Question about Dell Inspiron 3500 Notebook
DELL Inspiron 3500 2nd RAM Slot not reading
I'm fixing a DELL Inspiron 3500 for someone and has 128MB RAM in it and I just got another 128MB for it to Max it out to 256MB. The problem is the 2nd RAM slot isn't reading any of the Chips. I even tested the new 128MB RAM chip and works fine. I don't know why the other RAM slot isn't reading. Also another problem with this machine is the Modem isn't reading the dialup phone line. It says NetZero is unable to properly communicate with your modem. Please make sure your modem is properly connected and turned on. It is a internal modem and has its driver installed " COM1 9600 bps modem" is what is reads.
  • 3,940 Answers
Since the second slot is not reading either RAM module, then to fix it will require replacement of the motherboard. Motherboards for that system are cheap (Less than $50) but unless you are comfortable installing it yourself, that system really is uneconomically repairable (Cost more to fix than it is worth)
Posted on Jun 30, 2008
Fix ram slot
Couldn't locate documentation on this unit, no 1520 listed. Typically both card slots must be filled and of matching size/speed etc. Good luck.
Aug 27, 2013 | Dell Inspiron 1520 Motherboard
Dell Inspiron B130- Memory installation in second slot
RAM modules in laptops are secured by spring clips on both sides of the RAM module.
To release the RAM module press the clips away from the RAM module and the RAM module will pop up at an angle. You can then pull the RAM module away from the memory slot.
Insert the RAM module in the slot, push it into th slot and then press the RAM module down until the clips on the side lock onto the RAM module.
Jun 04, 2012 | Dell Inspiron B130 Notebook
Dell latitude wont read 256 megs of ram only 128
The c600 can handle up to 512MB of RAM, so it's likely one of your RAM sticks is bad or not seated correctly. Are you using two 128MB sticks? Remove the stick from the second slot and turn on the computer with only one stick installed, and see if the RAM is recognized. Then take that RAM out and try the computer with only the other RAM stick -- if either is not recognized, that stick is bad.
If both are recognized, try reinstalling both RAM sticks and see if the computer will recognize them. If not, make sure they are both seated properly. You may have a problem with the second RAM slot if it is still not recognized. If you have access to other RAM, try that too and see if it is recognized.
Jul 27, 2010 | Dell Latitude C600 Notebook
My Dell Inspiron 1545 DVD slot isn't reading anything
u cant do it if it is a hardware problem ... its best you take your notebook to the manufacturer
Jul 16, 2010 | Dell Inspiron 1545 Notebook
Dell dimension 2400 won't boot, just blank monitor. Power light comes on but desktop wont turn off after that just goes to amber light. The issue occurred when I replaced RAM with 128mb with 1gb in same...
This is a memory issue. First try to test it again with the 128mb of ram. Then go to the website www.crucial.com and test to see how much your system can allow to increase for memory and also see the type of memory your suppose to use. It could be that your not using the correct amount or the right memory
May 18, 2010 | Computers & Internet
I have an old dell dimension v450 that has 3 ram slots each with 128mb ram modules. Iwant to upgrade the ram with 512mb pc100 sdram but when I do the computer wont even boot up
your motherboard is not compatible with more than 128MB of RAM pre slot so max u can place 384mb of ram if u place more than that your motherboard will not recognise of it wont start
Feb 01, 2010 | Dell Computers & Internet
Adding computer memory
The only thing you could do is put in a 256MB module in the slot that you have access to. Only one socket is user upgradable. The second socket is only upgradable by a Dell service center. They would have to install a second 256 module to get you to the 512MB max.
Jan 22, 2010 | Computers & Internet
Upgrade of Ram on Dell 8100
There are 2 possibilities here - either the slot is not working or the RAM itself.
First install the working 128MB RAM in both memory slots one after the other and ensure that both the slots are in good shape.
Next, install the other 128MB RAM in one slot and check if this is working good.
Your laptop can support a maximum memory of 512MB. If you looking for an upgrade, please call Dell Support. Even though it's little expensive and shipping takes a week, you can get a free after sales service and peace of mind. Moreover you get proper guidance from the experts.
Jan 10, 2009 | Computers & Internet
Installing Memory
Hi
Yes, you can replace/upgrate the memory module under the keyboard.
Before you proceed, note that Dell Inspiron 2650 uses DDR200 3.3V SODIMM modules. Also, memory module capacities supported are 128MB and 256MB with a Maximum memory of 512MB. If the current memory installed is 128MB, you need to order 2x 256MB modules to replace/upgrade both memory slots. If the installed capacity is 256MB, you just need another 256MB for the slot underneath the laptop.
Check "Removing the Keyboard" for guide removing the keyboard to access the 2nd memory slot.
Read "Preparing to Work Inside the Computer" before committing to the above procedure.
Let me know how you get on.
Mike
May 24, 2008 | Dell Inspiron 2650 Notebook
Memory location Dell inspiron 2200
The memory inside is fixed but there is an open slot . Just open the access panel on the back and the slot is there. You can add up to 1GB
May 02, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 3500 Notebook Logo
Alun Cox
