Question about GE Washing Machines
Washing machine vibrates and it is real loud - GE Washing Machines
  • 481 Answers
It sounds like the main bearing on the transmission; expensive repair.
Posted on Jun 30, 2008
Auto washing machine drum vibrates makes loud noise
When machine is empty use fingers to try and move drum side to side. Is there excessive movement? 2 to 3 mm is ok. If drum moves to much it will be the drum bearings. Easy fix for an engineer or competent diyer. Millions of how to videos on utube.
Oct 04, 2015 | Whirlpool Washing Machines
My Haier washing Machine vibrates and makes a very loud vibration noise.
Have you noticed any grease or oil stains on clothes coming out of the washing machine?
In my personal experience, heavy vibration and loud noise during spin cycles has been caused by the bearing being broken and further damage caused by running on a broken bearing. If that is the case it is a costly repair, I had to get a new washing machine.
Washing machines are simple to take a part to a small extent, just remember in what order you took things off if you decide to investigate further your self.
Dec 15, 2014 | Haier Washing Machines
Spin cycle loud vibration problems on spin cycle
What is the complete model number of your unit?
Dec 04, 2012 | Washing Machines
Squeaky basket and loud vibration when in spin cycle.
Bearings worn, belt loose and probably motor brushes.
May 17, 2012 | Kenmore HE3T Washer
Kitchenaid washers vibrating spinning, and leaking water on the right front side
Motherboard might be on it's way out..
May need balancing...
Check the hoses for leaks
Nov 01, 2011 | Washing Machines
Washing machine is working fine but has started making a real loud noise when spinning doesn't matter what speed or cycle it has always been real quite only had washer 3 years does not knock or seem out of...
As washing machines age some of the bearings and seals can begin to wear. After 3 years this wear my cause some noise but will not harm the operation of the appliance. Occasionally debris may become lodged around the drum. Visually check the drum for any lodged clothing, coins, plastic, etc. If you feel confident enough, remove the cover on the washing machine and check the drain for large debris.
If all else fails, installing an anti-vibration pad can lessen the amount of vibration/noise that you hear. Basically, even a small amount of vibration noise like you are describing can be amplified when it transfers to the floor of your laundry room. Try installing a set of small rubber anti-vibration pads like Silent Feet and you might be pleasantly surprised by the improvement.
If the noise gets worse or changes to a thumping or knocking, call you appliance technician or let me know. That may be the sign of something more serious, but I wouldn't be worried right now.
Feb 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Hotpoint VBSR2080WOWW washing machine vibrates with loud noise
hi,
this is a generic problem with top-loading washing machines. when the distribution of load is not uniform, it gives sound when spinning. if it produces noise even after equal distribution of clothes, the problem lies in the suspension. this is not a major fault, and can be put up with, rather than spending dollars on fixing it. this will in no way cause any special wear and tear for the machine.
cheers
Jul 22, 2009 | Hotpoint VBSR3100D Top Load Washer
Vibration of wash machine
Hi!
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 22, 2009 | Danby Washing Machines
Washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Aug 16, 2007 | Kenmore 9387x Top Load Stacked Washer /...
Washing Machines Logo
42 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
