Question about Toshiba Televison & Video
I have a 2 year old Toshiba FSTPURE 27" flat tube CRT tv. The problem is that there is no vertical scan---the picture is a single horizontal line in the center of the screen and all other systems appear to be working. Two questions. What is the likely problem and is it repairable at a reasonable price? I am an electrical engineer and spent 45 years in the computer hardware business so I am willing to tackle tv repair on my own.
  • 3 more comments
  • msternx Jun 30, 2008
    THIS PROBLEM DOES NOT REFER TO A PROJECTION TV.
    IT IS FOR A STANDARD BROADCAST 27"CRT TV.
    Thanks for the quick response but the answer is too vague. Without a schematic it is impossible to know which is the vertical IC
    or which resistor you are referring to.
    What else beside the vertical control circuit
    could be the problem? Could it be the high voltage supply---although probably not since the horizontal scan is working.
    I need enough info to fix it.
    One additional piece of info----When the picture becomes a horizontal line, I can get the picture back by turning off the TV and
    turning back on after several minutes. It will then operate for 5 to 10 minutes before failing. I assume that this implies a fault that is marginal and heat sensitive.
    The model # of the TV is 27DF46. I haven't looked for the chassis # but the S/N is
    BAB614022413 A and was manufactured in Feb 2006.
    Maybe the S/N reveals some info about the chassis #.
    Hi Robotek,
    It looks like the Premtech solution is detailed
    enough to attempt a fix. I have only a couple of simple questions. When the back cover is removed, is the main board containing the LA7847 easily identified and is it easily removable--is the board connected to the rest of the TV thru a set of connectors?
    (I am aware of the high voltage even when powered off).
    It is late here so I will be back to you tomorrow. We are getting close. Thanks
  • 4,889 Answers
You have to look for dry solders in the region between vertical output transistor and primary side of the flyback (LOPT) transformer. Youd dont need a service manual for this. Just re-soldering circuits as Benimur suggested will do the trick..
Posted on Jun 30, 2008
    Genius:
  • 1,665 Answers
    President:
  • 357 Answers
Hi there
Try replacing the electrolytic capacitors in the power supply section. I started with replacing (2) 860uf 180v caps just after the bridge rectifier and continued along the circuit. Some (15) or so capacitors later,it finally cleared the the horizontal bars and lines and the high pitched noise. It also fixed another intermediate problem of no video, when turning on the power.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as FixYa if it helps you.
Thanks
Dustin Ellse (BearWeb)
  • Dustin Ellse
    Dustin Ellse Jun 30, 2008
    Here is a picture of what they look like:
    Thanks
    Sergeant:
  • 243 Answers
Ok on the dboard This is your most probable cause after looking at the circuit diagram you need to replace 4 10V10 CAPACITORS.
the 2 ZENER DIODES # 10.0V 1W .
and this IC SEMICONDUCTOR LA1460 kit and you should be set.
test em to make sure and replace them as needed that website has anything that can be blown.
Hope this helps,
Nate
  • 1 more comment
  • Nathan Ayers
    Nathan Ayers Jun 30, 2008
    But this is your most likely problem that i laid out to you. Im not just giving you what it could be. Im giving you what it is, As i trust with your experience you described. This should be no problem for you.
  • Nathan Ayers
    i have access to the circuit diagram if you need help on a replacement walk through.
  • Nathan Ayers
    That IC isnt even in the unit Robotek i Have the circuit diagram do you? or you just blowing smoke. Cause none of what your saying is right yet your trying to discredit someone. You dont know much about IC replacement if all you have to do is replace an ic theres a little bit more to the kit then that. You need a diode and a cap or the IC will blow again. But you do your thing if it helps.
  • 1,512 Answers
Hi
The verticleICis mounted on a heatsink, and you will find thicker wires connected to the yoke plugged in nearby. Cahnge all the capacitors about the area also, as they have a tendency to blow chips,or cause other problems. This about does a vertical stage repair. Take the back off and have a look for the yoke connection like I have said.Check before anything else that the chip itself is not just dry jointed. This will cause vertical collapse also. The only other thing may be an open circuit yoke.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
  • 8 more comments
  • Graeme Ross
    Graeme Ross Jun 30, 2008
    It is a fault in the vertical not horizontal stage, so focus your efforts there to begin with.
  • Graeme Ross
    yes, the fault may be marginal. Capacitors are a likely cause of this condition also. I generally just rebuild the area, clean old heatsink paste away, and use new compound. I use 2% silver content solder for its better heat stress strength
  • Graeme Ross
    DON'T FORGET - DANGEROUS VOLTAGES ARE PRESENT
    even with power disconnected !!! Be sure to Work electrically safe.
  • Graeme Ross
    If the problem comes and goes however, it is probably more likely to be dry joints. Start with resoldering first, then if it does not improve capacitors and vertical IC would be my call
  • Graeme Ross
    Here is another repair method relaying the same message about the verticle IC by one of our Top Experts, Premtech
    it's most likely the the vertical IC an
    LA7847-E has probably become ring-cracked at the point where the pins
    are soldered to the pc board.
    Depending on how long it has been
    allowed to arc the IC may have failed also, but they are not terribly
    expensive or difficult to repair - at least not here in the shop.
    The
    main board has to be removed. Locate the vertical IC - it will be
    mounted to a metal heat sink and the IC will be stamped LA7847. Then
    turn the board over and inspect where the pins are soldered to the foil
    side of the board. One or more will look ring cracked or fractured all
    the way around the pin. At this point you have two options, carefully
    reflow solder over each pin and put it back together or replace the IC
    by de-soldering it and removing it from it's heatsink. remember to use
    a good heat sink grease when applying the new IC.. There should also be
    a couple of caps in pretty close proximity to that IC... One should be
    about 50v/100uf and in the shop here we test em all... You might also
    just replace that one for good measure - they're not expensive either...
  • Graeme Ross
    it can be said that there are many ways to skin a cat, there is only one way to skin this one. The solutions given relating to the verticle output IC are correct. I hope that the extra solution I provided from Premtech helps clear that up. Cheers
  • Graeme Ross
    @midwest. the LA1460 is a low power dip chip... not a vertical output chip. What part of the circuit are you looking at?
  • Graeme Ross
    no problem glad to be of help. The chasis generally slide into rails on the front section, and also into the rear casing. It is not hard to manouver it about to get access to the verticlechip. They slide out and with not much "unhooking" of loom dress, you can turn the chassis over. Will post back to here tommorrow. Cheers
    regards
    robotek
  • Graeme Ross
    Graeme Ross Jul 01, 2008
    turning back on after several minutes. It will then operate for 5 to 10 minutes before failing....
    Sounds like you are talking about an intermittent fault. This is classic behaviour for heat stressed dry/cracked solder joints about the VerticalOutput chip. The chip may even be desoldering itself from overheating in the first place, the conditions promoting the overheating being caused by failing overheated, vented out caps mounted near the heatsink.
    Have you got to the chassis yet?
  • Graeme Ross
    To help a little with the repair provess, I have found a link so you can download the service manual for the 32DF46. Is the 32 inch version of the set you have, but same chassis i believe. The LA7847 comes up for both models, so the vertical circuit will be relatively the same. It is marked as IC401,and is towards the center of the main board near the flyback (eht) transformer
  • Toshiba Master
  • 6,487 Answers
The symptom is a vertical output problem (and has nothing to do with the tube itself). It is very common and is the result of some capacitors in the vertical circuit deteriorating with age. As long as you get it fixed before any active components fail (like the output IC) it is generally a $50 - $75 repair. If the output fails, then add another $25 - $50 to the repair. There is always the possibility that the IC has a thermal failure already, usually meaning a $75 - $100 repair; but the capacitors are the typical fault. Hope that helps..........
    Brigadier General:
  • 6,966 Answers
Often culprit would be the vertical IC. The are a fe instances that it could just be a resistor that has opened or increased its resistance.
Basic tools (DVM, soldering iron hand tools) should be enough. Perhaps you would not even need a service manual but a schematic would help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
  • Louie  Role
    Louie Role Jun 30, 2008
    Hi again,
    A bit of clarification pls, is your Toshiba a 27AF61 and additionally, would it have a chassis number possibly on a sticker either on the rear cover or on the aluminum heatsink near the flyback transformer.
    Looking forward to your postback.
    Cheers.
  • Louie  Role
    Based on your last post, then i am inclined to think that there is no component failure but rather a case of cold solder. Corrective procedure wold require re-application of heat with a soldering iron and perhaps a dab of soldering lead where required.
    robotek has given you a way of identifying the vertical IC.
TV has a great picture but wont "hold it". Keeps going to a single flat horizontal line across the middle of the screen. Tapping on side of TV used to bring it back but now, nothing. Just a line.
Vertical scan output section circuit fault. Absence of vertical scan causes the single horizontal line on screen. Horizontal scan output section is OK. Contact any service technician to troubleshoot the vertical scan output section circuit. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Horizontal line fault to CRT based TVs are given.
Oct 06, 2014 | Televison & Video
My TV's video is out. A straight line goes horizontally along the screen. The sound is fine. It use to come and go, now it is gone for good. Does a tube need to be replace?
Hello.Theres a loose connection in your CRT board of your television.The problem is in vertical section maybe the vertical output IC is cold solder.Thats why harizontal lines appear in the screen of your TV.Your picture is good the problem is in the CRT board at the vertical section.
Jul 03, 2011 | Toshiba 27A45 27" TV
Toshiba Model 53HX71: Bottom half of screen and sound is fine; top half of screen has collapsed to a horizontal line in the middle of the screen. Repairman I spoke to briefly said it probably won't be...
Hello
Your TV has vertcal scanning problem. All picture tube based TVs have, both vertical and horizontal scan to spread the picture to entire screen. When vertical scan section meets with a fault, the picture will collapse horizontally and fi horizontal scan section has a troubl, picture will collapse vertically. Your TV s fault , we technically say, to be vertical foldover. This is due to the vertical output section, a circuit part, inside the circuit board of your TV.
To rectify this fault you must open your TV. Unplugh it from the power socket, and open it. Locate the vertical output section, which is easy to do. Look at the deflection yoke, the coil fitted on the neck of the picture tube, and you will see four wires from it going to the main circuit board. Out of which, two will be thick, normally red and blue in colour, connected to the opposite direction on the deflection yoke, and the other two will be thin. follow the two thin wires, said later, and you will reach to a plug in point on the printed circuit board.
Before doing anything, just look at the soldering of that section carefully for any loose soldering, or bad soldering. Usually, the components in the vertical output section will get heated during working, and ahve a cahnce to get loose contacted soldering joints. Just resolder all the suspected points by applying a little more solder, and see the effect. If thi doesn't help, check the IC used in that section for trouble. Some capacitors will be there in this section, will get dried as aging, replace them first, as they are ver few in numbers, When replacing capacitors, note their polarity, as electrolytic capacitors have both positive and negative terminals like torch cells. Before replacing the vertical IC, replace all the capacitors, especially, two or three large capacitors on that section. Just do these and if you want any more assistance feel free to contact me through Fixya. OK
Dec 08, 2010 | Toshiba 27AF42 27" TV
My TV picture begins flickering with a bunch horizontal lines across the screen, then the pictures comes back and is fine for a while and then it happens again. We ruled out the DVR box and cable...
You have a vertical IC that is in need of resoldering. And you can bet you have a few weak capacitors very close to this IC that need replaced. And while you are at it, check for a high voltage cap that may be weak in the horizontal section. This would be the next step in saving this TV. If you or a hobbiest can pull this board you could probably do the repair. Use extra caution when you do this. Or best yet find a TV Tech!
May 02, 2010 | Zenith C27A24T 27" TV
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
Flatline!
the vertical drive ic that drives the yoke for vertical sweep has blown.
sometimes it is solder problems like sharp and toshiba had.
the part is 10$ the pc board will label it ,the yoke is the coil setup on the picture tube.if you follow the wiring half goes to the horizontal drive,and the others to the vertical section.the chip drives the coil directly.there are VERY high voltages in there ,even turned off. the pix tube cap on top is 30000v. like a stun gun.the horizontal drive 2000 volts and the main power supply 165 volts dc high current.you need a special setup to discharge the picture tube.
May 15, 2009 | Mitsubishi CK-35308 35" TV
Is my picture tube going?
Hi there yes this is a common problem with old tube tv's and yes eventually stuff seems to break down there is not alot you can really do about it to be honest ...my suggestion is that this is lifes way of saying upgrade ...this tv has done well ....if your looking to upgrade i would suggest going to a Samsung LA26C450 as a replacement television or if you are not so much a fan then a KLV26BX300 as a new option ,
Cheers
Nov 04, 2008 | Samsung TXK2754 27" TV
Toshiba 30" CF0C50
You have a bad capacitor in your vertical area.
Dec 29, 2007 | Toshiba 27A34 27" TV
JVC 27" CRT TV AV-27BP3 display shows single horizontal line
I have a similar problem on my CRT computer monitor (AcerView 76c). It is an old screen and I think it is just at the end of its life, much like your TV. Having some background in physics, I would be pretty sure that the problem is with the cathode ray tube's vertical deflection system. The horizontal deflection electrodes are working while the vertical one is not. This results in a display of a single horizontal line (or in my case, a few superimposed) in the centre of the screen. Where both X and Y (horizontal and vertical) deflectors fail then the electron gun firing would result in a single bright spot in the dead-centre of the screen.
So really, we have no choice but to move on and buy a new set as repair is probably just as, if not more, expensive than replacement with a new device. Seeing as your post was in 2007, I hope you managed to solve the problem.
Best wishes,
SZ (Sydney, AUS)
Dec 24, 2007 | Televison & Video
Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Nov 10, 2007 | Sylvania 6427FF TV
Televison & Video Logo
133 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
