Question about Brother DCP 130C All-In-One InkJet Printer
Paper jam theres always a paper jam but the paper doesn't feed at all thanks
    Genius:
  • 2,785 Answers
You have to open the printer and check for any broken or dislodge part in there.
Posted on Jun 30, 2008
Printer keeps saying i got a jammed paper there is no jammed paper
There are many places in a printer where a small piece of paper can get stuck. It's not always a sheet of paper. Open all the access panels and check the roller track for pieces of paper. If it is clear, unplug the printer for a few seconds and the plug it back in. This should clear the problem if it was in error. Also check the paper feed for too many sheets stuck together jamming the feed. Before loading paper always "fan" the paper first to avoid sheets being stuck together.
Apr 14, 2011 | Canon Office Equipment & Supplies
Says a front paper jam but no paper jammed any where
Your paper feder belt has ink on it and will not feed the paper. Remove the rubber belt and clean it good and clean and use compressed air on the printer tray area. If this does not work open the front feeder tray and set your computer to print from it. After about 500 copys it will normally have c leaned itself and be ready to feed from the main roller.
Feb 14, 2010 | OKI C5500n Printer
False paper jams and multi sheet feeds
multi feeds and jams are mostly caused by static electricity in the paper. ALWAYS fan paper top and bottom to remove static and "aerate" the paper before putting in prnter. Doing that will reduce the problems you are experiencing.
Please rate my help++++Thanks for using FIXYA
Oct 22, 2009 | HP Photosmart 8150 InkJet Printer
Paper jam on my toshiba 2060 model
Exactly where in the machine does the paper jam??If it jams when you hit the print button, try cleaning the paper feed tires with WD40.spray it on a clean cloth, clean the feed and pickup tires thoroughly and make sure to get ALL of the WD40 off the tires before using the machine.If you take the paper cassette out and look with a flashight you should be able to identify the paper feed tires.
Mar 24, 2009 | Toshiba 2060 Copier
Epson cx3800 paper feed problem
no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
Jan 29, 2009 | Epson Stylus CX3800 Printer
My adf jams. It does not feed the paper through it is missing the exit slot and jamming on the scanner. Is my scanner light spposed to always be on when the clover is closed? Thanks Richard Earle
Yes, the scanner light is normal always on, even if the cover is closed.
Try cleaning the rollers with some water.
Check if there is a piece of paper or staple or something else in the paper path.
If still jamming you need an engineer to service your ADF.
Please use the platen mode to make copies
Good luck and please rate me, thanks.
Jan 21, 2009 | Brother MFC-8840D All-In-One Laser Printer
Always Paper Jam in Epson Stylus CX3500
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Nov 26, 2008 | Office Equipment & Supplies
Paper ALWAYS jams!
Check if there are any paper leftovers inside the printer from previous printing jobs and make sure there isn't any strange objects that may have fall down in the paper loading tray.
Also put the printer upside down and move it up and down to see if anything that may have fall in the paper path, can get out of the printer.
May 05, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
Brother DCP 130C All-In-One InkJet Printer Logo
99 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
