating is de-laminating from the battery contacts that are either side of the back panel attachment hole. At first glance it looks perfect but if you run a fingernail or other small item across the face of the contact you will see and hear a movement as if there a a loose layer of foil over it. This is causing all manner of faults including 'external power lost, shut-down in 30 seconds' when the external power was not even connected at all!
Jun 08, 2009 | Garmin GPSMAP 295 GPS Receiver
Garmin C340 GPS - Will Not Power On
Thanks. This helped me fix the problem.
Apr 02, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 FROZE? Here is how to fix it!
My garmin shuts down immediatly when I switch it on. Dont know if there is an internal battery that needs to be replaced or some thing else.
Jan 26, 2008 | Garmin StreetPilot c340 GPS Receiver
Keeps turning off
Your power cord is cutting in and out. You either have a bad power cord or there is something wrong with the connection to the cigarette lighter. When the unit say "Running on battery - will turn off in 30 seconds" this mean that it has lost external power. This is by design so that when you shut off the engine external power is cut to the unit and that it will shut down.
It a shame that for the C330 Garmin decided to remove the LED light from the power cord that shows the power cord is connected correctly to the cigarette lighter.
Jan 15, 2008 | Garmin StreetPilot C330 GPS Receiver
Battery
need new batteries.
Jul 24, 2007 | Tomtom GO 300 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
