Question about Maytag M3DH30B2A Dehumidifier
No water being removed
Dehumidifier runs and get hot. no water being removed at all.
  • heier1 Jul 01, 2008
    took back cover off no water or frost on the coils compressor runs extremely hot.
  • heier1 Jul 03, 2008
    this unit is only two years old how do i get maytag to repair it under warranty. better yet how do i get there repair people to even take the unit in thanks for any help
    Sergeant:
  • 225 Answers
Hi, Firstly I would check to see if there is an air filter screen inside the machine - usually just behind the intake grille. They can be tricky to spot. If the filter screen is clogged up with fluff it will prevent the machine from working properly.
Secondly, can you see any signs of ice or condensation on the cold pipes? If not, and the compressor is running - a purring or throbbing sound - your machine might have a refrigerant gas leak. You would then need to get it checked / repaired by a regrigeration engineer.
Does this help? If not please give further details and ask again. Thanks.
Posted on Jun 30, 2008
  • Richard Raynor Jul 01, 2008
    Hi heier1,
    If I read you correctly the compressor is running but not cooling the pipes, so I'm sorry but it sounds like your machine has developed a refrigerant leak. If I'm correct then it will need to be repaired by a refrigeration engineer who has the necessary equipment to locate the leak, and then recharged with the appropriate gas.
    Sorry! D.
  • Richard Raynor Jul 03, 2008
    Hi.
    You haven't specified your location in your profile, but the first thing to try is the "Repair Service" box on this page.
    I hope this helps. D.
    and thank you for the rating :-)
I have had the machine on for 5 days on high and have extracted less then a 1/4 inch of water. The back side of the machine is hot and blowing hot air - the motor runs but does not extract water Is it...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 31, 2011 | Whirlpool Dehumidifiers
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
The dehumidifier runs but does not remove moisture. The coils are cold but no frost. The inner coil is hot.
heatman101
May 17, 2011 | Amana D530M Dehumidifier
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
Dehumidifier makes the room too hot where it is running. does very good removing water need too empty 50 pt every 24-30 hrs.
The dehumidifier does not heat or cool, but the compressor running will produce some heat and it can make a room hotter...
heatman101
Aug 29, 2010 | GE AHG40LJ Dehumidifier
Unit runs but no water in tank. Unit does not expel hot air.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Aug 17, 2010 | Whirlpool AD25BBK Dehumidifier
Goldstar dehumidifier won't run
Sounds like this unit developed a freon leak and that will make it run hot like that...cheaper to replace it then to repair...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 14, 2010 | Goldstar DH504EL Dehumidifier
Our humidifer runs but does not collect water.
Againg, if theres no moister in the air it wont remove water. if you feel the location for exmaple a basment feels cool when entering , then mosuet exist. dehumidifer will make any location warm when removing the coolnest in the air. within summer hot months it will collect more water than in the winter months. if it does feel cool and machine dont remove the water. call a repair person.
Oct 04, 2009 | Fedders R6DH45X Dehumidifier
Runs but does not remove water
If only the bottom part if your coil is geting cold or freezing, it's low on Freon.
Please rate solution
Sep 05, 2009 | Fedders R6DH45X Dehumidifier
Dehumidifier not removing water from air
Have you checkec, replace all the filters...?
Jun 24, 2009 | Haier HD656E Dehumidifier
Maytag M3DH30B2A Dehumidifier Logo
327 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
