SOURCE: Installing NVidia 8500GT XFX 256MB graphics to A8N-VM Motherboard
The chances are that you have an old motherboard which is not compatable with the new graphic card. Or you may be running windows 98 and are downloading the driver for xp or visa versa. The probable solution, will be to sell the new card on ebay and buy the best old card you can off ebay. Or just make do with the card you already had in your computer. If you are determined to have a better graphics card. A motherboard upgrade with better graphic card may be the best answer or buy a better spec pc second hand if you don't have much money. You'll probably waiste a lot of time trying to get the new card to work and it probably never will.
SOURCE: Motherboard problem
Hiw can u say's its display problem,Have u checked the signals on k/b ?
If not check the Num lock status in keyboard. Press the Num lock key ,if the light glows and stands for sometime display is ok,but ur vga adapter is the problem.
Otherwise problem maybe with m/b or psu.
Pl check it.
Regards.
Was this soultion useful?give the apppriciation by rating it.
SOURCE: cannot get new ati radeon 4350 graphics card to work on my asus motherboard
A couple of suggestions, in case you over looked them.
1) Get into BIOS and make sure the on board is disabled there. I've have trouble before when I missed it.
2) If the old one is showing on your Device Manager, Disable it but dont uninstall it. Then remove any drivers for it.
SOURCE: nvidia graphics card won't fit in asus ncch-dl motherboard
The NCCH-DL has the following slots:
1 - AGP-Pro 8x
(you can use regular AGP cards in here as well as long as you have the little plastic thing that comes with the mobo... you may even be able to without it)
2 - PCI-X
This is NOT PCI-E.
You CAN use regular PCI cards in a PCI-X slot IF the company that manufactured the card left the space between the little metal contacts... unfortunately, many PCI cards are made with the space filled in with useless plastic... I've heard you can cut the little space yourself and it'll work fine... I don't know why it wouldn't but be careful, and of course do at your own risk.
I currently use a regular PCI network card in this slot because the onboard LAN port only has Win64 bit drivers on the web site and it works just fine.
A PCI-E card will NOT work in this slot.
Generally speaking the PCI-X cards you are going to find are riser cards, network cards, firewire cards, and controler cards.
2 - Regular PCI Slots.
I think you know what PCI is.
