Question about Vacuums
Hi I am looking for some where to get my kirby legend 11 vacuum cleaner serviced and probably a new brush head for it thanks
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=722285
Generic problem for all Vacuums
Hi I am looking for
Posted by libbit1 on Jun 30, 2008
Hi, I am looking for some where to get my Kirby Legend 11 vacuum cleaner serviced and probably a new brush head for it thanks.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In most cities there are factory authorizes Kirby Vacuum dealers that also do service in most of the big cities other wise there are your local vacuum cleaner dealers in your area that also do service on the Kirby vacuums. When referring to the brush head are you asking for the bell housing or the brushroll. The brushrolls are very available @ either dealer but the bell housing that the brushroll fits into you probably will need to get that from the factory or the local vac dealers may have a good used one for less money or ½ the cost of a new one. Just a suggestion for you. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 03, 2008
My Kirby seems to be putting more dirt on the floor than what it is picking up? The brush roller is turning but it leaves dust streaks . It also shoots particles out the side instead of vacuuming it up....
Hi there. It sounds like you belt may be stretched. Simple turn vac upside down, start it up and carefully press your hand on the brush. If the belt is stretched the rollewr will stop turning. If this does not help, you probably have a clog in the power head area. Hope this helps, Chris
Feb 09, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Kirby will not turn on
For the kirby to run all the switches need to be in contact. First check the brush head and make sure its attached properly, then check the plastic piece on the bottom of the bag (called the mini emptor) it should be all the way against the body of the vacuum. if all that is good check the cord where it runs up the handle and connects to the swiveling strain relief at the top... usually those cords go bad right there. If the cord is good, you probably need a new switch but before you spend the money on that expensive genuine kirby switch check the motor carbon brushes and the commotator on the armature where the brushes make contact.
Jan 02, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Kirby legend 11
Just got done fixing our Heritage II model 2HD, it had a dirty safety switch. Both the hose attachment and the roller housing depress a plunger to close the switch, thus sending AC to the motor brushes. You might want to try pushing this in and out repeatedly with your thumb, power removed of course, in an attempt to make better contact. If this works to restore power to the motor, it'll be just a short time before the problem repeats itself. You'll have to remove the switch to give it a thorough cleaning. I didn't have any contact cleaner handy, so I wound up using WD40. Hope this helps. Kevin H.
Apr 04, 2009 | Kirby Heritage II Vacuum
Kirby Legend 2 Vacuume cleaner
call Francois Gordon 27 11 476 1235
Rocky
Jan 03, 2009 | Bosch Turbo Jet Bagged Upright Vacuum
I don't know how to change the brush. HELP Kirby legend 2 vacumm
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=767761
I don't know how to
Posted by mcwalworth on Jul 10, 2008
I don't know how to change the brush. HELP Kirby Legend II vacuums
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. To change the Kirby brushroll is to dial the belt off of the fan pulley and unlock the head to the bell housing, the head will come off. Then you turn the head over and remove the bottom plate by 2 levers the brushroll will be attached. Remove the brushroll and replace it with the new one with the screw head facing down to the carpet. Replace the bottom plate and install a new belt. The belt install on a Kirby is to raise the height adjustment to the highest level and then dial the belt off counter clockwise so it is loose and not on the fan pulley, release the top lever on the bell housing, then remove the bottom plate and unhook the brushroll on one side, slide the old belt off and then slide the new one on, replace the brushroll with the screws facing the carpet and re-hook the bottom plate on the Kirby. Then take the bell housing and hook that back on to the Kirby and lock it down. Then dial the belt on clockwise all the way and the belt should be on the fan pulley. The belt should be ready to go, plug in your Kirby and then do the step down on the vacuum height adjustment until the tone changes, then try to see id it picks up, if not go one more height adjustment and that should be the correct setting.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Mail To: Consumer Relations
The Kirby Company
Cleveland, OH 44102
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
How to use my kirby carpet cleaner
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=541258
How to use my Kirby
Posted by rnelson510 on Apr 24, 2008
How to use my Kirby carpet cleaner?
This is kind of a general question and I will try to explain the best I can. Most Kirby’s have a vacuum head and sometimes a shampoo head, the vacuum head is removable on most Kirby’s and the vac head comes off the front for a brushroll and belt change. When you vacuum and you go to adjust the vacuum head, raise the height adjustment all the way u to the top with your foot, then listen to the tone change, @ first you will hear air pulling thru and the brush has not hit the carpet as of yet, that is the sound the you are listening for, once the brushroll hits the carpet – there is a definite tone change and that is when you have it adjusted correctly, try to vacuum with it set that way, if it is picking up well – you’re OK, if not adjust if down one more click. Also remember to do a belt change every 4 to 6 months for good cleaning, change the bag more often because it will pup better with a new belt and bag, or if you don’t have a paper bag, take and scrape the inside of the cloth bag with the scraper provided in the small zipper section. Please refer to the owner’s manual or trouble shooting guide or to your local vacuum cleaner dealer or in the yellow pages, also you can use the Kirby factory or website listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Vacuums
Legend 11 Kirby, sometimes will not turn on
Could have a problem with the motor, may need carbon brushes, or other motor related parts. If the light turns on and off with the switch, then the switch is probably ok. There is a speed switch inside the motor casing that could be bad.
Feb 21, 2008 | Vacuums
Vacuums Logo
69 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
