Question about Saeco Incanto Classic Espresso Machine
I have a Saeco Incanto RS Espresso Machine. The prime light is on, but the machine won't prime. Very little water of steam comes out of the wand.
  • 2 more comments
  • JohnfromFL Jul 16, 2008
    Thanks to the two folks who offered suggestions. I think mirran was on the right track with a line blockage or something similar. I broke down and took it to an authorized dealer here in Tampa. They replaced all the lines, blew out the machine, and did a major de-scaling. Works like a champ now. Tampa has very rough water so I will now use only distilled water to prevent a repeat. The best $65 dollars I could spend.
  • Robert Toth Dec 12, 2008
    I am looking for a Saeco repair place in Tampa. Can you give me the name?
  • dazza Aug 04, 2012
    i'm pretty much sure that distilled water is not really drinkable, you should use filtered or mineral water
  • Anonymous Mar 14, 2014
    how to prime my exprelia evo espresso machine
  • 515 Answers
Do you have a filter in your water tank?
if you have a filter, remove it and try.
Posted on Jul 10, 2008
You need to manually prime it using the priming bulb that came with it. Instructions are in the manual. Remove water tank. Fill priming bulb. Hold priming bulb on water inlet. They don't inter-connect, so just hold it on there as best you can. Turn the machine on, turn steam knob on, and gently, slowly squeeze the bulb to force water into the machine. It works best when the machine is cold, because you want to get liquid water in there, and not have it displaced by steam.
I have a Saeco Incanto classic, the low water light is on, tank is full, and I have steam coming from the steam wand.
try descaling the machine it could be that the water level switch is clogged with water calcium and not lifting when water is added, or it is defective and needs replacement. I hope this was helpful.
Oct 22, 2014 | Saeco Incanto Classic Espresso Machine
Hi, I a problem with my Saeco s-class incanto classic coffee machine. The two coffee cup lights are flashing green the water light is flashing red. I prime by turning the steam valve and hardly any water...
Try this, when you run the hot water cycle to prime machine and it stops putting out water push in on the knob if that works then replace the tap rod assembly or the whole steam valve assembly.
Aug 29, 2010 | Saeco Incanto Classic Espresso Machine
Saeco S class Incanto Classic was working, but now no steam at all. The pump sounds like it is trying to pump, but cuts out after a coupl of seconds, hot water light comes on, red water light flashes, and...
Check the end of the steam wand and parnello, if both are clear, then descale machine, that might unblock the tubes feeding the booster boiler and the steam wand if it doesn't then you will have to do it manually.
Mar 06, 2010 | Saeco Incanto Classic Espresso Machine
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Feb 22, 2010 | Starbucks Saeco Italia Digital Barista...
Cannot get the machine to work for first time. Power works, water in but no water flowing into machine. Cannot get the circuit loading to work??
Press hot water button and open the knob for about 10 secs, this will prime the machine. Check the emd of the steam wand to make sure it is not blocked.
Nov 28, 2009 | Saeco Incanto Classic Espresso Machine
Water problem with Saeco Incanto Rondo sClass
Check the nozzle at the end of the steam wand it might be blocked.
Apr 25, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Saeco Incanto Classic Espresso Machine Saeco Coffee Machine Type SUP 021YDR Display shows Ventilate when I follow instructions and turn the Hot Water and the water knob the water is not coming through....
Do you get coffee? If it is just no water/steam, could be a blockge in the steam wand, or blockage in water lines. First test easy one - the steam wand. If the steam wand is o.k- then check for blockages in water lines/components ( pump, boiler, steam boiler). If you do not feel confortable with testing all the untis where water flows, contact Saeco USA Inc. to locate a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Apr 12, 2008 | Saeco Incanto Classic Espresso Machine
Brand new Incanto Classic bought online, not working after 1 month
First, machine should be under warrantee- check with 1800myjuicer.com
Sounds also like you have blockage in the steam wand- every time you froth milk, you should let some water come out- to prevent clogging. Try first inserting a pin into steam want ( machine turned off) to see if that alleviates the problem. Also contact
Saeco USA Inc.at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Mar 17, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
1,028 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
