Question about JVC AV-56WP30 56" Rear Projection Television
No picture, clicking sound coming from speakers, power light blinks
I have a JVC AV-56WP30 56 in. rear projection. Don't know what happened, but one day I go to turn it on, and I get no picture, just the power light flashes on and off and a clicking noise is heard coming from the speakers in sync with the flashing. It doesn't flash a certain number of times and pauses, just a constant flashing. The clicking gets progressively louder then stops after about 30 seconds or so, but the power light continues to flash.
I am experienced in soldering and would like to fix this problem myself, if possible. Any help is greatly appreciated.
  • Anonymous Jul 07, 2008
    help same problem
  • quynh_ntvu Nov 28, 2008
    same problem here.
Visit http://fletchersite.com/documents/ask.html for an immediate solution to this problem.
Posted on Nov 02, 2008
Power light blinks , no picture or sound , just the speakers pulsating.making a heartbeat sound.
Sounds like the TV needs some type of serivice. But just to cover your bases try unplunging it from the power from the wall and let it rest for about 5 minutes. Then plug it back in to the power and try to turn it on using the power button on TV rather then the remote. See if that works. If it doesnt call JVC.
Sep 13, 2010 | JVC AV-48WP74 48" Rear Projection...
JVC Model #: AV-56p575--------problem with power
If this clicking is a continuous clicking sound its likely that its coming from the ballast.The ballast is the component that powers the lamp.If this component fails your lamp wont ignite and wont allow the start up to continue.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
Clicking on the power supply board(no picture or sound)
If you hear a buzzing, humming or rapid clicking noises this could be a problem with your ballast.Might be a good idea though to pull out your lamp just ensure its not damaged.You can find these at discount-merchant.com
Apr 01, 2010 | JVC AV-48P575 48" Rear Projection...
JVC 52 " Rear Projection TV Blinking Lights and no Picture
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Jul 17, 2009 | JVC AV-56WP74 56" Rear Projection...
Flashing power light on JVC 48W TV
Tri to remove the concergence pcb assy and start the Tv.If the TV is working just replace the convergance IC.
Feb 11, 2008 | JVC AV-48WP74 48" Rear Projection...
Jvc av-56wp74 power up failure
Hello hwkdoc,
What has happened is that your shutdown circuit relay has tripped and it looks like it also may have malfunctioned. This however is not the cause of your problem but a symptom. The cause of your problem is an over-current condition caused by one of the systems in your TV, I would suspect the high voltage power supply or the switching low voltage power supply. These are the first places to look, if they are not the problem then check the convergence correction amplifiers. Right now the shutdown circuit is keeping the TV from coming on. If you do not have a background in electronics I would advise you to have a qualified TV technician analyze and repair your TV.
Thank you,
Shuttle83
Oct 15, 2007 | JVC AV-56WP74 56" Rear Projection...
Power-on problem
yes..jvc has an upgrade for the crt driver ic's replace all three chips and resistors note: resistors must be replace at time chips are replaced now call a local tv guy you know the fix!
Aug 21, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-56WP30 56" Rear Projection Television Logo
176 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
