Question about Insignia NS-30HTV 30" TV
No picture My insignia (CRT) TVHD30 picture will not come on. The red light goes to green when you hit the power button but the screen is blank. The fuse on the power supply board is good and I dont see anything obvious. Any help is greatly appreciated.
  • Anonymous Jun 30, 2008
    my tv set is dead, no picture on screen and no light on channel strip, when i power on the set, set still shows dead, what do i have to take the step to power on.
  • deezdrama Aug 13, 2008
    this is my third insignia is-tvhd30 crt tv set, for the money you cant beat the picture these sets have- in 1080i the picture is near as good as my 57" samsung dlp lcd....anyway I thought the third time was the charm and this tv worked flawless for a couple years, last night I turned the tv off and went to bed- this morning i woke up and noticed the green light flashing and making a slight clicking sound, when i got home from work i tried to turn it on but got nothing, unplugged it and tried again- now i dont even get the flashing light...any ideas? Im very handy with do it yourself procedures, is there a fuse or something inside i should check?
    Scholar:
  • 133 Answers
Try a "hard restart". which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics, to a certain extent.
You can also visit the manufacturer's website or call their tollfree number for problem solving info.
Hope these suggestions help you out.
Posted on Jun 30, 2008
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
Sony 42 inch wega when you hit the power button it goes to green for about 4 seconds then back to red and the tv picture never comes on or powers up.
Ur high voltage is dead.Ur FBT,call the Fly Back Transformer is dead.The block of plastic with a red wire with a cap go to the CRT(ur tv tube).
Sep 06, 2009 | Televison & Video
Sony KDF-46E2000 - Screen Goes Blank
The lamp can cause the picture to cycle without spitting out a lamp error. I'd replace the lamp and clean out the dust/dirt from fans, etc to hopefully resolve your issues.
Dec 06, 2008 | Televison & Video
Green and red lines on tv
What kind of projection tv are we talking about a lamp based unit? or a CRT based one? If it is a lamp based one then you could have a dirty light engine which is expensive to replace. If it is a CRT based one you could have bad convergence IC or one of you tubes is in overdrive and the screen voltage needs to be adjusted.
Oct 06, 2008 | Sony KP-51HW40 51" Rear Projection...
Insignia 42 inch TV won't turn on
The power supply is in the protect mode. There are many things in the set that can cuase this. Most likely there is a short on one of the circuit boards, or the power supply itself has failed.
You will have to have the set serviced in order to get it going again.
Jerry G.
Jun 03, 2008 | Televison & Video
IS-TVHD30
I fixed the problem with the "no power on, low clicking noise". The NPN transistor (2SC5931) was shorted. This transistor controls the horizontal hold. The shorting caused the power supply to overload and restart, then recycle. This was the cause of the clicking noise. Unfortunately this transistor was over $50, most likely due to the extinction of CRT's. I did find a replacement transistor 2SC5552, which only cost $2 (but I was able to get it in Mexico). The location of the transistor is located on the left side of the TV (looking from the back). Directly in front of it is the high voltage transformer which powers the CRT (should have a thick red wire). The transistor is attached to a large aluminum heatsink. To remove the transistor you will have to remove the entire electronics assembly to you can easily get to the underside. This was the solution for my TV, but there could be other components damaged.
Apr 14, 2008 | Insignia LCDTV26 26 in. Television
Insignia NS-27HTV
check & replace chroma ic. good luck!
Jan 16, 2008 | Insignia NS- 27" TV27 TV
Green Screen
check on crt board green amp transister and associated ckt should be short. or green drive transister,or main jungle ic which drive green signal is sure defective, i had the same problem in rca 32 inch tv for all screen red,replacing chroma ic solved the problem.
Sep 12, 2007 | Insignia IS 20" TV040919 TV
Insignia NS-30HTV 30" TV Logo
150 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
