Air conditioner fan is not moving air is coming from the vents but not cold
  • 104 Answers
Air conditioner probably has a failed run capacitor inside the unit. Check all circuit breakers and/or fuses first.
Posted on Jun 30, 2008
Unit fan comes on unit runs fan shows that it's running but not getting cold. Second unit comes on no problem getting cold.
Posted on Apr 20, 2009
3 Suggested Answers
  • 2559 Answers
SOURCE: air conditioner not blowing cold air
Just because the big one is cold and the small one is warm,Doesn't tell you if the system is properly charged or properly working.It is true that the big line will be cold and have condensation on it and the small one will be hot and dry,But this occurs in a wide pressure range,so the system could still be improperly charged.The charge in the system is based on the ambient temperature,The size of the system,The line footage,Etc............ So without a set of gauges and the ambient temperature,You can't really check anything but whether or not the unit comes on.
Posted on May 20, 2009
  • 236 Answers
Turn off unit supply and check the blower wheel inside the indoor unit by rotating it manually by your finger if the blower wheel rotates freely then there is something wrong with your fan motor or fan motor capacitor. But if the blower wheel is not rotating freely try to check the fan motor for lubrication or some bushing dried of and no oil
Posted on Dec 31, 2007
Goodman central air conditioning. Little air is coming from the vents in the house and the air that is coming out isnt very cold
have the central unit blower/fan cleaned as they block up from dust and other particles so that they eventually look like logs and do not move air like they should. Have the unit gas pressure tested for correct amount of gas
Jun 17, 2013 | Heating & Cooling
My airconditioner unit will not cool, compressor is running, but cold air will not come out of vents
mcdevito75 here, The compressor may be running but without the fan, no air will come out of the vents, Double check the fan operation on your A/C unit, turn the fan speed switch see if the fan is working if not, see your local A/C repair shop.
Jun 24, 2010 | Heating & Cooling
Fan blowing air not coming in the house blowing threw vents
check to see if those ducts have dampers if the do make shure there open and if they are open maybe close some of the others to balance or improve the preasure in the ducts that arent blowing enuf
Apr 04, 2010 | Ruud UBHC Air Conditioner
Cool air, but no fan, electrical smell inside house
most like it the motor windings are burn and you need to replace the blower motor
Sep 27, 2009 | Ruud UBHC Air Conditioner
Air condtioning unit
check capicitor on motor, fan motor bearings may be locking up when they get hot then when cooled the motor comes back on. Then you must replace fan motor.
Aug 11, 2009 | Heating & Cooling
The motor was making a humming sound, we stuck a screw driver in the unit to get the blades moving again it worked for a minute and now the blades aren't moving and we don't hear the hummming sound, there...
Aug 10, 2009 | Heating & Cooling
Apartment Central A/C Unit Not Working Properly
Sounds to me you are low on freon and the evap coil in icing up
Jun 25, 2009 | White Rodgers 0754-1 Electric Water Heater...
The compressor and fan don't come on when the air conditioner is turned on and hot air comes through the vents. However, when the relays are removed and a test wire is inserted into the relay port, th
Sounds like a bad heater control unit, or bad control module. You are bypassing the switch when you jump the relays, so usaully the switching mechanism is suspect.
Jun 02, 2009 | 2007 Ford Fusion I4 SEL Sedan
Everything is working .No cold air coming from vents
if the compressor is on the condenser fan ison the evaporator fan is on and no cool means lack of freon and also you can start and check with gauges
May 01, 2009 | Kenmore 72187 Air Conditioner
No air flow upstairs
Cold air is denser than hot air, so is harder to move. All vents have some mechanism to regulate flow, so close all of the downstairs vents. Check to see if your furnace fan motor has more than one speed, & set it on maximum. Keeping the fan on all the time will help as well. If all else fails, you may need a more powerful fan motor.
Jun 16, 2007 | Weather King 12AJA4801AH Air Conditioner
Heating & Cooling Logo
665 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
