Question about JVC AV-27D302 27" TV
TV powers on and then cannot change channel or change volume???
I have a jvc av-27d302 tv . it turns on with picture and the volume goes to the maximum. You cannot change channels or volume. I open the casing and see one board inside that looks to have all the controls. Is there a need for a repair manual??? If I change the circuit board will the remote control still work ?? Are there any adjustment to be done.???
Rick Cashion
  • Anonymous Aug 07, 2008
    I have the exact problem with my TV. Is it worth getting it fixed or should I start looking for a new one?
    Genius:
  • JVC Master
  • 1,673 Answers
The fault may be the control panel, or it may be in the uPC itself.
Most of the time, it is some of the switches on the control panel.
The most common cause of this type of failure is that many times when people clean the TV set, they spray cleaner directly on the screen or the set. The liquid runs down in to the set and causes damage. Sometimes the damage can be very expensive!
If the fault is just the control panel board, this can be easily replaced. You can order one from the manufacture's parts department or from one of their parts distributors.
You will need the service manual, a scope, and a DVM to troubleshoot the problem if it is more involved than just changing the panel. The only way to know is to try the panel unless you have a way to test it.
Jerry G.
Posted on Jun 30, 2008
VC IArt tv doesn't show picture and the power button flashes
There is shorted component/s in the power regulator section to your TV. Check and replace them.
May 07, 2012 | JVC AV-27D302 27" TV
I HAVE A JVC TV AND I WAS SETTING THE COLOR AND THERE I GOT A BLACK SQUARE IN THE CENTER OF MY TV I CHANGE TO STATION IT GOES AWAS THEN IT RETURNS
Check your Close captions and text1 options in the close caption menu screen, turn all off..
Please leave comment thanks....
Oct 12, 2009 | JVC AV-27D302 27" TV
Black box is taking up bottom half of the Screen
Check your closed-caption settings and make sure it's turned off. You'll probably find it's now set to text mode. The set is blanking out the part of the screen where text would be displayed, but there isn't any.
May 25, 2009 | JVC AV-27D302 27" TV
JVC D-Series TV top of picture shrinking
There are probably two capacitors that are bad in the vertical circuit. Not too hard to replace if you have any experience at all. Find the vertical output IC ( usually IC451 or similar ) and simply change the closest electrolytic capacitors. A professional can do this easily. Could cost up to $150.
May 13, 2009 | JVC AV-27D302 27" TV
JVC Interiart 27" TV
Hey there Andy l rekon ya busted yer remote so best git on down to the store an git yerself one a them universal remotes for xmas.
Nov 17, 2017 | JVC AV-27D302 27" TV
Green lock and black screen
go to your menu and turn off the ccd and text modes to remove the box,as for your lock out code try oooo or 9999.
Sep 22, 2008 | JVC AV-27D302 27" TV
How do you change the channel =S
usually you have a channel up and down
it looks like an awwow nowadays and is somtimes abbreviated like chn up of chn down
Feb 10, 2008 | JVC AV-27D302 27" TV
TV, i plug it in, turn it on, no image, "on timer" light comes on.
If you dont hear a click theres a problem in the standby power supply. if you do hear a click theres a problem in the Main power supply or sweep supply. Get a good tech to look at this for you if your not a tech. Good Luck
Aug 07, 2006 | JVC AV-27D302 27" TV
JVC AV-27D302 27" TV Logo
131 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
