Question about Vacuums
My kirby g series doesnt **** properly anymore. A friend borrowed it, returned it with a scratch and now its nto sucking like it use to. My son took the head nozzle off, could it be not put back on properly?
  • mustang78 Jul 03, 2008
    Thanks... I will get my son to try that. But im in Melbourne Australia, so i will have to find a service centre. Does opening it up myself void any warranttee?
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=722170
Generic problem for all Vacuums
My Kirby G series doesn’t
Posted by mustang78 on Jun 30, 2008
My Kirby G series doesn’t **** properly anymore. A friend borrowed it, returned it with a scratch and now it’s not sucking like it use to. My son took the head nozzle off; could it be not put back on properly?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are a couple of things that you can check to see if it works properly. 1st replace the belt with a new Kirby Genuine belt, the average belt change is every 4 to 6 months, make sure the brushroll spins freely and when you install the brushroll make sure the screw heads are facing the carpet on both sides. B4 you start make sure the bell housing is locked down tight and when you plug it in raise the height adjustment to the highest level then drop it down one step @ a time until you hear the tone change or the brushroll should hit the carpet and @ that point vacuum to see if that is the correct adjustment if not drop it down one more setting. Also replace the paper bag with a fresh one and check to see if the outer bag is dirty and might need cleaning on the inside of the bag and not the outside. If you have further problems please feel free to contact your local vacuum cleaner dealer in your area or call the Kirby cust serv dept listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 30, 2008
After my son vacuumed up maybe a lego theDiamond G Kirby started sparking from inside housing. We took brush and checked for any loose items and found none. Any ideas and can I diy?
Sucking up a Lego or similar item normally should not have done any damage to the motor. It may stop the brush roll which may burn the belt if the belt is tight. If the item got sucked into the fan it may have broken or cracked it which could seize the motor. Remove the brush roll assembly, spin the motor shaft while you inspect the fan. Fan replacement is best to be done by an experienced technician.
Jan 24, 2017 | Kirby Vacuums
Roller doesnt spin on my kirby g series
That means that the belt is stretched or broken. You need to replace it. You can get replacement belts here:
Kirby Ultimate G Belts
Mar 09, 2010 | Kirby Ultimate G Bagged Upright Vacuum
My kirby diamond vacuum is not sucking. the small
Greetings from GoVacuum,
When the green light on the Kirbys stops working, this indicates that your belt has either broken, or fallen off the cleaner so the brush is not spinning. You're probably noticing that it's not picking up as well without that green light. If the belt is broken, and you need to a purchase a new belt, GoVacuum offers these belts for sale here; Kirby Vacuum Cleaner Belts 301291-3 (3 pack) fits all Generation series models G3, G4, G5, G6, G7, Ultimate G, and Diamond Edition in a 3 pack.
Once you have the new belt, please watch our very helpful video on how to replace it, and to make sure that the belt is on correctly, and the green light is on.
Kirby Belt Change Video;
If this video was helpful to you, please be sure to rate this solution by clicking the four Thumbs Up icons in the top right hand corner of this solution.
If you have any questions or needs some clarifications, please email me at chris.jones (at) govacuum (dot) com.
Thank you,
Chris Jones
GoVacuum
Mar 07, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Kirby shampooer not sucking water up
Your belt is not properly connected. Here is the instructions to properly install the belt on the main power nozzle. It works exactly the same way as the shampooer head, so this should be of help...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Marci
Jun 13, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby Ultimate Diamond Edition G Series, upright. Problem: I lost my manual. How do I use my vacuum on hard wood floors? How do I use attachments, where do they attach?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=576029
Posted by jlutsi on May 06, 2008
You can cal the Kirby factory to request a new owner’s manual and they will describe how to use the vacuum on hardwood floors. There is a felt piece as wide as the brushroll area that will clip on to the bottom of the revolving brush area so that you hard wood floors don’t get scratched. The Kirby head will dial off and the Kirby head will come off and the attachment hose will connect to the front of the Kirby and that is how you use the attachments. Also contact your local Kirby vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Don – The Vac Man
Go Ahead. Use Us.
May 06, 2008 | Vacuums
Kirby Ultimate G will not suck with main brush head attachment
You may need a new belt, it may have stretched enough so it isn't turning the brush roll anymore.
Mar 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
NoSuckage !!!
Either the lid for the dirty water tank is not completely on or the filter inside has been pushed up all of the way to the top. You need to have a 1/4 in. gap from the top to the top of the filter.
Nov 21, 2007 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Vacuums Logo
111 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
