Question about Dell OptiPlex GX110 PC Desktop
Opening the cover to my Dell diminion 300
How do I open the cover to my Tower I can't open it to clean it
    An expert who has answered 500 questions.
  • 564 Answers
There are screws in back, either thumbscrews or screwdriver type. remove them from one side(only one panel needs to be opened.0
also, I'd recommend you be careful cleaning inside. there are loads of problems that can arise from this.
Posted on Aug 19, 2008
When i turn On my PC this thing shows in the monitor. <300 XT BIOS P/N 113-A33437-102
Open the case, loosen the 2 screws holding the black plastic casingon the cooling tower over the CPU. Carefully remove, or tilt back to reveal cooling tower radiator and coil.
If there is a layer of dust built up (like there was on mine); carefully vacuum clean the radiator, cooling tower unit, fan and all other surrounding areas. Clean any residue from tower-to-CPU contact area.
Vacuum entire PC inside and out. Remove, reseat, vacuum video card. Reseat storage drive cables reseat the memory sticks, close it up and plug it back in start computer.
Jun 05, 2014 | Dell Dimension 5100 (D51L1) PC Desktop
How can I remove the cover on a Dell Optiplex GX150? I have the Tower version, not the mini one.
I think this tower is of the clamshell design where the whole chassis opens up down the middle. Try pressing the pressure points on the top and bottom of the tower and pulling the tower open. No covers will come off, it will open on a sort of hinge to expose the inner workings. Here are some pictures from Dell of how this works on the smaller model, it should be the same for yours:
click on computer cover, or scroll down to that section
Aug 17, 2010 | Dell OptiPlex GX150 PC Desktop
Need to replace cd-rom drive, how difficult?
CD-ROM drive can be taken out by opening the tower side cover. ther is a cord at the back of the drive which needs to be pulled out. then from the front side pull the drive out. also be careful to check it has some screws at the side or not. if not then it should come out easily.
May 10, 2010 | Dell Dimension 3000 PC Desktop
Unable to remove cover from dell dimension 8400 desktop pc
This Dell Support, and the Service Manual for the Dimension 8400,
In the Service Manual main menu, left-click on - Opening the Computer Cover
1) Computer off, and unplugged from power. (Always unplug the power cable from the surge protector. Then if the power cable needs to be removed from the computer, do so)
2) Remove all cables to the computer
3) Lay the computer on it's Right side.
(As you face the computer, your right side is the computers Right)
4) There is a Release button on the Top of the computer case, and a Release Button on the Bottom of the computer case.
These are located at the Rear of the computer.
The preferred method of opening the computer case, is to press one release button in at a time, and slightly lift up on the side of the computer case, where that release button is located near.
Then go to the other side of the computer case, press this release button in, and lift up on the computer case.
The computer case opens like a clamshell. The computer case is hinged at the front.
Computer laying on it's right side. Press the Top release button in, and lift up on the computer cover located near the Top.
Now press the release button on the Bottom. Lift the computer case up.
The computer case opens from the back, towards the front, like opening a car hood.
Feb 18, 2010 | Dell Dimension 8400 PC Desktop
Hi There,
Should be very straight forward.
You can find full instructions here;
(this includes opening the cover!).
This model has 4 DDR2 slots and supports a maximum to 4Gb of RAM.
Aug 25, 2009 | Dell Dimension E521 PC Desktop
How to remove tower cover...
Hi, Please find the instructions for opening the 8300's cover. I hope this helps. If it does, please don't forget to rate the solution.
Mar 20, 2009 | Dell Dimension 8300 PC Desktop
Opening the tower of a dell optiplex gx240
Hi there.
Dell provide a detailed, pictured document to help you in these matters here its is >>>>>
good luck and thanks for using FixYa!!
Mar 15, 2009 | Dell Optiplex GX240 SFF Refurbished Small...
Can't get tower cover off
  • goto dell site
  • get free registration giving your service tag number
  • then search 'how to open cover'
  • You can find video for that
try out and please post your feed-back
Apr 16, 2008 | Dell Dimension 2400 PC Desktop
Removing cover on gateway 300
This a tower right? I don't have a gateway but I have a dell and a compaq tower they come apart pretty much the same way. The left side panel slides out by pulling from the back. Some may have a screw or two you have to loosen or take out. Then you can either slide it by pulling from the back or there could be a latch that you slide to unlock it. Wow I can't believe it 60 bucks. Just keep messing with it you'll figure it out!
Oct 09, 2007 | Gateway 300 C PC Desktop
Dell OptiPlex GX110 PC Desktop Logo
114 people viewed this question
Alun Cox
