Briggs and stratton engine #204412 type #0163e1
I want to overhaul engine . i need specs and instructions on how to r/r parts, it ran low on oil and may have thrown a rod or bearing. the engine is connected a generator. a troybuilt 5550 model 030245.
  • 1 more comment
  • Anonymous Jul 11, 2008
    I have the very same problem, with the exact machine. The connecting rod broke in half, the crankshaft journal is destroyed. to top it all, I had loaned it to my friend, and I said that the oil needed changing. No problem, "I'll do it for you".
    He drained the oil, put the plug in and cranked it. Shortly it goes kaboom!
    "I'm sorry". He says, "I'll fix it like new for you". Two months later I go for it. Most of the parts are missing, "I'm sorry". He says, "but if you can get it fixed, I'll pay you. The manual is missing. I need the correct crank P/N
    but, there is several for that type engine, and I dont know which to get.
    The other parts are pretty universal, so I won't have a problem.
    HELP!
  • Roy Cagle
    Roy Cagle Sep 13, 2014
    With friends like that, who needs idiots?
  • Roy Cagle
    The supposed repair manual for ALL Briggs engines can be downloaded from their website once you provide the model and revision numbers.
I found a parts list for model 204412 at http://www.buysmallengineparts.com/
Posted on Sep 07, 2008
I have the same problem. Rod broken and crankshaft junk. I don't have the manual either. Was going to try to order new engine. Engine doesn't have tag on it. Got all the info off generator. Went to troy bilt lowes website. It shows all the break down parts for generator. For engine it just shows #900 on drawing. When you go to #900 on parts list it just says contact manufacturer without any kind of part # or engine size. I went to Brigg & Stratton website and they don't list troy bilt model 030245. How can I find this information?
Posted on Aug 14, 2008
  • 1 more comment
  • Roy Cagle
    A short block will usually fix the repairs needed for these 10 HP OHV horizontal engines.
  • Roy Cagle
    For individual parts, check out prices and diagrams at ereplacementparts.com or jackssmall engine parts.
  • Roy Cagle
    A NEW engine of this particular model, with the custom crankshaft is very pricey.
On the valve cover the model and series is stamped .. If you can't find it, call briggs with the serial number of the generator and they may be able to cross reference .... Both push rods for the 204412 are the same length ... Also I buy my genuine parts from Tulsa Engine Watehouse ... Fast service .... 1/2 the price... I had a problem with the push rod and decided to do a top end ... Parts were 42$
Posted on Jul 11, 2013
  • Roy Cagle
    Briggs site ALSO wants a revision number when requesting to download a manual.
To get the generator off you screw the long bolt in a few turns and then tap it with brass hammer it will come right off the tapered shaft on the briggs powered generators
Posted on Feb 11, 2010
  • Roy Cagle
    That does NOT always work. You may have to thread tap the end of the shaft and install a push bolt puller to get it off.
My dad bought a Mod # 030245, and it sat for two years, before he needed it. Started it up, it ran for about three hours, and the generator burned up, the motor still runs perfectly, but no power, from Gen. we should swap parts. lol
Posted on Jul 21, 2009
The engine you have is likely a 10HP B+S model 204412. It is etched on the rocker cover if you'd like to confirm. My son just blew up mine, brand new, no oil.
Posted on Aug 23, 2008
  • Roy Cagle
    You have to really watch these kids nowadays, don't you?
    Problem Solver:
  • 7 Answers
I have the same problem so ordered a short block but am having problems getting the gernerator off the crankshaft and need to know if there is special puller needed or you can tell me the easy way to get it off.
Posted on Jan 28, 2009
Need a repair manual .pdf for a Briggs and Stratton Model 311707 Type 0132-E1 engine
H.A., Check the attached links,instruction and guides for Briggs and Stratton, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My 311707 0132 E1 Model Overview from PartSelect com
http://www.smallenginesuppliers.com/html/engine-specs/briggs_vertical_shaft_engines/276781SingleCylinderOHV.pdf FAQ Small Engine Specifications Briggs Stratton Specs
Briggs Stratton Small Engine Specifications
Jul 01, 2016 | Measuring Tools & Sensors
What are the torque specs on intake manifold on Briggs & stratton
if there is thread locking compound on bolt or threads it must be removed, use a tap to clean the threads and a wire brush to clean the bolts. Use a thread locking compound (blue) when reassembling, torque the bolts to 30 ft. lbs. alternating bolt to bolt in 7-10 lb. increments. Recheck the torque after the engine has been ran up to op temp.
Jul 17, 2014 | Briggs & Stratton Briggs Stratton Intek V...
My Briggs 23hp ran out of fuel is there a reset switch as the engin will not start anymore.
I would be checking low oil level as there is a low level oil switch that switches off when you run low on engine oil.
May 10, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
I am trying to figuare out what type of oil to put in a Briggs & Stratton model 09415-0 generator
Hi b_fesperman,
Here is Briggs&Stratton's webpage with the oil specs for their engines: http://www.briggsandstratton.com/engines/support/frequently-asked-questions/Engine%20Oil%20Recommendations/
Copy and paste the entire address into your browser and the information will open for you. Note that synthetic 5W30 can be used in all temps.
Hope this helps. If it does, please place a vote for me. Thanks,
Handie Andie
Jun 08, 2011 | Briggs Stratton H7159 & Stratton® 5500,...
Briggs & Stratton Van Guard 16 hp D.C. Chipper with Gravity Flow. With fuel switch on and starting engine four minutes, white smoke apprears and increases gradually, then heavier and chokes itself...
Sounds like your carb is flooding. Inside the carb, there is a simple valve that shuts off the fuel flow when the fuel bowl is full. If this valve fails, or if the float sinks, then too much fuel is forced into the cylinder and will wash past the rings and into the crankcase. This causes the engine to run very rich. You need to remove, clean and overhaul the carb, and change the oil and sparkplug and probably the air filter too. Find the model, type, and code numbers on the engine and go to www.partstree.com , www.ordertree.com , or your local repair shop to get the needed carb overhaul kit. Some B&S engines have an option of carbs, so look for a name on the carb itself...probably Nikki or Walbro. The carb kit is not very difficult to install, but make sure to get everything very clean before reassembly.
Good luck.
Sep 24, 2010 | Briggs & Stratton Chipper Shredder Patriot...
Overhaul the engine need Specs.
well you have all electrical parts now you need fuel squirt some fuel in the carb and try start it it will fire for a second thats it get back to me
Sep 14, 2009 | Briggs & Stratton Power Products 5,550...
Computers & Internet Logo
4,084 people viewed this question
David Payne
David Payne
