Question about Kenmore 22422 Top Load Washer
Kenmore washer it won't stop filling up with water and overflows.
  • 481 Answers
This could be the water level switch or the small flexible plastic tube that goes from the water level switch to the side of the tub. this tube may have worked loose if the washer is vibrating too much.
Posted on Jun 30, 2008
zeusfaber
  • 247 Answers
SOURCE: washing machine overflowing
I'd have a look at your water level detector to start with. Usually a narrow bore hose running from near the bottom of the drum to a pressure switch somewhere near the top of the machine. Most common problem is that the hose gets blocked with gunk. With the machine off and drained, try removing the hose and giving both it and the barb on the drum that it came from a good clean through. A.
Posted on Jul 17, 2007
  • 209 Answers
SOURCE: Washer water overflow.
i am a recently retired engineer of 20 years and this sounds like a blockage to start with, when you remove the lid you will find a round disc like object (pressure switch) with a thin pipe coming from it going down to the bottom end of the machine, this pipe as either come off or is blocked somewhere. drain the machine totally, clear out the pipes, make sure there are no damaged parts to the pipes, then make sure all are fitted properly, start the machine off again and watch for water level shutting off near the bottom of the door, start with the above, if this doesn't cover the fault there may be an issue with the timer or electrical fault elsewhere/? hope this helps, if so rate me please, thank you
Posted on Sep 13, 2007
Lumpy816
  • 246 Answers
SOURCE: Waher wont stop filling
Check your pressure hose. To check the first end, pull your washer forward and tilt it back about 45 degrees. On the right hand side towards the back you'll see a clear hose coming down and "pugging" into the tub. Make sure it's in place. To check the other end, open the console and make sure the other end is plugged in to your water level switch ( far left hand side of the console. If you took the cabinet off to replace your coupler, make sure you didn't pinch the hose against the back panel when you put the cabinet back on.
Posted on Jun 16, 2008
  • 21 Answers
SOURCE: Kenmore 70 series washer
if the water was overflowing from the top of the tub it sounds like the pressure hose came loose. tilt the control panel back and you will prob see the hose that connects to the left side (where you adjust the water level) has come loose. cut about 1/4 inch off of it and re-connect it.
Posted on Dec 29, 2008
  • 234 Answers
SOURCE: Kenmore washer won't stop filling w/ water
The problem is most likely the water level switch. This would be the case if the water is able to be turned off with the dial on the washer and not running all the time.
If it is running all the time and you have to turn it off at the water line valve, then the problem is a stuck water fill valve.
If you need more help, post a comment.
You can find information on the parts at partselect.com.
You can buy parts from them or find them locally if you want.
Thanks,
Tim
Posted on Jun 16, 2009
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
Won't stop filling up. Water continues to flow without stopping for cycles
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps.
Gene
Aug 28, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer keeps filling with water never shuts off overflows
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking.
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement.
Gene
Aug 04, 2011 | Kenmore 26422 Top Load Washer
Water doesn't stop filling tub and tub overflows
the water level sensor is not working and needs to be replaced
Aug 31, 2009 | Washing Machines
Water Overflows from washer
Hello,Sounds like a problem with either the inlet valve or the pressure switch, way to determine which on is while it is filling pull the plug..if water keeps filling it's the inlet valve..if it stops filling it's the pressure switch..If you have any other questions or concerns please feel free to comment again..good luck!! Mike
Aug 18, 2009 | Kenmore Washing Machines
Fills with water but doesn't stop
the washer timer control has failed, u will need to replace it.
Jul 23, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series heavy duty 3 speed
This problem is generally caused by a pressure switch failure. The pressure switch controls when to shut the water inlet valve off at the appropriate level and is located behind the load level or water level selector knob on the operator console. Before assuming, however, that you have a defective switch, read the following link first:
http://www.fixya.com/support/r762094-washer_overflows
In the majority of the problems I have experienced with an overflow condition on a washer, it has been caused by the air hose coming off the pressure switch. Hopefully, this will be the case with your washer and will not require parts. I hope you find this information helpful. Let me know if you require additional assistance.
Sep 29, 2008 | Kenmore 24032\24036 Top Load Washer
Water Just Keeps Filling!
replace the water inlet valve, the valve that the black hat and cold lines connect to
Apr 19, 2008 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Kenmore 22422 Top Load Washer Logo
113 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
