Question about Frigidaire ATF6000ES Front Load Washer
Oil leaks on clothes
My washer made a very loud banging noise when it went into the final spin cycle.  When I took out the towels, several of them are spotted with black spots and some look like they have been smeared with oil.  Did something break?  Can this be fixed reasonably, or should we buy a new washer.  This is installed under our kitchen counter top so we need another front loader.  We don't know what to do.  Thanks!
  • 876 Answers
How old is the washer and how expensive? It may be worth it to get an evaluation service call from a local appliance shop and if it needs to be replaced, the repariman may have recommendations.
Posted on Aug 13, 2008
How do I fix a ge top load washer that's making a loud banging noise while agitating?
There is either a balance issue or a damaged spring. Usually all you need to do is open the washer (make sure it is OFF) wait for it to stop spinning... then look for clothes bunching up on one side. Take some out ad move them around.
Sometimes putting in to many or too few items will make it harder to resolve. Items like large towels or several towels, sheets and such will hold more water and be heavy until the water starts to pull out.
Oct 09, 2014 | Washing Machines
No spin cycle
Did you check to see if there is a broken
belt present
Dec 04, 2007 | Frigidaire GLTR1670A Front Load Washer
Loud clunking, banging sound during the spin/drain cycle.
the make , model and year are missing but if it is a top loader unit , it indicates that the tub suspension bar motion absorbers have broken and need replacing
Sep 06, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
FWT449GFS2 making loud banging noises during final spin cycle
lxr6232eqo making loud banging noises during final spin cycle
Aug 31, 2009 | Frigidaire Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Final Spin Drum BANGS around--terribly frightening noise!
Check the spring that hold the drum in place. They are about 4-5 inches long on the top of the drum at about 2 and 10 o'clock. The springs suspend the drum and if broken the drum will bang around. About $40 to order springs online
Also check on the bottom at about 4 and and 7 o'clock because there are 2 shock absorbers that help keep the drum from just bouncing and bouncing with no end in sight. Again about $40 to change each one.
I am in the process of the first repair and doesn't seem too difficult. The second was done about 6 months ago and was not too difficult but was awkward because you had to lay on the floor to get the replacement pins in place.
Jan 11, 2009 | GE WSXH208A Front Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
149 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
